Question about Honeywell Programmable Thermostat Heater
I have Honeywell programmable eletronic thermostat model RTH230B. Tried turning on central air but the air conditionaing unit does not turn on. I then set the thermostat to the manual mode and set the temperature down to 60degrees. Still no air conditioning. Please help.
  • 407 Answers
This problem is more than likely not the thermostat at all. The best way to see if the thermostat is at fault, is to pull the cover off and you should see a R(Red) terminal and a Y(Yellow) terminal, carefully jumper the two wires together and see if the outside unit comes on. If not, then the problem doesn't lay in the thermostat. You can also jumper the R and G terminals and see if the fan blower motor on the indoor unit comes on if you don't have another person to help. The thermostat is just a switch board for your controls on the inside unit and outside condensing unit. It is all 24v wiring coming from the unit and supplying the power to the correct terminals on the thermostat. Unfortunately, if your problem is not the thermostat, you can have a number of different problems going on. A few places to look.....
1. Breaker box to make sure nothing has tripped.
2. Make sure your indoor unit is still coming on.
3. Outside disconnect box. It will be by the condenser and should have fuses in it (some do not). To check, you will need to ohm the fuses. IMPORTANT: If fuses are blown, you could have a short in the condensing unit which should be checked first before changing fuses.
Hope this helps some and good luck!
Posted on Jul 11, 2010
Batteries died on my honeywell RTH230B replaced but furnace won't
you will have to reprogram it according to the operating manual.
The manual is available on www.manualnguide.com
Feb 02, 2010 | Honeywell Programmable Thermostat Heater
I have a Honeywell programable RTH230B. I changed
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jan 08, 2010 | Honeywell Focus 6300B 5-2 Days...
Flashing snowflake on display
That is a Time delay normal to keep the condensing unit from turning of and on to fast really save the life of the equipment
Jun 16, 2009 | Honeywell Programmable Thermostat Heater
The heater runs and doesn't want to shut itsself off
check the wire to the thermometor then if the wire is ok replace the thermostat
Mar 03, 2009 | Honeywell Programmable Thermostat Heater
Model RTH230B uses a lot of batteries
THIS TYPE has been deemed defective! changeout to a different type.
Sep 04, 2008 | Honeywell Programmable Thermostat Heater
Central honeywell air conditioner
Sounds like it may have lost power. Check the breaker and the fuse at the furnace. If they are all in the on position and working then it sounds like you may need a technician. If the display is blank on the thermostat you may also want to replace the batteries.
Jun 12, 2008 | Honeywell Electronic Programmable...
Honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Mar 07, 2008 | Honeywell Programmable Thermostat Heater
Honeywell Programmable Eletronic Thermostat model RTH230B
There are so many products, we cannot help without the model no. Try typing 'Honeywell programmable electronic thermostat' into google and searching for an image of your thermostat, then get the model no. Then you might be able to get some help.
Dec 20, 2007 | Honeywell Programmable Thermostat Heater
I can't program my thermstat
go to www.honeywell.com. There you will find a search tab. Type in the exact model number of your thermostat. You will be able to download the installation/owners manual.
Nov 29, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
277 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
