Question about Plantronics CS55 Wireless Headset
When I call people they say I sound muffled and that there is a crackling noise and it is a new headset.
Sound became muffled(only lower frequencies) in both ears
An equalizer circuit or filter? No idea where this would as you only give the result not total environment.
Apr 01, 2014 | Telex Airman 850 Aviation Pilot Anr...
There's a distinct crackling sound on my Headset. What can I do?
I have the same problem, but only in Windows, and only on my laptop (It's a Compaq 515). I do not get the problem if I pair it with my phone, or if I plug the receiver into any of my other computers. The big thing is: If I reboot into Linux, the noise stops.
Feb 08, 2013 | Logitech Wireless Headset H600 Overthehead...
Microsoft lifechat lx-3000 headset crackle noises
Go to Control Panel>Large Icon View>Sound>Playback Tab>Right Click The Headset Icon>Properties>Advanced Tab>Change the Default format from CD quality to DVD quality and voila. :D
Feb 01, 2012 | Microsoft LifeChatâ„¢ LX-3000 Headset
On my XBOX 360 I am getting a crackling noise in my headphones when I have my microphone plugged into the wireless controller. I have tried two other known good controllers and the problem is still p
This sounds like it is probably an issue with your wireless controller. If there is any way for you to safely blow into the tiny hole that you plug your headset into in an attempt to clear any dust or debris from that area it would be in your best interest.
If not, try a third headset-- the same issue means either play without a headset or purchase a new controller.
Hope this was helpful!
Jan 30, 2012 | Microsoft Xbox 360 Console
I have been experiencing static noise/crackling from my front left and right speakers just recently. (I have a 5.1 dell system - the front center - attached to the monitor and rear speakers do not emit...
This seems like at cables have gone bad or either the connections in the speakers went bad. Its best to replace them unless you know how to disassemble and re-soder the connections.
Mar 01, 2011 | Dell WL6000 Computer Speakers
The mic play back sounds deep and muffled , i was online chat and when i set up the mic volume, it played back deep and muffled like on the movie silence of the lamb.
Its set too loud and the mic is way to close to your mouth. try seeting the boom mic about 2inches from your mouth!
It's a matter of experimenting with mic placement to get the best results. (If it'sd not a new unit, make sure that the microphone holes underneath the windsock aren't blocked up with debris!)
Good Luck
Jan 17, 2010 | HP RF823AA#ABA Headset
Static noise problem
check cabling sounds like the receiver is loose
Mar 27, 2009 | Avaya AWH-55 Professional Headset
Sound stopped working
hmmm..crackling in headsets suggests that perhaps you have a shorted connection. you may wish to test them elsewhere too
Feb 22, 2008 | Gateway M305CRV Notebook
No one can hear me
I had the same problem. I contacted hellomotto online and was able to return it. I received a brand new headset at no cost within a week. Hope this helps.
Aug 29, 2007 | Motorola Mobility H500 Wireless Headset
Plantronics CS55  Wireless Headset Logo
143 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
