Question about Canon Powershot A2000 IS Digital Camera
Lens shutter problem
When the camera is turned on the lens shutter opens partially. Lens error pops up. Then the camedra shuts off.
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Jul 09, 2010
I turned on my camera and I get an error message that says, Lens Error Camera will shut off automatically. Then the camera shuts off. The lens will not pop out?
Hi.
This problem occurs when there is zoom-block problem. The solution is to change all the zoom-block, but normally this is more expensive than a new camera.
This mechanism fails due to sand, dust or just useful life expired.
Aug 27, 2015 | Canon PowerShot A4000 IS Silver 16MP...
When trying to turn the camera on, the lens will not extend fully. it extends partially, and then the camera turns itself off, leaving the lens in the partially extended position. you have to try and turn...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 23, 2011 | FUJIFILM FinePix JX250 Digital Camera
The lens opens then closes then partially opens
Maybe some of the lens gear is broken . change the gear or lens will be ok .
Aug 31, 2009 | Casio EXILIM ZOOM EX-Z70 Digital Camera
Petax Optio E60 lens error of 0x15110000
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 13, 2009 | Pentax Optio E60 Digital Camera
Lens error
if the problem is due to the fact that u have dropped the camera on floor or put into water...then no other go you should change the whole lens array...contact your nearest service centre
May 13, 2009 | Nikon Coolpix S210 Digital Camera
Lens shutter does not open while lens pops out using new batteries
What you are seeing is not the shutter but a lens protector. I think the camear has dirt in that area and it needs to be cleaned out. Do this with compressed air.
May 02, 2009 | Cameras
Camera stuck in "lens error" mode
Hello, It's time to let a Nikon camera repairman take a look. If lens does not pop out, then it could be motor, shutter, etc, etc. Check out one of our Camera Repair providers and get a repair quote.
Nov 30, 2008 | Nikon Coolpix 4600 Digital Camera
IR-300 Olympus
I had what sounds like the same problem. The camera was dropped and the shutter was stuck open. Just kept showing error message.
As I felt I had nothing to lose I began tapping it on a soft book and the shutter started to appear. I then shut it just using the end of my finger. When I then turned the camera on again it opened and shut when turned off. It has worked fine ever since.
Seems a rather poor design.
Hope this helps. Very best regards Peat.
Jun 05, 2008 | Olympus i:robe IR-300 Digital Camera
Shutter having trouble opening and closing.
Hey SleepyFairy,
What it sounds like is that something sticky has gotten into the lens cover mechanism, and the only way to fix that is to have it repaired. If this camera is less that a year old it is most likely still covered under manufacturers warranty, and you should have it looked at by an authorized service technician to get it fixed.
Sincerely,
Allan
Go Ahead. Use Us.
May 14, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Canon Powershot A2000 IS Digital Camera Logo
82 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
