Question about Linksys Wireless-G WRT54G Router
I'm trying to secure my wireless connection - Linksys Wireless-G WRT54G Router
  • 2,260 Answers
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Posted on Jul 11, 2010
  • 65 Answers
Step1: Login to the router page.
Step2: Click on wireless on top second option.
Step3: Put your SSID(which would be the name of your wireless network)
Step4: Select the channel as 1,6 or 11 for greater range.
Step5: If you want the SSID to be broadscast(that means everyone withing the range of the router can see the SSID.) then check it as enable, else disable.
Step6: For putting security click on the "wireless security" option just below the wireless and select your option as WEP (as it is a easy way of encrytion) and than put your password.
Let me know if that helps.
**If this works please rate else let me know in case of further help.**
Posted on Jul 07, 2010
Trying to connect my ps3 to my wireless router. Error code after automatic access connection says no connection.
PS3 is not finding your router.
Make sure you choose wireless network under network settings and choose scan for wireless network.
Make sure SSID on router is broadcasting and not hidden.
Make sure router is broadcasting in G or MIXED mode.
Try removing wireless security on the router (open mode) and testing to see if connection can be made.
If connection can be made without security then try with security on.
Place ps3 closer to the router or connect with ethernet cable to verify connectivity.
Verifiy router is working by connecting a laptop or other device to the internet/router.
Mar 05, 2011 | Arris SURFboard SBG900 802.11g/b...
We have a Zyair B-3000 wireless network. With our older Notebooks (XP or Vista) the wireless communication is no problem but with newer computers I can't establish a wireless connection (e.g. HP Pavilion...
To trace the problem, I would first temporarily turn off security on the ZyAir B-3000 and see if you can connect with the iPad and the HP.
To do this login to the ZyAir. If you still have it set to factory settings you would login by clicking here: http://192.168.1.2 then type the password which is 1234. The find the wireless security screen and turn off WEP security. By the way, If you still have factory password, I would change that soon.
Here is the users manual with more details: ftp://ftp.zyxel.com/B-3000/user_guide/B-3000_3.50.pdf
After turning off all security, try and connect from the two systems that cannot connect. If you can then the problem most likely has something to do with wireless security. Now with the security still off try and connect with the other 2. If all 4 can connect without security turned on it is probably a wireless security issue. You could try changing from WEP to WPA security and see if all 4 can connect. You do not want to run your wireless router without security so make sure you turn the security back on..
I say most likely it is security, because maybe there are some settings that might be blocking the iPad and HP from connecting. Maybe the router is set to only allow two connections, or is set to allow specifc MAC addresses of the two older computers. Look around the configuration firmware in the ZyAir and see if there are any settings that would limit how many can connect wirelessly, or limit specific systems to specific MAC addresses.
After spending too much time on this and it still doesn't work, then you might consider doing a factory reset. Beware that a factory reset will wipe out all the configuration on the ZyAir and you will have to reconfigure. Instructions to factory reset are in the users manual link above, but basically you hold the side RESET button for 10 seconds, it will restart and you don't touch it till it is done resetting. If you do decide to do the factory reset, then right after resetting and before setting up security on the ZyAir I would try and connect all 4 systems at once. If that works then configure the ZyAir with security.
Dec 20, 2010 | Zyxel ZyAIR B-3000 (C46104) Wireless...
MY PS3 WILL NOT CONNECT TO MY WIRELESS ROUTER DLINK 615, everythink else does.
This will connect for the following reasons:
1. Check if the wireless security key is correct.
2. The wireless security key is at times case sensitive.
3. Try and connect to your own wireless network
4. Finally, check with other wireless devices at your place, if they are connecting.
5. If the security is high, lower down the wireless security type to 64-bit WEP
For verifying all this, contact your router vendor.
Thanks for asking.
Arvind S Iyer
Oct 17, 2010 | Sony Playstation 3 (PS3) Console
I want to secure my wireless conection
to secure your wireless register for www.opendns.com it can help secure your router wireless internet try it now
Jun 18, 2010 | Linksys WRT160N Wireless Router
Unable to get wireless access to internet on ps3, keep getting a connection error DNS 80710102 or 800100A, can you advise how to resolve?
Try to disable the security key of your wireless router in the meantime and try to connect your PS3 without the security turned on. If it connects, what you have to do next is to reset or generate a new security key on the wireless router and setup the PS3 - wireless network connections with the new security key.
May 26, 2010 | Sony Playstation 3 (PS3) Console
Set up wireless security, now no ethernet connection with router
first try to repair your connectivity under network settings.If this doesn't work unplug both the power supply and router for a minute, plug them both back in and restart your pc. Let me know if this works.
Dec 26, 2009 | Linksys Wireless-G WRT54G Router
I can't connect my ipod touch to my wireless network via my belkin router even though it says its connected
try disabling security in the roter and try to connect via wireless or try with 64bit wep security and change the ssid of router u will get connected
Dec 09, 2009 | Belkin (F5D7231-4) Wireless Router
Cant connect to secured wireless network...
Hi Grant,
If it says aquiring acquiring network connection while you connect to the wireless network it means that something is conflicting with the wirelss network, so first you have to check wether 2 wireless utiliies ( windows wireless utility and dell utility )are active at the same moment, if yes disable one of them and try again, still if it does not connect, disable antivirus and firewall and check if that fixes the issue, still if it does not work then try changing the security type on the routers page, basically this should work out and still if u have any issue, please reply to this msg for further troubleshooting steps....
And even if it gets resolved please reply once.
Thanks and Regards
Anup
Apr 01, 2009 | Dell Wireless 2350 Router
Router (WGR614v6) Secure Connection Issues
you need to remove the connection saved.
after securing the wireless router, before you try to connect. Go to
-Control Panel
-Network Connections
-Right Click your Wireless Adapter
-Click Wireless Network Tab
-Remove The Network
Then Try to reconnect.
Feb 11, 2009 | NetGear WGR614 Router
WPA for linksys
I would guess you are entering something incorrect with your security. If the wireless adapter on your XBOX wants a WPA then the wireless it is picking up has security on it however, it may be incorrectly set using WEP or WPA radius. Here is what *I* would do. Log in to your wireless router and remove all security. Go back to your XBOX and look for the signal for your wireless network. Now try to connect. Wireless connections can be a pain to configure sometimes but start first with no security and work yourself up. IF you can't get it working with security, make up a goofy SSID with NO security but don't broadcast it then you can connect the manual way through your XBOX specifying the SSID (not broadcasted) and no security that should do it. (Just a side note for my XBOX I bought a cheap Belkin 4 port router made it an access point for my existing wireless network and hardwired my XBOX to it. Works fine.)
Jan 23, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
Linksys Wireless-G WRT54G Router Logo
53 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
