Question about Husqvarna 24HP 54" Yard Tractor ()
When I try to mow it trys to die, and the grass is not high at all, it does it all the time?
    Brigadier General:
  • 3,911 Answers
Assuming it has a B&S V2 I would check it for bent valve push rods. In effect you are running on one cylinder and it becomes much more pronounced when you engage the blades. Without removing the valve covers you can check for a dead cylinder by removing one spark plug wire at a time and starting it. If it seems to run normally on one cylinder but not at all on the other, then you have a dead cylinder. I wold suspect the valve problem as I have seen it before and it happened to me too.
Posted on Jul 08, 2010
My Husqvarna SRD 17530 when I cut my grass I have set up as high as it will go and it will plug up with grass..
wet grass will stick to the inside of the deck. try to clean it real good and let it dry. try not to mow in wet grass if possible or it will happen again.
Apr 13, 2017 | Husqvarna Garden
Why does it bog down in grass maybe 6 " high?
The likely cause of this is that the grass is too high for your mowers deck. You should try just mowing about 1/3 of the blade at a time (if you can) until you reach your desired length, so if you grass is 6" high, only take off about 2" at first to reduce the stress on your mower. Set your mower deck to it's highest setting and give it a shot.
Also, be sure that the blades are sharp, and if you don't have mulching blades, you should get some! Grass this high will leave long clippings on the lawn which can suffocate the grass, mulching blades will chop up the clippings into smaller pieces, which is beneficial for your lawn!
Finally, make sure you aren't mowing wet grass. If you mow when the grass is wet the clippings can stick together and clump up under the mowing deck which will cause excess strain to the mower and maybe even cause it to shut off.
If none of this works, you may want to use a string trimmer to remove the first two inches of your grass and then continue mowing as normal!
Hope this helps! Happy Mowing!
Aug 03, 2015 | Garden
2008 craftsman lt1000
you need a govenor adjustment take it in or or your waiting to long to mow grass slow down when you mow or mow more often
Sep 02, 2014 | Garden
Why does my toro model 74301 keeps dieing
There are many reason a lawn mower dies in gear. Buildup of grass on the underside of the deck, mowing in too deep or thick lawn causing too much load on the blade, or the air filter needs cleaning.
Jul 19, 2014 | Toro Garden
Yardman 38" 7160 the deck belt is loose
Have you been mowing high grass, and how long has the belt been on? if you have mowed tall grass or belt is older than 2 years old it needs replaced, most don't realize how much a belt stretches from mowing tall grass. I hope this has been helpful.
Sep 27, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Troy Bilt XP self propelled mower
Normally an indication of poor air flow. Replace air filter. Clean outside of carb with carb cleaned to ensure choke is free to operate. Go real slow in tall grass, some mowers don't have the torque to do tall grass, only use 1/2 of the deck width and have side discharge open.
May 10, 2013 | Troy Bilt 5.5hp Self Propelled Mower
I tried to mow the grass even though it rained this am. our grass was really high and i saw a little smoke come out of the lawnmower. is that because the grass was still a little wet or the grass was...
Nope. If the grass is too high, knock it down to size with a weedeater first. These electric mowers cannot handle the tall, high stuff. If you do, you will surely burn it up.
Aug 14, 2011 | Black & Decker 18", 6.5a Electric Mower
The blades stop turning under a heavy load on my Craftsman 42" mower deck. Is there an adjustment that can be made?
"the adjustment" is to slow down in high grass areas. alternatively mow more often so the grass does not get so high between mowings
Apr 12, 2011 | Garden
Own a Troy Bilt self-propelled model #12A-466-M011 for a year now. It worked great when first got it. Now it will not clear the grass underneath so cuts off every 15 feet and have to manually clear grass...
I had the same problem with my Troy-Bilt self propelled lawn mower. You have to use the grass catcher if your grass is high. Also, I mowed wet grass and it made my belt slip off the pulley and created a new problem, somowing wet grass is definitely not a good idea.
Aug 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Problem mowing my lawn.
I had the same problem and I already found those recommended solutions\ causes on the web:
1. The motor isn't on full throttle.
2. The blade is upside down.
3. The grass is too high when cutting it.
4. Overlap your cuts.
It helped my problem/ I hope it will help yours too!
Sep 01, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Husqvarna 24HP 54" Yard Tractor () Logo
81 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
