Question about Kicker KX600.1 Car Audio Amplifier
My kicker kx600.1 keeps turning on and off. The protection light switches with the power. How am i able fix this?
5 Suggested Answers
Icehockey35
  • 16 Answers
SOURCE: my protection light won't shut off on my kicker kx300.4 car amp
ground loose or unsecure...bare wires touching?
Posted on Jul 03, 2009
fixerdlt1
  • 18 Answers
SOURCE: kicker zx 1000.1 green light flickers and no sound
The first thing I would suggest is to check all connections to the amp and speakers, especially the ground. A loose ground can cause the problem listed. You can test this by temporarly running a ground from the amp to the battery neg. . If the amp fires up ok then that means your grounding point for the amp should be checked and cleaned and reattached firmly. If you have a meter(multitester) set it to ohms and check the impedances of the voice coils in the woofers. If one is cooked it may be shorted and tripping the amps protection. Always hook thing up with the sys off and then turn on and test.
Posted on Jul 22, 2009
Professor_V
  • 92 Answers
SOURCE: my protection light will keep turning on and off
THE GOAL HEAR IS TO DETERMINE IF THE INSTALLATION IS CAUSING YOUR PROTECTION FAULT OR IS IT THE AMPLIFIER ITSELF HAVING INTERNAL DAMAGE. REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION, THEN THE AMPLIFIER WILL NEED TO BE SERVICED, AS YOU HAVE TOTALLY SIMULATED A BENCHED CONDITION THAT IS TOTALLY INDEPENDENT OF YOUR INSTALLATION. MOST TIMES, THE AMPLIFIER WILL GO INTO PROTECTION WHEN IT SEES AN EXCESSIVE LOAD WHEN TURNING UP THE VOLUME, WHICH IS USUALLY CAUSED BY TOO MANY SPEAKERS OR DAMAGED SPEAKERS, BUT IF NO SPEAKERS CONNECTED, THEN IT IS USUALLY BECAUSE THE AMPLIFIER SEES AN EXCESSIVE LOAD OR DC OUTPUT DUE TO ITS OUTPUT SECTION BEING DAMAGED. IN ANY CASE, ONCE REPAIRED, YOU MUST CHECK YOUR SPEAKERS FOR BURNED VOICE-COILS, WHICH WILL IMPOSE AN EXCESSIVE LOAD TO THE AMPLIFIER AND CAN CAUSE IT TO FAIL AGAIN. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Posted on Jan 15, 2010
  • 41 Answers
SOURCE: Protection light keeps flashing on and off
try hooking up only the power ground and remote see what happens if protection light is on then u have a problem with amp if it goes off then hook up rca if still off then hook up speaker wire if it turns on then u have a prob with speakers
Posted on Feb 03, 2010
Testimonial: "Thanks, it's the speakers the amp is to powerful for the rated subs."
Kicker kx850.4 protection light stays on know power light
Check power make sure you have solid 12 volts. Disconnect speakers, shorted speaker can cause protection mode to engage. If still in protect mode will need to repair. Kicker does out of warranty repairs on kx series amps or try T.I.P.S contact at linearpower.com. Iirc Ray @ tips was one of the engineers at kicker back when kx series was introduced.
Jul 19, 2016 | Kicker Car Audio & Video
Kicker amp powers no audio all connections made properly
Is this the first time installing it or have you had it a while and it suddenly stopped playing ?
Aug 07, 2011 | Kicker Car Audio & Video
I have a kicker amp and my power light will come on once the music starts but not even a full sec later it fades into protect mode den bak green den red it jus keeps rempeating itself kan u help me
Maybe theres a loose connection in the power ic. causing the vivration of the casing when you on the volume control. you need a qualified technician to fix your problem.
Jul 02, 2010 | Kicker ZX10001 Car Audio Amplifier
My amp would turn on and off and one time it just stopped working its a powerful amp want to fix plz.help
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Contact Kicker to have them repair. .A thumbs up would be greatly appreciated if this answer is helpful to you.
May 20, 2010 | Kicker KX500.2 Car Audio Amplifier
Feb 02, 2010 | Kicker ZX10001 Car Audio Amplifier
Hi. I have a Kicker amp KX1200.1 that doesn't seem to be working. I think it blew a fuse. Do you know how I can get that fixed?
You should have an inline fuse (external) at the amp and one at the battery. There are not fuses on the amp.
Jun 25, 2009 | Kicker KX1200.1 Car Audio Amplifier
Red light keeps flashing..
my kicker was doing the same thing, and come to find out the power was loose,
1.check power connection,
2. check ground
3. check remote wire.
4. check that your amp isn't mounted on -metal-
5. check your fuses onboard the amp,
6.check you speaker wire
7.check your rca jacks
8. check that your gains aren't too high for the wattage
May 12, 2009 | Power Acoustik PS2-1250 Car Audio...
Kicker kx 800.4
Generally, if a Kicker amp has the power light lit and the protection light isn't lit, it's working. Are you sure that you have signal feeding the amp?
Are you sure your speakers are OK?
Nov 04, 2008 | Kicker KX800.2 Car Audio Amplifier
Kicker KX600.1 Car Audio Amplifier Logo
172 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
