Question about Honda Quincy 17 - Gallon Air Compressor with 5.5 Hp - G15H17PC3B
How many quarts of oil are required when changing oil?
    President:
  • Honda Master
  • 1,388 Answers
Nice compressor! The gx160 engine needs a little more than 1/2 quart. (.6 to be exact) Honda recommends changing oil every 6 mo. or 100 hours with 10-30 for cooler climates and 30 for temp ranges of 60 - 100 deg.. The pump needs about 12oz of compressor oil. I buy the oil at Lowes for less than three dollars. If you work in a very hot environment then use their synthetic oil, (about $7) it will take much more heat and you do not have to change it as often. It is not mentioned anywhere but there is a little air muffler on the pilot valve that discharges air when set pressure is reached that should be cleaned / checked. There is a screen that gets clogged causing heat. Good Luck.
Posted on Jul 08, 2010
Toyato camray with filter how much ltr 2008 model
Toyota 2008 Camry V6 requires 6.1 quarts of SAE 5W-30 oil with filter change
The 2008 Camry's with the 2.4L I4 require 4.5 quarts of new 0W-20 or 5W-20 oil with a filter change
Oct 11, 2012 | 2008 Toyota Camry
How many quarts of oil for an oil change
Depend on the size of engine.
4 cylinder engine 4 quarts.
6 cylinder engine 5 quarts.
Oct 06, 2010 | 1995 Toyota Camry
Amount of oil
The Engine oil capacity on the VL 800 is:
3.2 U.S. Quarts (3000 ml) without a filter change
3.6 U.S. Quarts (3400 ml) with a filter change.
While Suzuki does not expressly recommend a filter change with every oil change, I change the filter anyway. I don't like the idea of leaving nearly a half quart of old, dirty oil in my machine.
Jul 28, 2010 | 2002 Suzuki VL 800 Volusia
How many quarts of oil is required for an oil change
put three in then check dip stick..let oil settle before checking.if low add another.
Jun 06, 2010 | 2004 Nissan Sentra
Lawn Tractor 1000, oil chg
there is no filter. but when you drain the oil. start by adding a 1/4 quart and check the level. if still low keep adding (little at a time) until it reaches the full mark on dipstick...good luck
Apr 03, 2010 | Garden
How many quarts of oil does it take for a 2007 toyota avalon?
If it's a 4 cylinder it holds 4 quarts ( with new filter). If it's a v-6 it holds 6 quarts (with new filter).
Jan 20, 2010 | 2007 Toyota Avalon
How many quarts of oil in suzuki C90
My 2007 C90t which is the same motor as yours requires 4 1/2 quarts of 10/40wt.
Stick with Suzuki brand oil btw. When I changed to Amsoil, I developed a problem.
Sep 03, 2009 | 2005 Suzuki Boulevard C90T
Oil change 2007 chevy malibu maxx
2.2L takes 5 quarts
3.5L and 3.9L take 4 quarts
Both quantities are with oil and filter change
Sep 08, 2008 | 2007 Chevrolet Malibu SS Sedan New Cars
Honda Quincy 17 - Gallon  Air Compressor with 5.5 Hp - G15H17PC3B Logo
563 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Tim Venetis
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
