Question about GE 36 in. Profile JGP963 Stainless Steel Gas Cooktop
Flame is too high even though adjusted to the lowest setting.
All burners cook with excessive heat. Is there an adjustment I can make? Flame color (air/fuel mixture) is ideal.
  • dfcooper Jul 07, 2010
    Gas. GE Profile model JGP963.
  • 17,970 Answers
For a test try this: When a burner is on and nothing is on the grate, tap the grate with the back end of a knife handle. Just tap or rap it several times. Notice the flame color? More orange than prior. Tapping stirs up more dust from within the surrounding air and debris from the grates causing more orange flames. Nothing uncommon or unsafe. Can recreate this condition on anyones stove burners at any given time. More dust more orange flames. All is than OK.
The whitish power around the pilot lights is caused by products in the natural gas. Usually caused by a high sulfur content. Can also be caused by pilot flames which are too large. Pilots should be no higher the the top of the cup around the pilot flame. Best pilot flame height is only half the height of the surrounding wind protective cup.
Be sure the surrounding pilot wind protective cup are clean and the air openings at the base of the cups are opened and free of debris, etc. Pilot flame color should be blue at the base of the flame and have a tiny yellow tip on the top of the flame.
Too high a pilot flame will create black soot and whitish powder may even be created with low sulfur content in the gas. The pilot flame height and the cups being cleaned out with all openings around the circumference is required to have a clean burning flame with no excessive amounts of whitish powder being created or left behind.
Black soot is never acceptable. The conditions which cause soot will also create odors and burn the top cover of the lid or it's chrome vent cap and/or cause discoloring to the enameled top etc.
To adjust a pilot flame, follow the thin aluminum tubes from the pilots to the black gas supply manifold where the knobs are under the top lid. There will be a tiny set screw. Use a tiny slot bladed screw drive to turn the set screws clock wise to reduce the pilot flames heights or counter clock wise to increase height but only enough so flame height is half to two thirds the height of the protective cup.
If this not solve your clues, you will need call a service technician to adjust. (adjustments are not covered by the warranty).
Tell us news.
Posted on Jul 07, 2010
    Mine is a GE Profile model JGP963 gas cooktop with electric ignition--no pilot light. The flame is too high at all settings. The air/gas mixture is perfect. I just want to reduce the flame. All burners cook with excessive heat. Is there an adjustment mechanism?
  • ZJ Limited
    ZJ Limited Jul 07, 2010
    Keep in mind that sometimes just need any clean task to solve it; You may have a rusted, clogged or
    damaged burner or venturi tube.
    Try to check if there can find the installation manual
  • 6,993 Answers
please is this a gas burner or an electric burner?
I look forward to your reply,
bye for now.
Cook top indicator lights stay on long after it has cooled off. The largest cook circle sometimes doesn't reduce heat when the dial is changed
Cook top indicator light will stay on as long as the stove is hot I think. Also, the burners don't heat real steady? or evenly or true to their settings even, quite often. they also take a really long time to cool down as well as to adjust temperatures, so it may just be that it is taking an awfully long time for it to cool down in order to adjust.
Apr 04, 2015 | Cooktops
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Converted a ge gas to lp. the oven and broiler has too much flame
You must close the gas valve orifice. There is a gas valve (silver or grey colored rectangular shaped piece which feeds the burner(s)) that has a brass or gold-colored hex nut. This nut (1/2 inch) needs to be tighten down clockwise to the stop point. This will regulate the flame.
Dec 21, 2008 | GE 30 in. JGP336 Gas Cooktop
Burners/Heat
make sure you have the correct orifices, make sure you have good gas pressure and make sure pressure regulator is ok.
also if the unit has been in service for a while check the orifice for build up a wire or needle will work to knock out any build up
Apr 23, 2008 | Jenn-Air JGD8130 Gas Cooktop
Creda 4 burner, converted to LP
Your flame is perfect if it's just the very tip that is yellow or white. All burners should be adjusted this way, on highest flame.
Mar 13, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Burner too hot
you set it fro low and goes straigt to high???? no adjustment in heat setting either of or high?? if so youll need to repalce the infinte switch controllins that burner
Mar 11, 2008 | GE 30 in. JP326 Electric Cooktop
Burners only work half way
Remove the burner knobs, inside of each shaft is a straight slot screw adjustment, use a flshlight to see it. Sears has screwdrivers this small.While holding the shaft with a pair of pliers turn the screw in the shaft, it will be hard to turn, this is normal.
Continue doing this until you obtain the desired flame setting.
Oct 11, 2007 | GE 30 in. JGP337 Gas Cooktop
Kenmore 32099 Cooktop burners regulation
remove the burners and adjust the air ration with the slide at the bottom of the burner tube
Jul 25, 2007 | Kenmore 30 in.32099 / 32094 / 32092 Gas...
GE 36 in. Profile JGP963 Stainless Steel Gas Cooktop Logo
115 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
