Question about Alpine PKG-RSE2 Car DVD Player
Dome light stays lit on unit when doors are closed. two installers said it was hooked up correctly and could not find the problem
  • Alpine Master
  • 17,130 Answers
You will need to remove the unit and test it outside. Connect once again the leads and test if this proves right. If not open the set, as you close the panel door, there is a small limit switch that is activated to cut off the light. this is a press to OFF switch and on release it puts the connection ON.
I am sure this will sort out the issue. Hope this helps. Good day
Posted on Jul 08, 2010
Interior light stays on when driving.goes off when I use key fob to lock
Interior lights will not turn off when door closed - VW Audi Forum
www.vwaudiforum.co.uk/.../36009-Interior-lights-will-not-turn-off-whe...
... locking when using key fob, only from the inside via the lock on the drivers door ...by key fob and manually turn off the interior lights but the door lights stay on.
close door light & interior lights - CarGurus
www.cargurus.com > Questions > Ford > Edge
CarGurusJul 24, 2010 - close door light & interior lights - close door light on my ford edge is lit up on the dash and the interior lights wont go off. all the doors, truck, and . ... are completly shut. what to do? help before my battery goes dead. ... charged Interior lights work Headlights are strong Key fob locks and ... Used Ford Escape".
Door Chimes, interior lights on when stopped, and power locks have ...
www.grandamgt.com > ... > Technical Q&A
Apr 28, 2011 - 13 posts - ‎5 authors
It really only happens when its totally stopped while in drive. ... Key Fob- It works, but no longer gives the horn sound to confirm its locked. ... The fact that the car doesn't honk when using the remote isn't a problem. ..... Currently my dome light stays lit when on the door position and my alarm goes off as soon ...
Help - Interior lights staying on / door locks going crazy ...
www.mazda3forums.com/...interior.../329450-help-interior-lights-stayin...
Feb 11, 2009 - It seems that my interior lights stay on while im driving. ... If you get into the car start up the car, and then close the door the lights shut off. ... the when youuse the key fob to lock the car at night the interior lights stay on as well.
Jan 27, 2016 | Cars & Trucks
96ChryslerCirrus: 'door' warning vs odometer miles, Dome light stays on.
In the Ford Ranger, the light switch can be found in the door, right by the latch. You may need to use some WD-40 to get to work properly. -------------------------------------------------------------------------------------
zed bull
Nov 28, 2012 | 1996 Chrysler Cirrus
Door open light stays lit when all doors are closed
first, ensure that you don't have your dome light in the "on" position. THEN, check the door jamb switches that are depressed by the door being closed. you might remove them to make sure that a wire hasn't broken loose.
Jan 28, 2012 | Toyota Cars & Trucks
The dome light stays on
(I'm assuming you mean the light on the unit)... chances are whomever installed it hooked the wire for the dome light up to constant/accessory by mistake or convenience... if there used to be a dome light in that location, all you have to do is drop it down and find the correct wire to tag, if there wasn't you will have to run one up from either you foot wells or another location or you can just put it to a switch. If you were referring to you factory dome light, it may be a broken door trigger, or a bad relay.
May 01, 2010 | Accelevision DVD Player with Built-in TV...
Dome litght stays on and telltal reamin lit.
that would be my guess, the water probably shorted out the switch in the jam, replace switch
Apr 06, 2010 | 1999 Ford Taurus
Ford Taurus SE 1999. Dome Light - Door Ajar indicator problem. This is an intermittent problem, hence far more difficult to isolate. OK. I will be thorough in describing this "set of problems" as I do...
i must say that i feel your pain with this,, my door ajar light does the same thing but my dome light doesn't come on when the doors are open, i have to flick the switch on the dome light to make it come on. In my opion and i stress my opion it saounds like a issue with the body controller, im not sure what ford calls it but it controls all the body functions, i dont think the low coolant light is connected to the body contoller but i dont know this for sure, i think that light is controlled bny the engine ecm. some times a dealer can connect to the body controller and see if there are any fault codes for circuits that it controls and or monitors, also they can reflash or update the configeration and or calibration level cause ford release's fixes for issues all the time, same theory works for any control module on a vehicle. i dont think any of the auto parts stores have the right program to connect to bofy controlers but i could be wrong, worth looking into. i only put up with mine cause i use it as a beater, if you are worried about your dome light staying on and drianing your battery then you could pull out or disconnect the dome lights for the time being, its not a fix but just a band-aid.
