Question about HP OfficeJet K80 All-In-One InkJet Printer
Apple mac connecting to HP printer via XP PC
I am trying to connect to XP PC which has HP K80 printer connected via parallel printer port. Printer works from XP PC, and can see shared printer from iMAC but will not print to it - any ideas
    Scholar:
  • 99 Answers
Go here and you should have all you need:
http://iharder.sourceforge.net/current/macosx/winmacprinter/
Thanks// CowboysfanZ
Posted on Apr 24, 2008
Trying to connect 4 MACs to all in one Kodak 5250 printer and will not connect via wireless. I had to set up so that the other pc's have to print from one location via hardwire. I tried installing...
If you have one PC connected to the printer via USB you can share the printer to your Mac computers easily:
If the printer is connected to a Macintosh computer via USB:
1) Open System Preferences
2) Click on Print and Fax
3) Highlight the Printer and Check the box Marked "Share This Printer On The Network"
If the printer is connected to a windows computer via USB:
1) Download "Bonjour Print Services for Windows" from Apple's website
http://support.apple.com/kb/dl999
2) Install it on the PC connected to the Printer.
3) After Installing the Above, Run the Bonjour Printer Configuration Utility and select the Printer you want to share and it will share it over the network to all your apple devices.
Mar 02, 2011 | Kodak ESP5250 All-In-One InkJet Printer
Tip
100% CPU when printing
<span><span>If</span> <span>your</span> <span>printer</span> <span>is</span> <span>connected</span> <span>to</span> <span>your</span> <span>computer</span> <span>via</span> <span>a parallel port</span> <span>(</span><span>or</span> <span>LPT</span><span>)</span><span>,</span> <span>it can</span> <span>use</span> <span>100</span><span>%</span> <span>of</span> <span>your processor</span> <span>time</span> <span>for</span> <span>your prints</span><span>.</span> <span>In</span> <span>some</span> <span>cases,</span> <span>other</span> <span>open programs</span> <span>do not meet</span> <span>longer</span> <span>during printing</span><span>.</span><br /><span>This</span> <span>issue</span> <span>is</span> <span>related</span> <span>to</span> <span>the parallel port</span> <span>which</span> <span>is</span> <span>connected to</span> <span>your</span> <span>printer</span><span>.</span> <span>Windows</span> <span>does</span> <span>not support</span> <span>interrupts on the</span> <span>parallel port</span> <span>which</span> <span>leads him</span> <span>to use</span> <span>100</span><span>%</span> <span>of</span> <span>your</span> <span>CPU</span> <span>to</span> <span>your impressions</span><span>.</span></span><br /> <span>The</span> <span>only</span> <span>workaround for</span> <span>this</span> <span>problem</span> <span>is</span> <span>to</span> <span>abandon</span> <span>the</span> <span>parallel port</span> <span>to connect</span> <span>your</span> <span>printer to</span> <span>your</span> <span>PC</span> <span>and</span> <span>instead use</span> <span>the</span> <span>USB</span> <span>port</span><span>.</span> <span>We must</span> <span>make sure your</span> <span>printer</span> <span>supports this</span> <span>connection type</span><span>.</span><br /><a href="http://www.fixya.com/AnswerQuestions.aspx"></a>
on Jan 03, 2011 | Office Equipment & Supplies
Use of HPJ4680 in a network with Mac & PC connected to router
Ok what you do is, install the printer as a LOCAL one on one of the PC's, Probably the XP, one, would be best. or perhaps the PC; actually "Connected" to the D-link router & Modem, then Now install this printer , as a LOCAL, printer, and set as DEFAULT, enable Printer Sharing. Now, ALL PC's MUST, have a Name, Belong to the same Workgroup, have a Password. On the "Other" PC's Install the Printer as a Network Printer, browse for it and connect. Print a test page from each. Remember the PC with the printer attached, must obviously be ON or the "Others" cannot connect and print.. Make sure all network permissions are set sharing is set, especially on the Win 7. Just make sure they can all "See" each other first, before try all this.. the network MUST be intact and communicatable from each PC to at least the PC with the printer attached. I have included 3 links below, to help
kb.parallels.com/4886 - support.apple.com › Support -
support.microsoft.com/kb/239418
Mar 05, 2010 | HP Officejet J4680 InkJet Printer
Epson TM-T90 wont work with USB plug
I have the same problem...Epson does not work with a parallel to usb cable or adapter. If you still want to use this printer you will have to use the parallel port or change the interface on the printer to USB.
Nov 21, 2009 | Epson TM T90 Printer
Can't install old printer on newer computer
The appropriate printer drivers are bundled with XP. With the printer connected to the computer and powered on, the system should automatically recognize the printer and install the correct drivers if it is connected via USB. If it is connected to the parallel port, go to Control Panel -> Printers, select Add New Printer and follow the on-screen prompts.
Mar 21, 2009 | HP DeskJet 932c InkJet Printer
Connect Kyocera Mita FS-1010 to Macbook (OS X 10.5)
in FS1010 printer usb port avilable u can connect the printer through usb port .
please delet ur printer driver and reconfigure it . use a usb cable to connect the printer it will work.one more u can put ur printer in network
Dec 23, 2008 | Kyocera Mita FS 1010 Laser Printer
Officejet k80xi innstall
Reboot the pc after uninstall Printer.
And then insert the CD without plugging the printer. Follow the steps and when prompts for connecting,--Connect the printer-- Its simple
Regards,
Ellin
Oct 19, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Canon bjc 50 printer
You are correct on your deduction.
It is the USB to Parrallel adpter. They are not reliable in the XP/Vista enviroment. I have run into this several times.
Oct 07, 2008 | Canon Office Equipment & Supplies
HP Laserjet 3100 all in one USB driver / cable
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Also try with another USB cable, If you are using a long cable, just try with a short one.
Dec 17, 2007 | HP LaserJet 3100 All-In-One Printer
Printing using Parrallels and winxp
How do you have this unit connected via parallel - there is no parallel port
Apr 22, 2007 | Epson Stylus CX6600 All-In-One InkJet...
HP OfficeJet K80 All-In-One InkJet Printer Logo
73 people viewed this question
Ben Johnson
