Question about Goodman GPC1330H21A Air Conditioner
Ac on blowing out room temp air
My ac
  • 674 Answers
First you should check your air filters and clean or replace if dirty. Next check the outside unit and make sure the fan and compressor are running. If they are not then make sure the circuit breaker isn't tripped or the fuses aren't blown. The circuit breaker or fuses should be located close to the outside unit. If you have power to the unit there should be an access cover you can remove to see the contactor. With the thermostat set to make the a/c run look at the contactor and see if it is pulled in. If it is then check the capacitor(s) for the fan and compressor. Let me know what you find and I can give you some more advice.
Posted on Jul 07, 2010
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
2001 Dodge Ram 1500 4x4 with no heat, no ac, blows room temp air on all fan settings
The upper passenger side firewall has a little black line passing through it . Usually it is broken. There is also a ball on the drivers side firewall behind the hinge
Nov 03, 2012 | 2001 Dodge Ram 2500 Truck
Just installed a GE ajcq12accm1 and it will only cool for about 5 minutes, then blows room temp air ........do you have any tips on fixing this...please ?
Besides calling out a certified ac tech. It may be the t stat set at a higher temp than actually is in room. (Calibration)
May 28, 2012 | GE Built-In Room Air Heat Cool Air...
Amana PTH153B50AM AC & Heat pump. fan works AC & heat don't. I was told by the guys who installed it to unplug it to reset the termostat but that don't work either. I turn it on cool &...
Jane, what you really need is the Owners Manual for you discontinued model AC/Heat Pump.
Call Amana Customer Support 1-800-843-0304 and they can furnish you one. Either by email attachment or by snail mail.
Hope this helps you. Please let me know.
Jun 20, 2011 | Amana PTH153B50AM Air Conditioner
Fan blows room temp air, I can hear the AC kick in but it only runs for about 30sec to 1min before cutting out and making a sputtering sound that shakes the whole unit. Then it just goes back to blowing...
check you condenser fan motor make sure it turns on, if ok you must clean the fins on the outside unit,with a water hose , make sure you turn power off first before taking a water hose to unit
Aug 30, 2009 | EdgeStar AP420HS Portable Air Conditioner
Unit not blowing cold air
you have a slow leak in your refrigerant and need to find the leak. you will have to get an AC repairman to come to your house and check it for leaks and fix the problem.
Jul 28, 2009 | Amana Comfort Zone 12M32PBEH Air...
My ac unit is working but the room is not reaching the desire
Is the condenser outside unit working. (Evaporator is inside the home.) If so you may be low on refrigerant. Have a qualified technician test it.
Jun 29, 2009 | Carrier 38CKC042 Air Conditioner
Improper Termperature Readings during AC run
personally i'd just replace the thermostat, but try pulling the front panel off and look on the circuit board and see if there is a jumper for F/C or any other settings. you may try changing its position. you can also remove the batteries for 15 minutes and see if it resets itself. the only other thing it could be is a wiring issue.
May 29, 2009 | Heating & Cooling
Ruud Heat Pump blows room temp on Heat and AC setting
A "Heat-Pump" is also known as a reverse cycle air conditioner, this means on heat the outdoor unit acts like the indoor section and vice versa. So in all probability you need to have it leak checked and recharged.
Apr 27, 2009 | Ruud UBHC Air Conditioner
Heater blows cold air ac blows warm air
Your problem is the air temp control blend door actuator is defective and not controlling temp u set. to change/access this part the dash assembly must be removed from the car.
Mar 24, 2009 | 1998 Ford Taurus
Goodman GPC1330H21A Air Conditioner Logo
172 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