Feb 18, 2010 | 1999 Ford Taurus
2004 crown vic interior lights stay on
Don't think you have a door ajar switch problem , more then like the lighting control module is the culprit . Does the door ajar light on the instrument cluster stay lit ?
The interior lighting can be separated into two distinct modes of operation: the courtesy lighting and the demand lighting. The lighting control module (LCM) controls all of the interior lighting in the vehicle, as described in the following text.
The front dome lamps, rear reading lamps, and instrument panel courtesy lamps, can be illuminated either by opening any of the vehicle doors (courtesy lamp function) or by depressing the headlamp switch (demand lamp function).
When any door is open, the door ajar switch grounds an input to the LCM which then sends power to the courtesy lamps. The voltage sent to the courtesy lamps gradually increases from 0 volts to 12 volts within 500 ms (± 50 ms), to achieve the theater lighting effect. When the door(s) are closed the door ajar switch(es) break(s) the ground to the LCM input which then gradually reduces the power from 12 volts to 0 volts within 5 seconds. (± .5 second).
When the headlamp switch is depressed it grounds an input to the LCM which in turn sends 12 volts to the front dome lamps, rear reading lamps, and instrument panel courtesy lamps. When the headlamp switch is depressed a second time, it breaks the ground to the LCM input which then ceases to send power to the front dome lamps, rear reading lamps, and instrument panel courtesy lamps.
The battery saver will disrupt power to the courtesy lamps after 10 minutes, the demand lamps after 30 minutes, and the headlamps after 10 minutes. Turning the ignition switch to the RUN or ACC position will terminate the battery saver feature by disabling the interrupt timers and reinstate power to the lamps.
Do you know what DTC'S are ? diagnostic trouble codes !
LCM Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1322 Driver Door Ajar Circuit Short to Ground LCM Go To Pinpoint Test F . B1442 Door Handle Switch Circuit Failure LCM Go To Pinpoint Test G . B1445 Door Handle Switch Circuit Short to Ground LCM Go To Pinpoint Test G . B1563 Door Ajar Circuit Failure LCM Go To Pinpoint Test C . B1566 Door Ajar Circuit Short to Ground LCM Go To Pinpoint Test H . B1685 Lamp Dome Input Circuit Failure LCM Go To Pinpoint Test I . B1687 Lamp Dome Input Circuit Short to Battery LCM Go To Pinpoint Test I . - All Other DTCs LCM REFER to Section 419-10 .
PINPOINT TEST C: THE COURTESY LAMPS STAY ON CONTINUOUSLY CONDITIONS DETAILS/RESULTS/ACTIONS C1 CHECK THE SYSTEM OPERATION Open and close each door, making sure that each door is completely closed.
  • Are the courtesy lamps still illuminated after the 25 second time-out period?
Yes GO to C2 .
No The system is operating correctly. C2 TEST DOME LAMP SWITCH Depress the dome lamp switch.
  • Are the courtesy lamps still illuminated?
Yes DEPRESS the dome lamp switch a second time. GO to C3 .
No The system is operating correctly. C3 CHECK THE LIGHTING CONTROL MODULE
LCM C2145a
Yes REPAIR circuit 53 (BK/LB). REPEAT the self-test. CLEAR the DTCs.
No INSTALL a new LCM. REFER to Section 419-10 . REPEAT the self-test. CLEAR the DTCs.
Apr 16, 2017 | 2004 Ford Crown Victoria
Ford taurus door ajar light stays on
have you had the door panel apart before for anything, the switch is on your latch inside your door. I hope this helps you. I am just trying to be helpful, and will help you all the way through your repair if you like, My compensation is my rating. please be generous..lol
Dec 19, 2008 | 1996 Ford Taurus
1997 Tarus dome light and floor lights will not go out.
This is usually caused by the switches sticking in the door latches. Try spraying some WD40 in the latches and open and close the doors a bunch of times that should take care of it.
Dec 11, 2008 | 1997 Ford Taurus
Alpine PKG-RSE2 Car DVD Player Logo
111 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
