Question about Mr. Coffee 12-Cup Programmable Coffeemaker
Clean light keeps flashing after I have cleaned it 3 times
It is driving me nuts
    Genius:
  • 1,970 Answers
Mcdevito75 here, If there is a reset on the control panel press it. You can also try to un--plug the unit from the wall socket for about 1 minute then plug it back in and see.
Posted on Jul 07, 2010
CT61 Key Panel Power On And System Ready lights keep flashing
1) replace the batteries by the same type alkaline, clean the contacts batteries.
2) adjust the REED switch, see the diagram attached, clean it, and tight the plug or connector well.
3) tight the ribbon cable for keypads, clean it, and tight very well.
see the block diagram
God bless you
Oct 17, 2012 | Horizon CT61 1.75 HP Digital Drive Motor...
"Clean" light keeps flashing. Machine doesn't
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Kenmore Dishwashers
The clean light keeps blinking and the dishwasher will not turn on. have tried to push cancel which makes the clean light blink faster.
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
Kevin
Apr 16, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
The clean light keeps flashing, and we cant cancel the program or get it to wash
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Dec 14, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
May 23, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
The cleaning button keeps flashing after cleaning. I have cleaned this with water & vinegar several times, but can only make one or two pots of coffee before the cleaning button begins to flash again....
We have this problem as well. We simply clean it as directed once or twice with the vinegar and water mix and then unplug for an hour. This resets our machine for several weeks. Based on the number of comments I've seen on this issue, it seems that the "off" sensor doesn't work.
Oct 10, 2009 | Cuisinart DCC-1200 Coffee Maker
I have a whirlpool Quiet Partner I. HELP Drain light flashing
This may or may not help in your situation, but the following link explains how you can clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this fixes your problem.
Jul 11, 2009 | Whirlpool DU1055XTS Built-in Dishwasher
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Filter light keeps flashing
The light flashes after a certain amount of run time. It is a reminder to check the filter to see if it needs cleaning. Once you have checked/cleaned the filter and reinstalled it, press the filter button for 5 seconds and the light should go out.
Jun 18, 2007 | Whirlpool ACQ158XP Wall/Window Air...
Jet clean system will not clean.
I had the exact same problem. Then I put more solution in so that it was just above the MAX line and it worked fine. So make sure you have enough cleaning solution in the system and it should work great.
May 20, 2007 | Norelco 8160XLCC Electric Shaver
Mr. Coffee 12-Cup Programmable Coffeemaker Logo
200 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
