Question about Rowenta DG5030 Iron
Steam leaking from around the cap--Rowenta DG5030
Steam is escaping from around the cap. This is the second time this has happened to this iron. I called and ordered a small green rubber washer to go onto the screw cap...didn't work. Then I bought a complete new cap..it worked for about a year. Now, it is happening again. I bought another new cap, but it is still squirting steam when the cap is screwed on. This is a real pain because I iron a lot. I did notice that the black, flat, rubber washer that surrounds the base screw in part seems to be more worn on one side than the other. The metal receiving end of the screw protudes more on one side than the other. It seems to be in that area where the steam is escaping. Is there anything I can do to fix this myself? I don't want to ship this heavy steamer/iron. Jane
jaylex
  • 417 Answers
SOURCE: Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Posted on Feb 11, 2008
SOURCE: Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Posted on Sep 03, 2008
DiYerTech
  • 70 Answers
SOURCE: What happens if I use CLR in my steam iron?
The steam tank may not be heating because of mineral deposits in the tank. But also do this check first. Open up the tank reservoir cold, and drain all water out, (is it clean inside there when you shine flashlight in there? Rinse with clear filtered water only (low minerals).
Do not use CLR or anything agressive in there. You should have the main unit in full steam mode and the iron control also in full steam mode. Leave one tablespoon of water in the tank, put back together and let the pressure build. Put a clean towel on your ironing board and when iron is at full pressure and heat, hit the burst of steam and look at what comes out of the sole plate. If you see lots of white deposits look at the sole plate and see if the white chunks are coming out steam holes.
When using iron, run it till steam/water tanks are dry, the burst of steam is used in this case to clean the iron of all standing water. Pull the reservoir and allow to cool...once tank is cool drain it as well. Doing this several times should help purge unit of the heavy mineral deposits.
If you need parts, here is the Rowenta repair facility....
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Posted on Jun 06, 2010
heatman101
  • 43501 Answers
SOURCE: Rowenta Steam Iron DG5030; Iron drips water
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
kebah
  • 683 Answers
SOURCE: do you know where I
Hi there.
You can buy parts for your steam iron at http://www.rowentausa.com
Regards.
Posted on Jul 15, 2011
Steam comes out the filler cap on the water base on my Rowenta DG5030
WIre brush the caps screw threads and replace the O Ring ASAP.
DOn't use the iron until you get a new O ring and they need to be the orange/red rubber ones they are able to withstand the hot steam black o rings at home depot won't last.
Jul 24, 2014 | Rowenta Pressure Iron and Steamer DG5030
Fix rowenta dg5030
Send it in for repair.
Google Rowenta Repair Center
Jul 22, 2014 | Rowenta DG5030 Iron
The tank in my rowenta iron is producing steam but the iron is not producing steam
Yes the iron needs to be cleaned. They do have a descaler to clean. the Steam valve with a electronic switch is broken, that is what opens and lets the steam out of the iron when you press the button.
Google Rowenta repair Centers.
Jun 30, 2014 | Rowenta DG5030 Iron
Steam is coming out of water fill area
Where did you purchase a new cap, mine was accidentally broken and can't find a replacement.
Apr 22, 2013 | Rowenta Pressure Iron and Steamer DG5030
Steam comes out of the place where you put the water in
check the holes in the hot plate are not blocked with lime scale...sounds like you have a back pressure problem
Dec 29, 2012 | Rowenta DG5030 Iron
My rowenta dg5030 is leaking at the cap
My question is what is Rowenta doing about the gasket problem. Where is the replacement.
Oct 14, 2010 | Rowenta DG5030 Iron
No steam. I pressed the steam button on the underside of iron handle and no staem.
There 's a leaked capacitor in the circuit board. You just have to replace it and it works again.
Please visit the following page for detailed instructions:
http://thechipfreak.blogspot.com
Jan 15, 2010 | Rowenta DG5030 Iron
Rowenta DG5030 Iron Logo
461 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
