Question about Kitchen Ranges
I have another question regarding a KitchenAid dryer, model #KEHSO1P WH1. The last advisor I talked to said that from the terminal block, phase 1 to neutral should be infinite. I measured 120 ohms. I disconnected P1 (on the electronic control board), and then the reading was infinite. I ordered a new circuit board based on this, and it measures the same 120 ohms. The +V terminal of the heater relay on the old board was a little charred, with some melted plastic. I have also replaced the high limit thermostat, the thermal fuse, and the thermistor. In diagnostic mode, everything checks out ok - moisture sensor, door switch, etc. Theater checks out OK. Not grounded, and measures 11 ohms, terminal to terminal. I guess I still don't understand the root cause of the problem. I suspect that it is the elctronics control board, but I don't know of a measurement I can make to verify this. Thanks for your help.
  • Albert Lemieux Jul 13, 2010
    Jumah seems to have gone offline. haven't heard from him for several days. Still have a question waiting.
  • Kitchen Ranges Master
  • 6,826 Answers
It appears that you have gone further than many novices or even technicians would go on repairing this problem using an Ohm Meter.
The +V terminal of the heater relay on the old board being charred is not a good sign.
I don't have a lot of time to answer this question but did find a site on Kitchenaid.com that has quite a few .pdf files that you might find helpful in diagnosing the problem, although, they seem to be a bit less technically oriented:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=kehs01p&siteCd=KAD&userType=Consumer
Posted on Jul 13, 2010
    I think that I have the fryer working, onllow heat for the time being. My scenario goes like this: The high limit thermostat fused shorted. This in turn took out the thermal fuse, and in the process, weakened the control board. When I replaced the high limit thermostat and the thermal fuse, the weakened board took out the thermal fuse again. This time, I replaced the board, the high limit thermostat, and the thermal fuse. Now it seems to be working. Does this scenario make sense? I am basically looking for the root cause, and am guessin g that it was the high limit thermostat.
  • Duane Wong
    Duane Wong Jul 13, 2010
    Like I said, you have gone further than most technicians would have, in my opinion.
    Kudos to you.
    President:
  • 1,561 Answers
Would you please shed more light on this question, dont really understand what exactly the problem is, i will like you to shed more light on this question so that i can proffer a solution.
Thank you.
Posted on Jul 07, 2010
  • Albert Lemieux Jul 09, 2010
    Originally, the thermal fuse blew, and the high limit thermostat shorted (fused). The thermistor checked out OK. I replaced the high limit thermostat and the thermal fuse. The dryer worked for about a week, and the thermal fuse went again. This time, I replaced the thermal fuse, the high limit thermostat, and the control board. I suspect that the problem is solved now, but I don't know how to test the board to show that it is bad, and that makes me think that maybe I have not found the root cause. Any comments?
  • Albert Lemieux Jul 11, 2010
    It has been a couple of days. When might I expect an answer?
How to wire a four prong plug in
red and black power phase wires on the cord go to the 2 outer terminals of the 3 terminal power block on the dryer,then the white neutral wire on the cord goes in between the red and black wire on this power terminal block ,then the green wire on this cord goes to any metallic point of the dryer which is the safety ground wire
Jul 28, 2012 | Maytag Dryers
The terminal block at rear of stove had a suppressor board mounted behind it and then fastened to stove back by #9-15 x 1 inch screw. The rear solder joints of the suppressor board would all be touching...
Hi - there are two types of suppressors these days - 2 & traditional 3 tails - 3 tails used to be connected across the phase-neutral-earth - these days the 2 tails are connected across the phase-neutral conductors - its purpose to eliminate the cracklings to tv/radio waves..
I tried to locate the parts you refer to on the website .. will look some more
Jul 08, 2011 | Kitchen Ranges
How do I switch the wiring for a Garland Model S 686 -2 Stove from Single Phase to 3 Phase?
If the oven is a three phase oven currently wired on single phase there will be three active terminals at the terminal block. There will be links or bridges which connect the single phase to each of these active terminals. Remove these links and connect each phase to each terminal.
Feb 24, 2011 | Garland S686 Electric Kitchen Range
I have a new water heater, and the hook up terminals are labled 1-2-3 are they hooked the same as in the panel 1-2-3 ?
