Question about Canon imageCLASS MF3240 All-In-One Laser Printer
Canon MF3240 all the lights are ON
On my Canon MF3240 Multi-function printer, all the lights are ON (Processing Data, Copy, Scan, Fax & Error), and No errorcode display. Please advise how to fix it...
  • Canon Master
  • 4,737 Answers
First try the following tips..;
Remove all the cartridges, turn off the printer, disconnect the cables like usb, ethernet, power cable, leave it Off for few minutes (5 mins min.). Clean the contact points on the printer and on the cartridges using a small ball of cotton dipped in alcohol/spirit/acetone.
Now switch on the machine only with the power cord connected to it. Leave it On for few minutes, and then put it Off.. Connect the usb/ethernet and again power it On while you keep pressing the power button and the cancel button.
Install the cartridges and check whether this helps or not [you also need to check drum's "waste ink tank", if it's full, remove the waste ink and do some possible cleaning with it].
If the above tips don't help, you need to call for a Service from the Canon, there must be a fatal system failure with the Machine.
I can only wish you good luck for now.
Thanks for using FixYa.
Posted on Jul 07, 2010
  • usrichinta Jul 09, 2010
    Hi ,
    Your solution did not work. I tried all the steps you have mentioned and still all the lights are on the panel.please suggest.
    thanks,
    Uday
  • Lebanon Raingam
    Lebanon Raingam Jul 09, 2010
    Well, now, remove the drum and all the cartridges after that power on the printer without anything installed, leave it for few minutes and watch what error message you can see. If you can't see any error message like "Insert Cartridge" or "Insert drum" etc ... etc.. then there's internal mechanical problem with the printer/machine which will not be able to fixed without the qualified technician from Canon. You need to call the Service Center for servicing so that they can inspect it personally. Possibly the board could be the culprit, in that case, it'll be hard to get it repaired since most printers have not spares available in the market, never you can give a try, and perhaps, they could provide other alternatives.
    If you see any error message, firstly please install the drum and then reboot the machine again, check the error message, Is it asking for cartridges? then install the cartridges one by one and check the error messages every time you install a cartridge. If you see no error messages when you install a cartridge, then remove and skip that rather install another. You better try with another cartridge when you see an error in place of the one you just installed. If this is the case, definitely your problem will be fixed after you replace the faulty cartridge.
    On the other hand, your only option is call for Service.
    I wish you Good Luck.
I have problem in mf3240 canon priter showing E-225
Faulty CIS (contact image sensor) or the flat cable connecting the CIS to the PCB. Error only appears when you scan/copy/fax. But printing function I guess is normal.
Sep 29, 2014 | Canon imageCLASS Office Equipment &...
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Canon MF3240 firmware update failure
YOU THEN NEED TO REINSTALL IT BECAUSE YOU CANT ROLL BACK THE FIRMWARE
Mar 29, 2012 | Canon imageCLASS MF3240 All-In-One Laser...
I need to know how to get my imageclass mf3240 to scan.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=124&modelid=12943#DownloadDetailAct
Download & install the latest software for your printer.
Feb 05, 2010 | Canon MF3240 imageCLASS Laser...
I have a Canon imageclass MF4150 Printer with startup issue
Try in service mode ( add.function & #) then clear all, if not try to switch over every conector on the Main PCB board.
Jan 12, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
My canon mf3240 printer jamed, then a b5 paper size error message
You must be set you machine from program key
1> press menu>paper size>A4/Letter/set OK
after print or copy your requirement size.
Dec 12, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
CANT SCAN ON X64 BIT WINDOWS VISTA FROM CANON MF 3240
Spend a little money and buy the upgrade to Windows & 64Bit. If you have more than one computer buy the "Family Pack for $149.00 you get 3 licenses for 3 pc's.
Apr 11, 2009 | Canon MF3240 imageCLASS Laser...
Data processing light keeps flashing in fax mode
Unplug your USB cable and the fax should start working. If this fixes the issue, it could be a problem with your USB cable or hardware.
Mar 06, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
The printer prints from the PC but will not copy without the PC
Please reset your printer to factory defaults form on screen printer menu > > >
Dec 31, 2008 | Brother Multi-Function Center MFC-240C...
Canon imageCLASS MF3240 All-In-One Laser Printer Logo
65 people viewed this question
old marine
old marine
