Question about Integra DTM-5.3 Receiver
Hi i have an integra dtm-5.3. I had just completed an extensive a/v makeover and was listening to the fm tuner. i decided to watch tv. i turned the receiver to the the video input. No sound. i turned it back to the fm tuner... No sound. The receiver is not muted. All the connections were solid. Idisconnected the integra and hooked up a different receiver to the same cables/wires and it worked fine. Is there a reset button on the integra?
4 Suggested Answers
  • 49 Answers
SOURCE: my integra dtm 5.3 flashes
disconnect all speakers. do this with the power cord unplugged from wall. then re-try without speakers. if still in protect --shorted channel-which is repair/parts will be needed.
Posted on Mar 04, 2010
  • 85 Answers
SOURCE: I have an ONKYO TX-SR606 receiver and I am trying
In reality the correct way to listen to radio or any music source for that matter is in 2 channel stereo. What this means is that the front left and right will play and also the subwoofer. If you absolutely want all your speakers to play while listening to fm, than press the Multi channel button and set it to direct, or any other sound field that you may desire.
Good Luck
Posted on Jan 08, 2011
dunnbiker
  • 8546 Answers
SOURCE: Integra DTM 3.5 AV receiver. The
Do more triage first.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a possible root cause for intermittent shutdown.
Posted on Jun 11, 2011
Soundlogic XT 5 in 1 wireless headphones will not receive audio from tv; only gets radio stations.
Did you connect the base/transmitter piece to the AUDIO OUT jacks on the back of the TV ? The radio you are listening to is the built-in FM radio/tuner. You need to connect the transmitter to an audio source (TV, PC, CD/DVD player, etc.) to receive sound from that source.
Jan 04, 2015 | Audio Players & Recorders
Integra DTR-5.6, no sound for am/fm tuner
reset receiver if that does not work You will have a defective processor pcb
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
I need philips pci tv tuner card driver philips 1730
Help Me,I need software and driver TV Tuner Epro Philips
PCTV PCI / 7130 PAL FM
May 08, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
Programa y controladores de la tarjeta de captura de video y tv tuner FM para WINDOWS 7
Hi! sorry but forget driver for your TV card.
I had the same and I changed to another card.
If you buy another TV card, please watch the CPU on the card if it is a SAA71xx it would not work under Vista and Windows 7.
Dec 29, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Sony STRDH510 has a hiss coming from the speakers when listening to FM stations, however, there is no hissing sound when watching tv and listening to the sound through the same speakers. Is there an...
This has nothing to do with the speakers.
Page 38 of the manual describes tuner operation. FM hiss usually indicates a weak FM signal or it's not tuned precisely. If the "ST" indicator is blinking and you select Mono does it get any better?
A 75-ohm FM antenna oriented horizontally will help bring in a stronger signal (page 29 and 73).
Dec 08, 2010 | Sony Audio Players & Recorders
Could some one tell me how to change the stations on my WURLITZER -MODEL WR 18-1015-CD AM/FM- 18" TALL-LIGHT UP i have tried to and i can not get it to work. It only has a remote. Thank you
Here is a link to obtain the owner/user manual for that wurlitzer if you would like it:
http://www.payphone.com/shop/instructions/Wurlitzerwr18.pdf
1. Turn power on using either the remote or power button located behind tuner door.
2. Push CD / RADIO BUTTON (25) to enable FM tuner.
3. Turn FM dial to desired station.
4. Position FM ANTENNA (16) for best reception.
5. Set volume to desired listening level.
Sep 17, 2010 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
GEMINI PC TV TUNER W/O FM DRIVER
i want the driver for gemini tv tuner palbg
May 08, 2009 | ASUS TV/FM 7135 (TVFM7135WREMOTE) Video...
Pagnor plasma tv picture problem
hi
i was perchase philips7310 tv toner card in last 2 year back
tha problems is volume is work fine picture is not coming dispaly
plz tel me what is the problem
Jul 10, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Satellite No Longer An Option on My Kenwood KDC-MP228
Your going to need to pull off the battery cable for about 2 to 5 minutes and see if this will reset the radio. Good Luck
Mar 23, 2007 | Kenwood KDC-MP228 CD Player
Integra DTM-5.3 Receiver Logo
90 people viewed this question
Top Integra Audio Players & Recorders Experts
Electro Med Services...
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
