Unit runs outside, but fan will not come on in the inside unit.
    President:
  • 1,561 Answers
there are two 18 gauge wires going to your contactor coil the two wires will follow your line set out of your house and into AC to the contactor coil. usually red and white. or blue and yellow. make sure you have 24 volts with your volt meter (T-stat must be calling for cool). make sure you have 240 volts going into line side of contactor(L1 L2). there should be a run capacitor or two. usually a silver duel capacitor it will be round. is it mushroomed at the top? do you have voltage on both sides of contactor and 24 volts to contactor coil when thermostat is calling for cool?. and no voltage at capacitor or it looks mushroomed, you have a bad capacitor. the best way to test one is with a mircrofared tester. less then10 bucks to replace it will have a number ie. 35/5 uf if it is a duel. make sure you get the same one. if you don't have 24 volts to contactor coil or if contactor isn't pulled in. your problem is in the t-stat or funace. if you don't have 240 volts going into line side of contactor you have a tripped breaker or blowen fuse somewhere, or high pressure cutout needs to be reset due to dirty condenser.(usually only on Rheems) if you have 240 at line side L1 L2 and 24 to the contact coil but no 240 on T1 T2 of contactor you have a bad contactor which i would replace anyways since it sounds like it's buzzing. they are about 10 bucks too. let me know if this helped i'm pretty sure it's your capacitor. the capacitor if it's a duel will have three different terminal circles. C, fan, and Herm. C is for common it goes to the common wire on the contactor either a red or yellow wire. fan uses the wire coming from the fan and herm uses the wire coming from the compressor.
Take care.
Posted on Jul 07, 2010
Icing up outside. no heat inside
Isolate unit to defrost out door unit,
Once defrosted run unit ensuring heat from unit inside and fans are running outside,
if fans and compressor are running and there is next to no heat inside coming from indoor unit this is a common sign of a refrigerant shortage in system and this may cause outdoor unit to freeze up
Jan 24, 2016 | Mitsubishi Electric Mr Slim E12C26426...
Why tempstar 5000 High Efficiency a/c outside fan won't turn off ?
Sounds like your contactor is sticking in your outside unit. They could be welded shut.
Jul 21, 2014 | Heating & Cooling
My ac unit outside runs when the tempeture gets above what it is set on, but the fan blower keeps going on and off. I switched the theromstat fan to on from auto and it does the same thing, on and off in...
the fan control is not for the fan on the top of your outdoor unit. that is for the blower, you have 2 fans. Im guessing you have a split system, 1 unit inside and 1 outside?? Does the outdoor fan continually run??
Feb 06, 2018 | Ingram GMS90904CXA Heater
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
Aug 30, 2010 | Heating & Cooling
Can i run the fan on my inside unit if the outside unit is not working
You should be able to run the fan on the inside unit if the outside one isn't working. If you're worried, turn off the circuit breaker for the outside unit. If you don't know why the outside unit isn't working, check the circuit breaker at the breaker panel, check the breaker inside the box that electrically connects to the outside unit, and check the outside unit for a reset button.
Oct 15, 2009 | Heating & Cooling
Nordyne AC unit works at first but later provided cool air. Thermostat set to 65. Power running to unit outside. Noticed ice around line outside and can send a picture. Chipped ice away. Want to know what...
If the inside fan motor is running OK you are low on refrigerant. If the inside fan motor is not running, repair the inside fan motor. Could also possibly be dirty inside coils.
Jul 20, 2009 | Heating & Cooling
A/C quit running
This question is really to broad to answer. There are several things that could cause it to stop running. I think I would turn everything off, let it cool down for several hours and try it again. When you kick it back on, take note of what is running and what's not running. Inside fan, outside fan, compressor. If the outside unit will not run at all it could be as simple as a grasshopper caught in the contacts. If you hear the compressor running outside but no outside fan, The fan motor probably needs replaced. Please make sure that all power to the unit is TURNED OFF before removing cover plates on outside unit and before trying to remove insects from contact points. Check all wiring inside outside unit while it is open. Also check capacitors for swelling or leaking. If you don't know how to turn all the power off or open the outside unit, you need to call a professional AC technician. Hope this helps. kstfas
Aug 26, 2007 | Ruud UAKA037 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
