Question about Cycling
When I apply my brakes almost nothing happens and it squeeks.. i have tried tightening and loosening them but nothing works.
  • 252 Answers
Hi
Depending on what brakes are fitted (I'll assume V brakes or U brakes for now) here is a similar procedure for both:
On the brake itself, loosen the pinch bolt , move the arms of the brakes inwards, so the pads are 1-2mm from the rim, tighten the pinch bolt. If the pads are down to their wear indicator, replace them. If they are missing the rim, on the ouside of them they have an adjustment bolt, loosen, aim the pads at the rim and tighten.
Adjust the lever tension by spinning the adjustment screw. Get this right for your own preferenece.
An added tip, to get your brake pads working amazing for a week or so, get a cloth, some Coca Cola and wipe the rims. The acid in it, cleans the rims of oil/contaminants and the stickiness grips the pads :)
Vote for me when this works , thanks.
Posted on Jul 08, 2010
Grinding/Squeeking Sound
Sounds like the brakes - take it to a repair shop.
Apr 11, 2014 | 2005 Chrysler Town & Country
Steady brake light on dash
i wonder if you mean abs light i f so loosen and re tighten .often no contact makes the abs light come on .other wise release emergency brake perhaps the peddle got pushes a couple of clicks enough to make light come on but not enough to look like it is applied.try emergency brake first push then release with handle.you wouldnt beleive how many people this happenes to .
Jan 19, 2013 | 2001 Chevrolet Silverado 2500
97 Chevy S10 rear end squeek that goes away when brakes are applied
If you have rear disc brakes, one of the rotors could be warped and causing the pads to move in the caliper.
You should be able to remove one wheel at a time, lock down the rotor with the lug nuts, and put the trans in low gear or reverse to listen for the noise.
Jan 14, 2013 | 1997 Chevrolet S-10 Pickup
Bleed brakes
There are a couple youtube videos on bleeding lines that will help you out. In a nut shell though you have to go to each wheels bleeder valve and loosen it while pressure is being applied to brakes slowly. As the pressure is applied either air or fluid will come out. When you get nothing but fluid you are done at that wheel. tighten bleeder screw and and move to the next. After each wheel is bled you need to fill up the brake fluid again. Now this is just a nutshell explanation and you NEED TO WATCH THE VIDEO for full details on how this is done and to understand it. Go to youtube and type in brake bleeding. They will come up.
Sep 29, 2012 | Avid Juicy Five Mtb Hydraulic Disc...
There is a squeek in the front end, Just put new brakes in but it still squeeks. Could this be a CV joint or a Bearing? The noise is present with or without the brake s applied. There is no vibration and...
worn CV joints "click," but only upon turning.
worn bearings "grind," with a faint metal-on-metal sound.
So, squeaking in the front end is unlikely to be a CV joint or a bearing.
Squeak could be almost any front suspension component, but here's the reason to stop
guessing what it is and jack up the car, remove the two front tires and inspect the
front suspension: it could be a bolt/nut
that is loosening - and by catching it, and tightening it, you could save yourself the cost of
replacing the missing hardware. Also, be aware that an inspecting mechanic (if your state or
county requires a safety inspection (like Pennsylvania)) will inspect all components of your car's
front suspension as a routine component of your car's safety inspection.
Also:
1-----Inspect----- Coil Spring----- Broken or Weak Coil Springs.
2-----Inspect----- Sway Bar Bushing----- Worn, Damaged, or Faulty Stabilizer Bar Bushings.
3-----Inspect----- Steering Stabilizer Bracket----- Loose or Broken Steering Stabilizer Bracket.
4-----Inspect-----lower ball joints-----Loose bolt/rubber bushing to lower control arm.
5-----Inspect-----Upper Ball Joints-----Loose bolt/missing rubber bushing.
6-----Inspect-----Connecting Rods-----(these are the rods that connect the lower control arm to the
front of the frame) Check for loose nut (on the frame side), or loose bolts (on the control arm side).
May 22, 2011 | Saturn Vue Cars & Trucks
2001 SL-1 disc brakes in front, drum brakes in back. When I apply the brakes it feels like my wheels are wobbling or out of round if that makes sense. The brakes have 26,000 miles on them.
Hi and welcome to FixYa!
As a first course of action I strongly suggest that you have the hub nut tightened. If it's loosen, it may shake even not braking. Very dangerous so please have it checked and tightened.
Hope this helps and thank you for using FixYa! Have a good one!
Mar 05, 2011 | 2001 Saturn SL
The housing of my brakes on the handle bars is loose and keeps moving. how do i tighten it so that it stops moving when i apply pressure on it and/or squeeze the brake lever??
If the screw is all the way tight and still slipping ... try to find a fatter part of the handle bar to mount the grip to. You will probably will not find any such that is convenient for you to continue to use the brake ... remove the grip, wrap some electrical tape around the handle bar, reattach the grip. Tighten it and give it a try.
I hope this works for you
a
Oct 12, 2009 | GMC Denali Road Bike
Brakes squeeking
Try spraying the calipers and pads with brake clean usually the squek is from brake dust build up. The caliper slides are the only places where high temp. synthetic caliper grease is used try that as well.
Jul 23, 2009 | 2007 Dodge Charger SRT8 Sedan
2006 chevy silverado 1500 front brakes are squeeking
on disc brakes there is a metal marker on them that when the pads get low on material it will make a squeeling noise to let you know its time to change the pads.. so I would say you are in need of front pads also even though they look good you are getting low.. this marker is designed to let you know its time before you get to metal to metal .. jerry
Apr 30, 2009 | 2006 Chevrolet Silverado 1500 2WD
Adjusting the emergency cable. I have just installed new brake shoes, rotors and pads. Now the emergency cable doesn't work anymore. Could you please tell me how to adjust it so that my emergency brake...
it will be a simple wrench adjustment on the cable itself, the cable should run underneath the driver side of the vehicle. You will see an adjustment area with a cable connected to a piece of all-thread that has a nut on it, generally, tightening this setup tightens the cable, loosening looses up the cable
Aug 07, 2008 | GMC Jimmy Cars & Trucks
Cycling Logo
114 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
