Question about HP LaserJet 2840 Printer
HP LaserJet 2840 printer. trying to scan from
HP LaserJet 2840 printer. trying to scan from printer but continue to get error: "Not set up on PC"
I have an HP 2840 and I have constantly been getting a scanner error 52 code. Per the text and research they say power it on and off, which did not work. Other experts say to replace the scanner...
hp 2840 error The device HAS Experienced 52 year internal hardware error. theoretically not initialize the scanner, to be replaced after that piece or set of diagnostic scan (logic board or motor, etc.
Apr 12, 2011 | HP LaserJet 2840 All-In-One Printer
Scanner Error 5 "error message" on my all in one
I had this problem and it had to do with the scan bulb head not recognising the marker. My temporary fix until the bulb is replaced is to turn the printer off, open the top (ADF and all) with the gray button on the right so that it's slightly raised and then switch the printer on. When it comes up, just close and print/scan/copy as usual. Apparently the spring in the arm warped the interior surface where the head moves and it can't line up when it's closed. Hope this helps.
Jun 07, 2010 | HP LaserJet 2840 Printer
HP 2840 scanner error "scanner not setup"
Trying to use scanner and will not work. Keep getting error message: "not set up on PC"
Mar 27, 2010 | HP LaserJet 2840 Printer
Hp color jet 2840 cannot scan on windows vista but can print
The problem is Vista. I had a similar problem and the only solution at the time was to remove vista and install good old reliable XP. Now just put windows 7 on and you should be ok.
Aug 14, 2009 | HP LaserJet 2840 Printer
HP Color Laserjet 2840 will not completely scan legal size docs
have you downloaded the scanfix that is own the HP support site?
May 22, 2009 | HP LaserJet 2840 All-In-One Printer
52 scanner error on HP Color Laserjet 2840
The device has experienced an internal hardware error. Recommended Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If the error is still unresolved, contact Hewlett-Packard for technical support to troubleshoot the problem. Call HP for telephone support
Mar 22, 2009 | HP LaserJet 2840 All-In-One Printer
HP PRINTER 2840 WONT SCAN TO WINDOWS FAX AND SCAN PROGRAM
well........ first of all it depends on the Operating System on you computer, then starting from there the advice that i can give you it is to fully uninstall the software and then install the software back using the version that is on hp.com
after that when you have the full sw installed you have to set up the scan button on the printer from the twain scan window but that will be a piece of cake. just make sure ot get the software properly installled.
Mar 06, 2009 | HP LaserJet 2840 Printer
Laserjet 2840. Not able to scan. When I hit the scan to button, it says not set up on PC. I have turned both printer and PC off and on again to reset but didnt help.
There have been a number of problems identified with the software for this all-in-one. Some pertain to USB connect and some to network.
After installing the printer you will need to set up the "Scan to Button" through the HP Director. Open this user interface from your desk top and click on Settings, then scan settings and preference, then scan to setup. Make sure that the feature is turned on and that you have selected a folder to scan to. Click the apply button once you have made your selections. At this point try the button to see if it is working. If not, from the same location outlined above try turning the scan to feature off and then on again. If the scan to button still does not work, hard boot your PC (shut it down complete) and then restart.
Jan 12, 2009 | HP LaserJet 2840 Printer
Scanning not happening in Hp lasejet 2840 in windows vista
check to see if that printer requires direct plug into wall socket. and did that printer driver come on cd or did you get it from www.hp.com?
Dec 12, 2008 | HP LaserJet 2840 Printer
HP LaserJet 2840 Printer Logo
631 people viewed this question
Seeker5211
Seeker5211