No. You have to find out if you have 3 phase or single phase power. If this is a new unit you will find a wiring diagram inside the front cover. 3 phase power has 3 "hot" wires. Single phase has 2 "hot" wires. There is a big difference when you hook it up wrong. I don't know if this is a new installation or if you are replacing an old one. The terminals are numbered for 3 phase. If you look in your breaker box, 3 phase 208 will haven a breaker with 3 spaces hooked together by one bar. Single phase will have two spaces hooked together by a bar. So if the breaker kicks out it will flip all 3 space on 3 phase or 2 spaces on single phase. If you already have wires to the location of the booster heater, you may have to use single phase if that is all that is at that location. If you have single phase power you will have to look at the wiring diagram and you will see the terminal block represented for both single and 3 phase. Normally running from the terminal block will be six wires marked 1 through 6. The wireing diagram will say something like "for single phase put 1,3,5 on terminal 1 and 2,4,6 on terminal 3. Leave terminal 2 out all together. Of course at this point your 2 hot wires will go to terminal 1 and 3. There are other considerations as well. With 3 phase the circuit wires will be smaller gauge and may not carry the current you need for single phase. This is a booster heater. You need to hook up your hot water line to go into the heater and the boosted hot water to your appliance. It will not work to heat your water for other purposes. It is meant to take 140 degree water and boost it to 190 degrees. Good luck, hope this helps
Sep 11, 2010 | Hatco Corporation Compact Electric Booster...
How to connect a dryer in 240 v? Its a whirlpool dryer model WED5520SQ0. I believe I need a 240 volts supply, but I can't understand how to connect... I someone has the installation guide step to step,...
I have to say if you don't understand 120v and 240v it might be best to let someone more knowledgable help in person.
120v is 1 leg
240v is produced from 2 legs opposite phase.
do you have "A" and "B" phase and if so do you know how to tell?
Do you have electric heat with breakers?
If so i'll try to talk you through it
Mar 11, 2010 | Dryers
Trying to change a 3 prong dryer outlet cord to 4 prong
you evidentally got a hot phase and a neutral mixed up on the terminal board which made the case of the unit hot 120volts,then it backfed through the case ground wire back to the neutral and this blew the fuse/breaker,if its a flat 3 wire cord, the 2 outside wires are your hot phase wires and go to L1 and L2 on the terminal block,polarity is not an issue soeither wire on either terminal,then the center one goes to the terminal marked N or neutral
Jan 20, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
We need to attach a new pigail to the KitchenAid 750 LQI
Hi lvolkmar,
Perhaps I can assist you with your wiring dilemma. To begin with, you wil need to gain access to the back of the dryer so pull that out and locate the feedthru where the original cord fed into it. Next, loosen the cable clamp ( make sure the cord has been unplugged from the wall receptacle )..
Once you loosen the cable clamp, open the access cover to where the wires get terminated onto the terminal block of the dryer. You should see at least 3 locations... and maybe 4. Your dryer should have a red, black,white and or green terminal so match the red wire to the red terminal, black to black, white to white and the green is the ground wire... if you do not have a ground terminal on the terminal block then you should see a ground stud near the point of entry or near the terminal block itself. It's ok to use one of the sheet metal screws on the frame if you can't identify a ground terminal.
For the record, the red and black wires are incoming ac power, the white is your neutral which is normally wired between the red and black and the green is a frame ground for your safety. Hope this helps you but if not, feel free to restate your question or concern.,..
Regards,
Rick
Nov 23, 2008 | KitchenAid KEYS750LQ Electric Dryer
How to hook up a 3 prong plug in a maytage dryer(model Number LDE4000ACW)
you have a 220v cord you want to installe into your , electric dryer.... easy enough look at your cord .. of the 3 terminal ends either end makes no difference which goes to the terminal block behind dryer. the middle wire needs to hook up to the middle terminal and then the last end goes to empty end terminal, AGAIN END TERMINAL CAN BE SWAPPED, THE MIDDLE MUST BE HOOKED TO MIDDLE, TERMINAL
Apr 05, 2008 | Dryers
Error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
Kitchen Ranges Logo
35 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
