Question about Kenmore Dishwashers
Kenmore dishwasher clean light blinks
Kenmore dishwasher model # 665.16033400 The clean light will blink 7 times. The owners book said there is a problem with the heat circuit. I checked the element it was bad I replaced it but it still blinks and will not run.
    Prodigy:
    An expert who has answered 500 questions.
  • Kenmore Expert
  • 646 Answers
Ah, the famous (or infamous) Clean-light-blinking-7-times problem. That is the code for "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff, a bad controller, or the 2 switches inside the door latch are not getting engaged fully.
Most of the time, I find that the cause to this problem deals with the latch, or the switches in the latch. If something (like a soda) gets spilled into the latch, it can cause the plastic parts to stick and not slide to engage the 2 door switches. You might need to take the latch out (unplug the dishwasher first!), remove the switches, and clean the plastic parts with water, dry it, and then re-assemble. The other thing to check is the door strike, which is supposed to push down the latch. The springiness of this metal part may be weak. You can remove it (without pulling out the dishwasher), by using a small screwdriver to release the little catches on either side of the "tongue" or "tang". Bend the center part down slightly more to give it more force, and then re-insert it. Then run the diagnostic cycle (by pressing the following sequence of keys: Heated Dry - Normal - Heated Dry - Normal; or High Temp - Air Dry - High Temp - Air Dry; or Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or High Temp Wash-Heated Dry - High Temp Wash - Heated Dry), let it run for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error.
Posted on Dec 16, 2014
  • 45 Answers
The computer needs to be reset. you may need to check the tech sheet that should have come with the dishwasher ( usually behind the toe panel) for directions on reseting it. If you cannot find the reset directions, let me know, I will have to look it up. thank you.
Posted on Jul 07, 2010
Clean light blinking will not start
Count how many times it blinks before it pauses and repeats. If it's 7 times, then it is a very common problem, and you can find the solution by searching for "dishwaser clean light blinking 7 times".
Nov 03, 2014 | Kenmore Dishwashers
What does it mean when my clean light blinks but I cannot cancel or reset it
Ah, the famous (or infamous) Clean-light blinking problem. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff, a bad controller.
Jul 21, 2014 | Kenmore Dishwasher With Ultra Wash And...
I have a kenmore Utrawash dishwasher and the clean button is flashing
Jul 19, 2014 | Kenmore Dishwashers
What is making my kenmore dishwasher blink clean?
That blinking light is trying to tell you that there is something wrong with your dishwasher. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff device or thermostat, a bad controller, or a problem with the door latch and/or switches.
Jul 06, 2014 | Kenmore Dishwashers
What to if the clean light is flashing and dishwasher will not start
That blinking light is trying to tell you that there is something wrong with your dishwasher. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff or thermostat, a bad controller, or a problem with the door latch and/or switches.
Jul 06, 2014 | Kenmore 24 in. 15079 Built-in Dishwasher
Kenmore Dishwasher clean light blinks
This is due to a problem with heating of the water. I have put together some instructions on what to do and how to reset the control so you can use the dishwasher. Follow the link below and let me know if it works for you.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 07, 2010 | Kenmore Dishwashers
Kenmore ultraclean \dishwasher\model 655.16033402
if it blinks 7 times. there is too cold coming in. if not ur heater is faulty. theres a heater kit for this problem that comes with a board.
Feb 06, 2010 | Dishwashers
Kenmore dishwasher
thers atech sheet located behind the lower acess panel, in that sheet you find your problem listed and how to reset the control.
Oct 29, 2008 | Kenmore Dishwashers
Dishwashers Logo
166 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
