Question about Mitsubishi CS-35405 TV
I have a cs-35405 tv that sometimes does not turn on not even the green light. the only related condition i can identify a low voltage of 110 or lower. is this a weak relay, a safety or something else?
  • shp_16509 Jul 07, 2010
    this is not a Projection T.V. and it makes no difference if the remote is used or the switch on the set is used
  • Mitsubishi Master
  • 6,993 Answers
it can be a weak relay, it should be from the transformer. The Transformer might not be receiving sufficient power to supply into the TV board. Also, check the TV power cord, if its intact. The power cord might be daisy sometimes and cannot be overlooked.
Take care.
Posted on Jul 07, 2010
  • 712 Answers
Is that a Projection T.V? If yes, do that turn off when you are watching it? And if yes, go get your t.v transformer changed. Do that only if the second problem do occur. If not, try changing the battery of your remote, it they are old. They might have lost power. If none of them is the problem, then it must be a low voltage run.
  • Sebin Punnacheril
    Sebin Punnacheril Jul 07, 2010
    Do you hear any click sounds when you try to turn it on?
  • Sebin Punnacheril
I have hooked up my tivo and cable box but can't get my dvd player or wii to work with my cs-35405. I can not afford a tv now so please help.
You may have to hook up the DVD to the inputs on the front of the TV. If there are not enough side or front inputs, you may have to run the game through the DVD player, if it has inputs.
Dec 09, 2014 | Mitsubishi CS-35405 TV
Green power light
This might be due to a problem related to the SMPS (Switched Mode Power Supply) overcurrent / overvoltage dectection circuitry. When an overcurrent or overvoltage condition is noted the SMPS's shutdown circuit will turn the tv off. An over current condition can and most usually is caused by a component overdriving which causes an increase in current requirements for the power supply which in turn causes the shut down of the TV set. In an overvoltage condition a component may not function as well as it should causing a high resistance and this hig resistance causes the voltages level to go up causing the over voltage detector to activate shutting down the TV set.
The best this to do would be to take the set to a shop if you do not have a background in electronics.
I hope this helps,
Thank you,
Shuttle83
Nov 15, 2007 | Mitsubishi WD-62525 62" Rear Projection...
I have a Mitsubishi CS-35405. It has worked fine up until yesterday. When I turned it on the sound was fine but the picture is very blurred and the colors are pretty much all red and green. I tried the...
As old as this set is I worked on a lot of them.
Red and Green only?
These sets among other things with age develop bad solder connections: I suspect on the board that plugs onto the end of the picture tube you have some broken solder connections--the red, green, and blue video output circuit is there.
The really hard part with this set is just getting it apart--weighs a ton.
Let me know if I can help (not picking any set that heavy up).
Mar 31, 2012 | Mitsubishi CS-35405 TV
I have a Mitsubishi cs-35505 tv. This model is an oldie, from '96, but still works... kind of. The remote is not really functional, even with new batteries and the internal speakers got turned off. I...
If you feel the remote is bad, you will need to find a new remote. The best option here is to find the MCM Electronics website. They will have a brand replacement. Thanks for asking and show a few hands of support!
Mar 21, 2011 | Mitsubishi CS-35405 TV
Hi, I have bought an used Mistubishi CS-35405 TV a month back. The picture came in color for 1 week and after that the picture is coming in black and white. However the controls text like volume, menu and...
Hello Mr Kumar
According to you, there was colour displaying on your TV, and it has gone for now. It is now displaying picture in pure black/white also. Since black/white, picture is Ok, there is no problem to your picture tube. It now doesn't get chroma signals. That is the problem.
There are many reasons for this fault. The first one is related to Its RF stage, that is Video IF and Tuner stage. Since picture is correct in bl/wh, tuner has no problem. Your TV has PIP functions also. You just do this one first. Tune to a station with manual tuning, and advance the tuning process till the station goes out, and try to see, at any point during this process, you gets colour or not. If you get colour in this way, your TVs tuner has some problem. Before doing this keep the antenna corectly. If antenna is not in correct position this type of fault will occur. If these two won't help, the problem may be to its Chroma IC. If so this Ic should be replaced. You just do these things first and inform me about the progress through Fixya. I've its schematic diagram and can give you the number of Ics used in different stages. But I can do it only through Fixya. I can't send it to you diretly, since it is against our terms and conditions. Since the TV is a used one we don't know its present condition also.OK.
Oct 29, 2010 | Mitsubishi CS-35405 TV
How can you adjust the color?
On your remote control, press video, will give you options to adjust, press video until it gives choice of color adjustment, press video agiain for tint, pressing again gives you other picture choices.
Nov 28, 2009 | Mitsubishi CS-35405 TV
How to set inputs in Mitsubishi CS-35405
My cs-35405, only has input 1 and input 2, but has ant. A and ant.B So there are really 4 inputs. The input button on my remote, gives choice of these 4. Any vcr, dvd, cable or cable box, and satellite would be hooked seperatly on these. But to record TV, satellite or cable would need to go to recorder first and then toTV.
Jul 16, 2008 | Mitsubishi CS-35405 TV
My mitsubishi CS-35405
This condition can be easily fix by replacing and IC that is the vertical amplifier.
The number is something like LA7835 or LA7836, this IC is mounted on a heatsink.
Do a search in google for it.
Mar 01, 2008 | Mitsubishi CS-35405 TV
Cs-35405 Black Box
Go page by page with the buttons on front of set ....what
you are seeing is called a text box and it is part of the CC feature...use menu & up / down....left / right buttons.....T.
Feb 29, 2008 | Mitsubishi CS-35405 TV
Thin vertical line
What you have described is definitely some form of Electrical Interference. Interference can come from a variety of causes. Is the Cable Inputting the Cable Box close to some High Voltage Electrical Lines? Or Are you located near some Electrical Power Station? Or A Police station, where the Radio Transmitter of the Police Station causing the Interference? As I said, there are a variety of reasons. Also, Try to check if the connector is loose at the rear of the Cable Box, or at the rear of the TV. You will have to eliminate every possibility reason. Wish i could help further.
Jan 21, 2007 | Mitsubishi CS-35405 TV
Televison & Video Logo
35 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
