Question about Samsung LN52A550 LCD TV
My Samsung LN52A550 LCD TV will not stay on.
Hi; my Samsung LN52A550 LCD TV will not stay on. I keep hearing tick-tick-tick noise; why it comes on and then off. It keeps repeating the tick-tick noise over and over; and will not stay on... Any ideas on what could be wrong?
  • Samsung Master
  • 1,606 Answers
The ticking noise usually comes from the power section of the tv. Usually it is a capacitor failing. As far as the cost of repair this can go either way ie cheap or expensive. It will dpend on what exactly has failed and if it requires a board replacement or just a part.
I'm going to assume this isn't under warrenty anymore. It is covered if it is. You need to get some repair estimates from Samsung and any tv repair shops. Then keep and eye out for a replacement. Make sure you include any shipping costs or other costs when you are totaling up the estimates. If it gets close to the replacement cost then you will have to choose if you want a new tv or have a repair done.
Posted on Jul 07, 2010
My Samsung LN52A550 has colored vertical lines in the middle and right side of the screen is black. Is the problem related to T-CON?
Yes,this problems alway the problems and the causes by the T-CON decodering board.If this problems acurring by it self.If this problems are causes by and an object or a person by hitting the LCD screen panel itself,than LCD screen is dead,not repairable.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
Mar 02, 2011 | Samsung LN52A550 LCD TV
When i turn on my samsung LN52A550 it usually looks red and then gets lines across the piture but after about 20 minutes it clears. Anyone ever hear of this?
I had this problem on my Samsung set too, along with capacitor issues. I fixed this issue, though, by disconnecting and reseating the long ribbon cable between the main board (the one with the cable jacks) and the LCD controller board (near the center top of the set). On mine, I had to pinch ears on either side of the connector on each end to remove the connector, and then I clicked the connector back in, and viola, no more lines! This is likely due to minor corrosion on the connector pins, and reseating clears the problem. If it doesn't, you may have a bad LCD controller board, which can be usually found on ebay.
Nov 01, 2010 | Samsung LN52A550 LCD TV
Samsung LN52A550 no picture
I hope our talented expert would have given you helpful info in chat session about your tv problem, let me know if you need further help.
Thanks.
Sep 27, 2010 | Samsung LN52A550 LCD TV
Samsung LN52A550 "no picture
do you hear any click click sounds? A common theme with Samsung. My tv did click and it was the capacitors.
http://www.youtube.com/watch?v=tK7zFBBU6p4&feature=related I watched a few of these and was able to see my tv had 4 bad capacitors, de-soldered and replaced them for under $5.00.
SAMSUNG SERIES 5 550 THE TV WILL TRY TO COME ON AND THEN SHUT DOWN AND START OVER.
Most likely failed capacitors in the power supply. I recently had the same problem with my 26 month old Samsung LN46A750. Samsung paid for the installation of an upgraded power supply board.
http://www.thebuzzmedia.com/samsung-tv-capacitor-clicking-issue-and-free-repair/
http://www.avsforum.com/avs-vb/showthread.php?t=1198409
Aug 27, 2010 | Samsung LN52A550 LCD TV
Samsung 52" LN52A550... tv makes clicking sounds, and won't turn on! HELP
This is a known problem due to the bad capacitor(s) on its power board. Samsung will fix it for free. If you want to fix it yourself, go to Youtube and search for "Samsung clicking"...
Aug 18, 2010 | Samsung LN52A550 LCD TV
LCD TV LA40R81BM/XTL tv tick tick sound 5min then strat
Hi my name is Roety,
I can help you with your issue ,
This is most likely a power supply issue
I usually replace the swollen capacitors I can see
A repairman would charge about $300 to replace them for you.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Dec 15, 2009 | Samsung LA40A450 40 in. LCD TV
I have a samsung LN52A550 LCD tv set and it won't show anything with a HD signal. If I hook up a 480I signal the tv will work,but if I hook up the tv antenna or any other hd source to it,the tv goes crazy...
Get a roof or digital antena.Will give u better signal.HD 1080i CBS,NBS check that if u have that in 1080i well able to get HD on the set.U might have a 720p tv set.
Dec 15, 2009 | Samsung LN52A550 LCD TV
Ticking noise from TV - Sony 50' rear projection 1080p LCD
The problem is ht leakage . remove the ultar cap of the tube and clean both the tube and cap with wd 40. then reinstall cap using some silicon glue.
this will correct your fault.
Jul 11, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Samsung LN52A550 LCD TV Logo
902 people viewed this question
Jerry Greenberg
Jerry Greenberg
