Question about Husqvarna Garden
Wont start has spark - Husqvarna Garden
  • Husqvarna Master
  • 1,807 Answers
Does it have good compression, is fuel getting into the cylinder.?
Posted on Aug 02, 2013
Weak spark
pull flywheel and replace sheer key on flywheel to get spark on time
Feb 23, 2014 | Garden
Wont start,,turns over,but no spark. wont even start with starting fluid
If there is NO spark then starting fluid cant start any thing. I would be checking the crank sensor first for the spark then the ignition coil pack.
Feb 27, 2011 | 1995 Oldsmobile Cutlass Ciera
Ran out of gas,put 4 gals in wont start tried starting fluied wont start
Sounds like the ignition system is not firing the spark plugs if starting fluid and gasoline doesn't solve the problem.
Verify by putting a spark tester on one of the spark plug boots and attaching the spark tester to the engine block or ground.
Dec 18, 2010 | 2006 Nissan Frontier
WONT START REPLACE ENGINE CARBRATOR ADPT DO TO BOLT BROKEN OFF STILL WONT START
Check spark plug. remove the spark plug, clean it and test it. If it still doesn't start, take the spark plug out, and connect it to spark plug wire and try to crank the blower, and see if it makes a spark, if not you may need to replace the spark plug.
Nov 04, 2010 | Craftsman 225 Mph Electric Blower Vac
MY 96 PONTIAC SUNFIRE 2.2LITER WONT START AFTER IT RAINS OR IT WILL STALL OUT AFTER BEING TAKEN THROUGH AUTOMATIC CARWASH ANY SUGGESTIONS ANYONE?? THANKS!
check spark plug wires and coils for moistore put some lube on the coil wires check for spark after it wont start if itll crank but not start its 1 of 2 thinks no spark or no fuel usally when the coils get too wet they wont allow spark to come through or will cause it to arc
May 07, 2010 | 1996 Pontiac Sunfire
Dakota wont start
your pickup coil could be the problem. not geting enough spark or sparking all the time
Apr 09, 2010 | 1996 Dodge Dakota
My 95 lexus gs 300 wont start
Try to replace the fuel filter and then check the spark plugs. Mke sure to clean the spark plugs and after you clean the spark plugs and still the same it wont start replace the spark plugs and check the distributor as well.
Feb 02, 2010 | 1995 Lexus GS 300
1989 Cutlass wont start
the filter on fuel pump might be clogged as well or fuel pump needs replaced
Oct 01, 2009 | 1989 Oldsmobile Cutlass Ciera
Moped wont start
is there a spark a decent one if not try changing plugs if still no spark it could only be the cdi,coil and magneto get back to me buddy
Sep 13, 2009 | 2005 Tomos Se 125 F
Blower wont start
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
Nov 28, 2008 | Echo Inc. 44 CC, Carb Certified Backpack...
Garden Logo
95 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
