Question about Toshiba 36A40 36" TV
Black line problems
I have had this tv since I was young, got it back in the 90s so its really old. Anyway the tv has been dying slowly for the past 2 years. It started with just one line across the top of the tv aout 1 inch wide, just a solid black line. Now it has expanded slowly all the way to about 3 inches wide. I noticed the other day that if I try a vhs and the crackly screen comes on that the lines no longer are there and you can see the entire screen, but as soon as the movie comes on the line (3 inches wide) comes back. SO what could this be.
-Joorod
    Genius:
  • Toshiba Master
  • 1,689 Answers
Some components in the vertical deflection amp have been going out of spec with age.
The set may no longer be worth to spend money to service it because of its age. However, if you wanted to invest the money, the set is serviceable. Considering its age, the CRT may be soft, and there are many other older components that can soon fail.
I would be considering a new set.
Jerry G.
Posted on Apr 22, 2008
Chevy cavalier dies
didnt specify the year but some of the older 90s the torque converter clutch solenoid [ tcc ] failing or connector problem you can disconnect it and drive i believe the 95 and down can be replaced by unscrewing it from case --others are inside unit
Sep 08, 2017 | Cars & Trucks
I have black line down right side of 42 inch hitachi lcd tv screen
You have a CCFL lamp that is failing in the panel, time for a new TV
Jan 22, 2018 | Hitachi Televison & Video
There are vertical 1" to 2" black lines that come and go. They are on the top half of the screen only. Also, the TV takes 40 min of flashing before the picture comes on. Our TV is about 5 years old. ...
Yes,This tv have two problems.One is the power supply board have dead capacitors,need it to replaced,the other is the vertical lining board on the bottom near the speakers need all the old lining to resolders.The shop will cost u $ half to repair,it to buy a new tv.
Apr 04, 2010 | Toshiba 42HP84 42 in. Plasma HDTV
Screen will periodically go half black. Then it goes back to normal. Or the black slowly creeps up from bottom of screen.
Ur backlight video board is dying,just not completely dead yet.Must replaced to solved this prob.
Dec 11, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
I have a sony bravia kdf-e5oa12u and for the past 2 weeks it keeps going off for about 5 mins and then if u press the power button it comes back on.But the past 2 days its takin up to at least 3 hrs to gt...
Ur high voltage is dying.The big black block of plastic with a wire with a cap that hook to ur CRT(tv tube).It call the FBT the Flyback Transformer is dying.That were the niose came from.
Sep 09, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Black line across screen
module problem take it to a Authorized dealer or a NESDA dealer service manuals hard to say if available since analog TVs are slowly going away and parts well another story might as well go buy a new HDTV set as a CET no garuntee how long it will be analog TV parts will be discontinued. FCC has alot to do with it.
Apr 16, 2009 | Televison & Video
2000 Nissan Maxima Battery & Brake Light On
I thought this was free support. Apparently I was wrong. How did I fix it? Easy, I broke down on the freeway and got towed home on a flatbed! That was easy!!
Jul 30, 2008 | 2000 Nissan Maxima
JVC TV 27" Black line on top of screen
This is for the original problem.. Not the second post.
It's a problem in the horizontal deflection circuit. The parts will be available, but you will be in for some daignostic repairs also to find out why it failing or if it has failed on it's own.
There should be a few caps near the IC (an LA7840) that could also be causing the problem. Click the link, it will make it easier to locate the part inside.
This is the kind of repair best left to a TV tech, but get it done now and it won't cost anywhere near as much as it will later.
Apr 18, 2008 | Toshiba 42H81 42" Rear Projection...
Washed out colours and thin red lines across the screen
your problem is in red video circuit. please get it done with skilled tech.
Oct 05, 2007 | Panasonic CT-32SL15 32" TV
Weird lines
your getting a 120 cyclr hum,possible a leaky cap in the power supply also check all ground connections are tight
May 23, 2007 | Sony KP-51HW40 51" Rear Projection...
Toshiba 36A40 36" TV Logo
66 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
