Question about APC BX800 Back-UPS XS 800 (APNBX800) UPS System
My apc back-ups ups xs 800 cycles from On-line "green" to On Battery "orange" and beeps about every second. I replaced the battery about a year ago.
  • 5 Answers
SOURCE: apc xs 1500 overloads even with nothing plugged
Plz check MOSFET which working in inverter section.
Posted on May 12, 2009
virtualhost
  • 2185 Answers
SOURCE: My APC back-ups es500 is keep on flashing in orange and Green
Probably the battery is drained. You should charge it first. And if the problem still persist, it could be that the UPS battery needs replacement.
Posted on Aug 01, 2009
jvpacoin
  • 91 Answers
SOURCE: Overload light in APC RS 800 UPS
it seems that the inverter circuit of your UPS is dying. the solution here is you have to open up the UPS and check the inverter circuit. to make easier, check the power mosfet if its leaking.
Posted on Aug 14, 2009
JaxPlanet
  • 922 Answers
SOURCE: APC back-ups XS 800 battery backup : warning
Turn it off and unplug it from the wall.
Open it up and make sure that the red and black wires are connected.
If they are the battery needs to be replaced. They are only good for 2-3 years. If you are not comfortable with my instructions, call APC for free support. (800) 555-2725
Vote for this solution if it helps.
Posted on Aug 18, 2009
  • 84 Answers
SOURCE: In My APC UPS, continuous beep sound is coming
Unfortunately that signals an internal fault with the UPS and it requires immediate replacement / repair. Do not continue to use the UPS at all.
Posted on Mar 31, 2010
My apc ups 880va is not working online .what is the problem?
Have you change the battery? most APC ups just need to change the battery for it to work again.
Jan 20, 2013 | APC BX800 Back-UPS XS 800 (APNBX800) UPS...
Apc xs1500 beeps 4 times
Check if the unit has a breaker on the back and reset it. The unit doesn't seem to be getting power.
Dec 03, 2012 | APC 1500VA BX1500 8 Outlet UPS UPS System
Apc xs800 new batteries
I Bought two RBC32's and had to hook them up to the connector and did it wrong on the first try. Make sure you connect the yellow to the Red terminal on one battery and the Black on the other, then connet the remaining red to red on one and black to black to the other. Once I did that and plugged it back in everything worked fine.
Apr 06, 2012 | APC BX800 Back-UPS XS 800 (APNBX800) UPS...
My Apc xs 1300 keeps chirping. This happened after a power outage in our building. is the battery fried?
Replace the batteries. This will fix the problem. Call me at Gruber Power Services for Free tech. support. 800-658-5883 x256 ask for Eric
Aug 22, 2011 | APC BACK-UPS XS 1300VA LCD 120V...
Alternating green and orange light with constant beeps
Verify that the usb to ups cable is pluggled in properly. Also you may not have a good ground. Disconnect the ups and plug it in another outlet to test with nothing else plugged into it, to see if it still beeps. You can also try and upgrade the ups software from apc.com
Jun 25, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
The 'ON BATTERY' light goes on every so often and the unit beeps. Very annoying as this is not an overload so I want it silent.
Hello.
There might be several reasons for this:
1) Malfunction of your UPS' circuit
2) Damaged wire cord
3) The power on your wall socket fails too often
4) Most likely the batteries are exhausted. See the UPS' manual about batteries replacement.
Good luck
Jan 24, 2010 | APC BX800 Back-UPS XS 800 (APNBX800) UPS...
After a power outage my apc has this clicking sound. every 4 seconds or so it sounds like it clicks and then a slightly different click 4 seconds later. However, when everything is powered up it doesn't...
I found this on the APC website;
Question: What would cause a Back-UPS Pro, a Back-UPS Pro USB, a Back-UPS RS, a Back-UPS CS, a Back-UPS LS, or A Back-UPS XS to beep once every 5 seconds with no output power?
Answer: One beep every 5 seconds is an indication that the UPS has entered what is called "Low Voltage Sleepmode".
The Back-UPS product has transferred to battery power due to a low voltage condition at the wall. The Back-UPS has remained Onbattery until its runtime was totally exhausted, however, there was still enough voltage present at the wall to trickle charge the battery.
This is considered to be a normal operating state. When the voltage returns to normal the Back-UPS will wake up and restore power to the battery outlets.
Nov 02, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
Aug 15, 2009 | APC BX800 Back-UPS XS 800 (APNBX800) UPS...
My APC back-ups es500 is keep on flashing in orange and green having the beep sound, whe it is on. It has been used for nearly 3 years. What would be the problem...?
Aug 01, 2009 | Computers & Internet
APC BX800 Back-UPS XS 800 (APNBX800) UPS System Logo
273 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
