Question about RCA 32F531T 32" TV
My friend has a proscan TV (model PS36600) with gemstar guide plus+ gold. She has cable service reception on 74 channels (no cable box or VCR). The guide stopped updating. Repeated attempts to setup the guide result in the same message: "The search for data has failed. Please check your tv reception." No other message is displayed in the guide message screen. Years ago I fixed this condition by a software reset procedure that someone told me. It was not in the user manual. I do not remember the procedure. I think it resets the zip code to 00000 among other instructions. Can you help?
  • 1 more comment
  • joeneu90246 Jul 08, 2010
    The above proposed solution recomends that I purchase a new set top box tuner. The cable service is provided without needing a set top box tuner.
    The tv tuner works fine for all 74 channels.
    On original power up, or on first power up after moving to a new location in a new zip code, the guide sends a message listing the data for several service providers, and requests that I choose the correct data set for the guide to use. The guide then stores that provider group.
    Now the guide search for data fails. I suspect the guide has selected data for an incorrect cable service provider. There are data for more than one service providers on my incoming cable.
    I need to force the guide to perform the original power up routine which will include selecting the cable provider data set. I remember that the procedure includes resetting the zip code to 00000. I do not remember the rest of the procedure.
    Cable service is provided by coax cable connected directly to the coax connector on the tv (Proscan Model PS36600). No set top box is provided or needed. All 74 channels are being received and selectable by the tv tuner. Works fine. No problem with reception.
    The problem is inability to download the Gemstar Guideplus+ Gold program data.
    The Guide screen message states: "The search for data has failed. Please check your TV reception."
    Program data is downloaded in 3 message files for 3 different cable providers. To work, the guide must be told which provider message file to use. The TV has defaulted to the wrong message file which doesn't match the real channels, resulting in the failure message on the Guide screen.
    The fix involves clearing out the wrong defaulted message selection, and setting the TV to do a Guide Setup as if it was the original Setup.
    Several years ago, I fixed this same failure. Someone told me how to do it, but I have forgotton it. It is not in the UserGuide manual.There are about 3 or 4 steps total. I recall having to set the zip code to 00000. I cannot recall the rest of the steps. This fix is not in the user guide manual.
  • joeneu90246 Jul 09, 2010
    The proble3m is NOT that I do not know the guide code. I don't need to know. When I go through the steps to Setup the Guide (after a power loss), the Guide detects programming data from 3 different providers. The Guide then sends a message for me to select one of the 3 data sets (when it is working). It is easy to select the correct data set.
    The problem is that the Guide doesn't send the selection message at all. The Guide software has not entered the path to "make a selection" of the 3 data sets. Instead it is stuck in a default selection which is not the correct one.
    To force the software to the routine to make a new selection, I need to reset the software to clear out the default selection as if the TV was being turned on for the first time.
    Someone gave me the procedure a few years ago when I had the same problem. It worked. I do not recall the procedure which took only 3 or 4 steps, including powering down and setting the zip code to 00000.
    I would like to do this procedure again, if you know it. It works.
  • RCA Master
  • 5,138 Answers
2 things other then what you are talking about (1) is Poor solder connections that feed off the board mounted t te left side of the turner where you connect cable (2) on Same Board is a transistor that shorts
killing the IF output Q904 located at top of board.Heres another thing you can try with TV turned OFF / Press and Hold at Same Time
Ch- and Vol- wait for TV to come on, you should then be in Service Factory Menu. This should allow you to reset to Factory program.
Posted on Jul 09, 2010
  • 10,865 Answers
Hello. These codes change on a regular basis. Call your cable service provider. They have a vested interest in assisting you. J.
    President:
  • 1,768 Answers
1 you will require a cable box to view your
Posted on Jul 08, 2010
  • RCA Master
  • 5,807 Answers
Hi
joeneu90246,
A simpler way could be having a Set top Box or other separate
tuner to accessed scrambled or DTV programs.
And connect the unit through the AV connections , not the RF
type that you are using , And use the remote that comes
from the STB
As I try to find more possible solution to your problem.
Of course , you need to set the TV on AV mode.
Posted on Jul 07, 2010
  • Rommel Cana
    Rommel Cana Jul 08, 2010
    to go to service mode
    Turn the TV on. Hold down MENU and hit POWER and VOL+.
Picked up tv from friend and cant get it to work
yes. you need to reset guide plus+. with factory tv remote, press.... menu, 7, 1, go-back, tv........ then press menu, 7, 1 , go-back, who-input....... then it will ask you to set up tv with your zip-code.
Nov 09, 2009 | RCA Televison & Video
Hi just got a LG dvd/vcr Model RC897T. I have it hocked up right, but i can't get it to switch over so that it would be seen on the TV. can you help
If a cable box is not required for cable signal reception, connect the cable line to the ANT. IN connector on the recorder.
If a cable box is required for cable signal reception, connect the cable line to the IN connector of the cable box. Connect a coaxial cable from the OUT connector of the cable box to the ANT. IN connector of the recorder.
To view or record a CATV channel:
  1. Tune the TV to the Recorder output channel (CH 3 or 4).
  2. Set the Recorder channel selector to the cable output channel. (Example: CH3).
  3. Select a channel using the cable converter.
With this connection, you cannot record one program while viewing another.If you are using a cable box to tune channels, it is not necessary to do Auto Channel Set.
Oct 20, 2009 | LG RC897T DVD Recorder/VCR Combo
VCR doesn't record since Comcast installed digital box
Try this..Run cable line into VCR in, cable from VCR out to box, then cable from box to TV..this might work...I have done this for YEARS and it is never failed. You can then watch and record 2 things at once.
Feb 12, 2009 | Proscan PSVR72 VHS VCR
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
RCA Gold Plus+ Guide problem
go to menu and find the automatic set up of your channel
May 27, 2008 | RCA 32F531T 32" TV
RCA Guide plus gold gemstar T.V
I have a guide plus gold gemstar tv and I cant program my direct tv remote or Innovage jumbo remote to operate the tv, can anyone help?
Oct 22, 2007 | RCA F32450 32" TV
Poor reception
It sounds like a problem with the tuner in the TV set. Hook up a VCR through the video inputs and hook the cable through the VCR and if the picture is still snowy, the problem is the cable. If the picture is clear, the problem is the tuner in the TV set. If you wanted, you could simply leave the VCR attached to the TV set and change cable channels through the VCR, or have the TV serviced. Good Luck
Jun 20, 2007 | Mitsubishi CS-40505 TV
Recording instructions
First, whether or not you can do this will depend on cable box useage, and how the VCR is hooked up. In the earlier days of cable TV, & off-air reception, this was a simple task. If you have a satellite receiver box or cable box which is used to tune the channel, rather than using the TV itself or the VCR tuner, then recording one channel while watching another may not be possible. While I don't know the capabilities of newer sat/cable boxes, older ones sent just one signal out to the external equipment (TV etc.) That one signal (channel) is all that is available. If you received a manual with the sat/cable box, see if it says anything about this issue. That being said- if you don't use a sat/cable box, but instead use your TV or VCR to select the channel you are watching, then assuming the VCR is hooked up inline with the TV, just setting the VCR/TV option to TV will pass all channels through to the TV, and you can then use the TV to select whatever channel wished, while the VCR is recording something else. Hopefully I haven't confused you. If another contributor has some additional info on the capabilities of sat/cable boxes of today, please read their contribution.
May 22, 2007 | GE VG4052 VCR
No picture channel 2-3-4-5-6-7
bad tuner or gemstar module
Dec 08, 2006 | RCA F32649 32" TV
RCA 32F531T 32" TV Logo
186 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
