Question about John Deere Garden
Sabre lawn mower srart right up but sputters when blade is engage
Sabre lawn mower srart right up and runs great UNTIL the blade is engaged, then it sputters and dies after about 60 secomds. I replaced the fuel filter, any ideas?
jgwhomeequip
  • 1902 Answers
SOURCE: toro timecutter spits and sputters when blades are engaged
Did you drain the fuel before you put it away? If not then you should drain the fuel and clean the carb. Gas when in lawn mowers and any other small gas engine will turn into a slim in a way and will block the carb. Drain the fuel and clean the carb system will run great when that is done
Posted on Feb 19, 2009
GM Elec
  • 1000 Answers
SOURCE: Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
mowerman1857
  • 389 Answers
SOURCE: When I put the mower in gear, or engage the
Sounds like the seat safety switch is shorted or worn out. You can test it with a short length (about 6") of wire. Strip about a half inch from each end of the wire, unplug the connector under the seat and plug your "jumper" wire in to each side of the connector (NOT the seat switch) If it now works, replace the seat switch
Posted on Sep 16, 2009
Testimonial: "Thanks. The problem was the seat safety switch was loose and not fully engaged. When I plugged it in correctly, everything worked!!! Thanks again."
heres2maine
  • 84 Answers
SOURCE: Blades will not engage on Husqvarna riding mower.
Could be a broken belt, loose belt (stretched) or something is under the mower deck jamming the blades. (stick for an example)
Posted on Apr 15, 2010
07 mtd yardsman mower with 13.5 tecumseh runs great untill engage mower , then dies down and blows black smoke
This sounds like a micro switch acting up, the first switch to check is the seat switch, make sure the block connecter is pushed fully home on the switch ( there is often a fail safe inside the connecter should the block come away from the switch )
Jul 08, 2012 | Garden
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Craftsman dlt2000 20 hp kohler runs great until i try to engage blades pull up on the switch to engage and motor bogs and stalls
Now is a great time to remove the deck and sharpen the blades! In the process, you will find your problem. Look for clogs, seized bearings, freely rotating belts, etc... The problem is in the deck or drive belt. Hope this helps!
Sep 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The 12.5 murray 38 in runs fine until i engage the blades,while engaged the mower runs fine for about five seconds then starts to spit and sputter.once i disengage the blades it runs smoothly again
The problem is in the carb. First try using some bottled fuel system cleaner at a heavier dose than for a car, but be aware that too much may damage the carb. Then run the fuel out and fill with fresh and try again. When you engage blades and it sputters try to throttle down until it runs smooth and then slowly bring engine back up to mowing speed. You should be able bring it up and mow. Run out the fuel tank. If unable to do this trick and get the fuel system cleaner through you will need to have the carb. taken apart and cleaned thoroughly.
Jul 07, 2011 | Garden
My 48 inch riding mower shuts off when I try to engage the blade. It runs until I try to engage
mine has a reverse cut out when blades are running....maybe the switch is bad and thinks mower is in reverse therefore shutting down the mower when the blades are engaged....
Aug 21, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Motor chokes and misses under moderate load and loses power
Sounds to me as tho it might need a carburetor adjustment, providing there is an adjustment screw on the carb. Sounds like the engine is running a bit lean. Did this problem occur right after the carb cleaning, or was it there in advance? Is there a fuel filter that might be clogged?
Jan 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blades wont engage
check the clutch if it engage then check the cable and belt to if it works make sure all the bolts are tight. usually the belts is too loose or if its a clutch drive maybe the clutch doesn't engage or worn out.
Aug 16, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Toro timecutter spits and sputters when blades are engaged
Feb 19, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
148 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
