Question about Proform Exercise & Fitness
Proform 490gs treadmill works for about 5 minutes, then turns off. Fuse reset button on bottom will reset motor after a few minutes. Unit is plugged directly into wall outlet with no obstructions in the motor or belt.
    President:
  • Proform Master
  • 832 Answers
As the walking belt wears, it creates more friction with the deck which creates more heat in the belt causing it to wear further. Additionally, the increased friction requires the motor to work harder to keep the belt moving at the same speed. With this in mind, it causes the motor to draw more electricity and therefore, more power to move the belt. The motor has to get rid of this excess energy in some way so the way it normally does it is by releasing it in heat so that's why treadmills with belt problems typically overheat the motor too.
All of this to say that if the breaker starts tripping, you know that the belt is causing the motor to pull too many amps and the safety system is working as it should. If the breaker has tripped more than a few times, it will need to be replaced because the breaker weakens every time it trips. Additionally, the walking belt will need to be lubricated at a minimum and if you want to be very aggressive toward the symptoms, replace the walking belt. Silicone lubes, like water-based liquid silicone require relubing once every 30 days. Go to E Bay and you will see the different types and prices they will all do the the job. I would go down to the Hard ware store and purchase a 4 or 5 dollar can of silicone lift the one side of the belt and spray the length of the belt 3 applications on each side should to tell you if has taken care of the problem if not the belt and deck will need replacing.
Posted on Jul 19, 2010
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
Ipod speakers do not work on the Proform 490c treadmill
To use the music port for iPod, you need an iFit Universal iPod Connector To purchase an iFit Universal iPod Connector call 1-800-533-1333
May 04, 2010 | Proform 490GS Treadmill Walking Belt
How do you adjust the belt on a PROFORM,( Model #
Unplug unit then, using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Apr 21, 2010 | Exercise & Fitness
Incline does not work
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Mar 19, 2010 | Proform CrossTrainer Treadmill
Was just given a Proform 490GS. It has been
Clean item up real good with damp rag-not dripping wet-dust/dirt will hurt walking platform/belt. Icon.com
Icon is the manufacture located in login Utah. Manuals can be downloaded through internet with model# of item, thats located on a silver tag in frt on frame,or under walking platform/mtr hood area. Proform did make one style that the model# was underneth...but thats been 10yrs ago
Jan 06, 2010 | Proform 490GS Treadmill Walking Belt
Proform 400GI Treadmill making a very loud noise, which is worse when using speeds between 2.7 and 3.1, noise is so loud can't hear tv when turned up to full volume. It makes the noise without anyone...
This definitely sounds like the drive motor. One way to check is to remove the drive belt and run the motor without the walk belt connected. Obviously if you still have the noise it will be a motor issue. If not then it will be one of the 2 rollers. Good Luck! Tim
Nov 04, 2009 | Proform 490GS Treadmill Walking Belt
Proform 760 shuts off after running for 15 minutes. Needs to cool off before it can be reset
my wife has a proform 490gs that keeps shutting off after about 40 minutes by tripping the breaker. what is causing this.
Oct 30, 2009 | Proform 760 CrossTrainer Treadmill
Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Apr 14, 2009 | Proform CrossTrainer Treadmill
I lost the key of treadmill proform 490GS
call 1-800-999-3756 and please rate me great
Apr 06, 2009 | Proform 490GS Treadmill Walking Belt
Exercise & Fitness Logo
333 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
