Question about Acer Aspire 7520-5757 Notebook
Aspire 7520-5757 will not power on. How can I fix it? Is there a hard reboot that I can do?
  • 942 Answers
Yes there is. Ill teach you how. Turn off your pc, remove the cables and battery. Then press and hold the power button for 8 seconds. Reinsert the cables and battery and turn on the pc. Check the lights on the keyboard if it still on. If it is not, then the problem might be the internal power supply inserted on your laptop or the motherboard itself which is situated inside of your laptop. If you do not know how to reseat or remove the parts of your laptop, then call ASUS for possible repair of it. Bonafide ASUS technicians will handle your concern...
Posted on Jul 07, 2010
How do I fix this problem.my Acer aspire 5536-5224 laptop monitor is black. I;ve tried doing the hard reboot by disconnecting power cord & battery, but no fix
Do you get a picture with an external display? If yes the screen is faulty, replace the screen. If no, the GPU has issues.
Jul 31, 2015 | Acer Computers & Internet
Acer aspire 5552 completely dead no power lights or nothing, my charger works fine.
Please remove your hard drive and reboot your laptop. If your laptop displays the BIOS screen, then your hard drive is dying or dead. Also, unplug the main battery to test it.
Feb 28, 2014 | Acer Aspire 5552-3691-24271 Laptop
My Acer Aspire 5920 does not start up after pressing the power button, nothing on the screen at all. However the lights are flashing. Before this problem, the screen froze when I was using it. What's the...
Possibly a RAM issue or errors on the hard drive stopping the display driver from working properly. Remove power sources, remove RAM and hard drive. See if you get a display when the power adapter is reconnected. If you do, remove power source and fit RAM, (if not motherboard may be faulty). Repeat and if still working, remove power, fit Hard Drive and boot again.
Assuming your OS is Windows Based;
Reboot and use safe mode run CHKDSK/F and when finished check the drivers.
Feb 04, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have an ACER Aspire 5100 purchased in February 2007 and for the past two weeks it has been giving me trouble to load. I have to constantly restart or shutdown the computer for it to load properly. Any...
There are many details missing here but 1st
1. you may have a hard drive issue / the hard drive may need to be defragmented
2. You may have a power supply issue not enough power to power the mother board due to a failing power supply
3. your system may be set to sleep mode.
these are a few things to check.
More information is need to give a more detailed response to this issu
Oct 05, 2010 | Acer Aspire 5100 Notebook
What button to press to reboot laptop acer aspire 2930
You turn it off ...then back on to reboot.
click the start button - select turn off computer
Mar 24, 2010 | Acer Aspire 2930-4661 Notebook
Black screen after turn on
That "Blue Screen" is also known as "Blue screen of Death".
The problem is due driver compatibilty or unstablity.
Try to boot your system to "Safe Boot" by pressing F8 during startup.
Select "Last know good Configuration that works"
Check if it can take you to desktop.
Unstalled the wi-fi driver and reboot.
If the above procedure fails, again
Select "Safe boot"
Now create a restore point  and download the lastest version of your WI-Fi driver and installed.
This should work fine.
Otherwise Backup all your important data from your hard drive (mainly opearting system file installed drive usually C:\) and go for a new Installation.
Dec 28, 2009 | Acer Aspire One PC Notebook
Acer aspire 3680 can't find op system
THE CMOS BATTERY IS BAD REPLACE IT AND REBOOT SYSTEM.
THE SYSTEM DOESNT SEE A HARD DRIVE, CHECK THE CABLES TO THE HARD DRIVE CHECK THE POWER CONNECTIONS
FILL THE HARD DRIVE SEE IF YOU FILL MOVEMENT, IS IT WARM,
POWER SUPPLY MAY BE ANOTHER ISSUE
NO OPERATION , NO SYSTEM, NO CONFIGURATION, CMOS CLEARED, POWER SURGE, LOSS OF POWER,
ROD
Jan 11, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 5315 won't boot, black screen
I had the same symptoms on friends laptop. She had nothing to lose so gave me carte blanc.
Took out battery (to eliminate as problem) plugged in power, and powered up
Power light OK, HD flashed, CD flashed, then black screen. Powered down.
Did the following:
1) took cover off of fan/circuit board (see http://www.insidemylaptop.com/ for details). (4 screws)
2) take out fan (3 screws) and find huge amount of gunk on cooling fins at fan disch. Blew out with compressed air. Also cleaned fan blades.(reboot shows didn't fix.)
3) Repeated step 2, Pulled out memory sticks and cleaned terminals by rubbing with lint free cloth. Replaced memory sticks.
4) System boots normally. Replaced battery. Boots normally.
DAMN I'M GOOD!
Jan 05, 2009 | Dell Latitude D600 Notebook
Acer aspire 5o5o
what do you mean about rebooting ? acers are quite the hardess things to reboot when promblems arive .... you mite try going to
push F2 set go to bios and go to boot tab follow instrutions on rebooting with hard drive or dvd or hard drive what ever you have avaiable ... if nothing is stated then this mite mean your hard drive has taken a dive and you mite need a new one please email me back ok linda
Apr 18, 2008 | Acer Aspire 5100 Notebook
How do i reboot???!!!!
Hold down the power button, Its a universal force shut down. The power up again.
Jul 02, 2007 | BYTECC Black Aluminum Backup/Reboot...
Acer Aspire 7520-5757 Notebook Logo
249 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
