Question about Whirlpool LGR7646E Dryer
Dryer will not dry cloths
I have a whirlpool electric dry and 2 days ago I put a load of clothes to dry and left for about two hours. When I came home my dryer was still running. Now when I put a load of clothes in the dryer will not get hot and my clothes are not dry. I cleaned the lint trap and hose leading outside to make sure that it was not clogged. Could this be my heationg element or can my dryer be stuck in cool down cycle?
  • Dawn W Apr 19, 2008
    Thank you for your help. I checked everything with my voltage meter but as it turns out the last thing that I tried turned out to be what was wrong. It was a broken coil, but it was broken in a spot that unless you pulled on the coils was not visiable. Changed the element and I am now able to dry my clothes. Thank You again,
    Dawn W
  • sgrisham Apr 27, 2008
    I have the same with this dryer. It runs but their is not heat. I don't have the manual. Do you know how I can check to see if the fuse is still lit? Any other troubleshooting ideas (for someone that knows nothing about dryers and has no manual)? Thx
    Problem Solver:
  • 14 Answers
Did you check the relay switch?
Posted on Sep 03, 2008
    Genius:
  • 1,073 Answers
Make sure that the dryer has the proper voltage going to it and if it does then check the heating element and the safety on the left top of the element housing
Posted on Apr 19, 2008
Takes too long to dry clothes
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
I have a kenmore/whirlpool electric dryer that is not getting the clothes dry,it takes 2 1/2 runs to get them dry! the model# is LEC6848AQ1
Remove the exhaust vent on the rear of the dryer and run a load.
If it dries in 1 hour or less,repair the vent or the restriction in the vent.
Jan 25, 2011 | Kenmore Dryers
Why it take so long for my whirlpool dryer to dry my cloths. When I put in a load of cloths it take about (2) hours to dry. I feel the heat in the dryer, but it not getting hot enough. Could it be the the...
try running the dryer with out the vent hose hooked up.if the dryer works well than you have a blockage some were in the vent line.also be for you pull the dryer out,look behind the dryer to see if the vent line is kinked or massed together.
Jan 24, 2010 | Whirlpool LER4634J Electric Dryer
My dryer takes almost 2 hours to dry a normal load of clothes.
You have a clogged vent , or kinked vent hose , or the hose to the outside ( possibly in the wall ) , is clogged with lint . A dryer , either heats , or doesn't heat . The venting , is what causes the excess timing , for the clothes to dry .
Jan 01, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer keeps drying and getting too hot
Check the dryer vent .The vent is stopped up,in the vent,or in the inside of dryer,in the lint hopper.Clean it out and unstop the dryer,and the vent.
Oct 10, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool LEN100PQO electric dryer wont shut off/no heat
if your thermal fuse is blown you will not recieve heat. if you put your dryer on sense load it will keep running because it is not sensing that the clothes are getting dry which in return your timer does not
advance
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Clothes taking 2 hours to dry
Post your model number to any of these fine forums for
a simple answer that will save you lots of money:
http://appliancejunk.com/forums/index.php?referredby=858
http://forum.appliancepartspros.com/
http://applianceguru.com/
For Sublime appliance repair advice, simply written:
http://sites.google.com/site/sublimeappliancerepair/Home
Apr 09, 2009 | Dryers
Dryers Logo
281 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
