Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
I have a kenmore refrigerator side by side about ten years old . works for about acouple of weeks fan motor shuts down coil freezes up in freezer compartment unplug uniy for aday plug back in fan turns on and unit will run for acouple of weeks
  • Kenmore Master
  • 17,970 Answers
There are many reasons for this problem. Here are a few common reasons. You may need a tech to determine exactly which part is at fault.
Defrost Problem
Modern refrigerators are designed to self defrost and it is essential to the airflow to have an evaporator coil that is clear for air movement. If the rear interior panel of the freezer has frost appearing, it is most likely a defrost problem and must be corrected before temperatures can be restored to normal.
Dirty condenser Coil
Check the condenser coils for lint and restrictions. It is located underneath the refrigerator and accessible from the rear. A dirty condenser coil will result in poor cooling, especially in the freezer.
Faulty Condenser Fan Motor
The condenser fan motor is found under the refrigerator near the compressor. This motor is essential to proper cooling. If the fan motor is not running, there will not be proper heat removal from the condenser and the result will be higher than normal temperatures in the freezer and usually in the fresh food section. Ensure the fan motor is running when the compressor is on.
Low Refrigerant Charge
If the unit has a low refrigerant change, the freezer will not reach proper temperatures.
For check any parts replacement visit this LINK. Tell us news.
Posted on Jul 07, 2010
  • kozboys Jul 08, 2010
    this is koz boys refrigerator is maintaining temp everything is clean . fan motor on condenser works fan motor on frezzer side is the fan that some times shuts off and then does not come back on . its been two days now that the refridggerator has been working. i am wondering if when it goes into defrost and when it comes out of its cycle why does the fan sometimes does not start up
  • ZJ Limited
    ZJ Limited Jul 09, 2010
    There are many separate
    components in a refrigerator's defrost system that must work in consort
    for a frost free system to work properly. We will attempt to explain the
    workings using simplified electrical schematics.
    The heart of the
    defrost system is the defrost timer. The timer is a motorized device
    that opens and closes electrical contacts. Each contact can be thought
    as a light switch, one controls the defrost cycle, the other the cooling
    system. When one of these is switched on, the other is switched off. A
    motor on the timer (NOT illustrated) turns a cam that opens and closes
    these contacts at set intervals (see below for other types).
    The defrost timer eventually
    switches into defrost mode and supplies power to the defrost heater(s)
    to melt any frost that has accumulated on the evaporator (cooling) coil.
    The cold control
    contacts remain closed but since the defrost timer is no longer feeding
    power to that circuit, the compressor does not run.
    Once the defrost termination
    thermostat (a.k.a. defrost limit switch) senses a set temperature, it
    opens the circuit to the defrost heaters, shutting them off. The timer
    remains in the defrost cycle until the timer advances back to the
    cooling mode. Since the limit switch is open, the heaters are no longer
    on for the rest of the cycle.
    Keep in mind that, normally the interior
    evaporator and exterior (if present) condenser fan motors should run
    whenever the compressor is running and vise versa. If the timer is
    stopping operation of the cooling system, neither the fans nor
    compressor should usually be running at that time. Its possible that you have the problem there.
Freezer is causing fridge contents to freeze..... cont.
Do you see any ice buildup on the back wall of the freezer?
Oct 21, 2012 | Maytag PTB1954GR Top Freezer Refrigerator
2 year old Kenmore side by side refrigerator is too warm
the freezer feeds the refridgerator with cold air,when you open the freezer door,do you hear the fan blowing,if not you need to change the evap fan motor,next take out the second from bottom food bin and touch back wall,if you feel snow or ice you have a defrost problem, you'll have to take off back wall,advance the timer till it clicks into defrost and see if the heater comes on,if so you have a bad timer,if not read out the t-stat and the heater,if there are plug in wires on t-stat unplug them and bypass the t-stat by plugging t-stat wire to heater if heater comes on change t-stat,leave the heater on to help you defrost the ice off of evap coil and use hair dryer to melt ice,hope that helps
Nov 02, 2009 | Kenmore Refrigerators
Fridge and freezer are not cooling well
hi.
If the evaporator fan isn't working, that's probably the problem. Test here>http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
thank u
rate me!!
Jul 20, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Will not cool proper on fridge side
THIS IS A DEFROST PROBLEM EITHER THE THERMOSTAT OR DEFROST TIMER IS BAD! THE THERMOSTAT IS LOCATED BEHIND THE WALL IN THE FREEZER COMPARTMENT ATTACHED TO THE COILS TO KNOW IF ITS BAD IF WILL HAVE A RAISED SPOT ON THE BACK LIKE ITS BUSTING OPEN CHECK THAT
Apr 27, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator and freezer not cooling/freeding
Possibly a defrost circuit problem -
1) Bad defrost thermostat
2) Bad defrost heater
3) Bad defrost timer
4) Failed evaporator fan motor.
Look for frost accumulated inside the louvers at the back panel, top and bottom. If you see it, remove food from freezer and put in ice chest. Take out shelves, get hair dryer and warm the backside of the freezer, directing air down the louvers. Then leave to sit for 4-6 hours with the freezer door open. Put towels in the bottom of the freezer to catch any melted ice.
After period of time, plug unit back in and power the unit back up. Once you know it's cooling, empty ice chests back into freezer.
If there is a problem in any of the above components, then it will show up in 3-4 weeks witht he same problem again.
Jan 29, 2009 | Kenmore 53642 / 53644 Side by Side...
Not cooling, ice on evap. coil
After ten years, the defrost coil may be bad. That will allow the evaporator to ice up. Find the defrost timer, check it out first. Some have a manual control.
Dec 21, 2008 | Kenmore 53642 / 53644 Side by Side...
Freezer is freezing up, then freezer and fridge warm up.
hi thanks for your question. you have a no defrost problem. the cheapest part to replace is the defrost termination switch. located in the freezer., its clamped to one of the coils by the fan motor replace this part. see what happens thanks the appliance doc
Oct 30, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore Refrigerator Freezing Up - Won't Defrost
i have a side by side kenmore frig freezer on th frig side the pop is freezing up and the water that comes out the door whtat could be wrong
Oct 12, 2008 | Refrigerators
Side by side works for a week, then freezer coils freeze up
defrost system problem tell me more,is the fan in the freezer working,can you find the defrost timer and put it in defrost?this way you can remove the freezer back panel and see if the defrost heater comes on,let me know what you find-mike
Oct 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Mar 04, 2008 | Kenmore 64823 Top Freezer Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
32 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
