Question about Norcent Technologies LT-2722 27 in. LCD Television
Where can I get a replacement converter? - Norcent Technologies LT-2722 27 in. LCD Television
  • Norcent Tech... Master
  • 8,457 Answers
Tries websites like Shopjimmy.com,Ebay.com to buy those LCD inverter boards.
Posted on Jul 07, 2010
1998 Ford Econoline has code p2099 what does it mean
code p 2099 refers to post cat converter fuel trim (FT) bank 2 --too rich===causes --catalytic converter
it also refers to engine coolant temperature (ECT) sensor --- circuit malfunction=== causes --- wiring-- ECT sensor
bump the cat converter with the heel of your hand and if it rattles replace the cat converter
if the cat converter is solid , replace the ECT
Sep 04, 2016 | 1998 Ford Econoline
Tip
RECYCLE THAT OLD CATALYTIC CONVERTER
Sooner or later, most cars will need to have one or more catalytic converters replaced. The old converter off your car or truck can be recycled for cash. Some of the older converters are worth enough to pay for having a new one installed. But most people are not aware of how valuable they are, so they let the muffler shop or repair shop keep the old converter. The muffler shop will recycle the old converters for money that should have gone in your pocket. Personally, I think there should be a law that requires the muffler shops to give the old converters to the customer, or have the customer sign a waiver saying they do not wish to keep the old converter. The waiver should state that the converter can be recycled for cash. And if they waive their right to keep the old converter, the muffler shop should be required to reduce the cost of the new replacement converter by a percentage of the value of the old converter.
on Feb 10, 2011 | Chevrolet 1500 Cars & Trucks
2000 Dodge Dakota Removed catalytic converter and replaced both up and down stream O2 sensors.Losing low end power and heavy spark nock or pre ignition fire? How to fix with out replacing converter?
REPLACE THE CONVERTER,ITS THE ONLY WAY!plus without it,you will never pass emissions,why would you replace the parts that work because of the catalytic converter and remove the converter,your thinking is warped
May 15, 2015 | Dodge Dakota Cars & Trucks
I bought a 2003 cat converter from NAPA(Part No.16403). My mechanic was unable to put the old heat shield back on. I am again seeing the "check engine soon" message on my instrument panel. ...
A 2003 vehicle probably did not need a new converter. Cat converters have to be run for years before they clog up. Depending on what kind of vehicle this is, you may have a post catalytic oxygen sensor problem. Also, depending on the vehicle, you can not just replace the converter with any old converter. Many vehicles require an OEM replacement converter in order for the sensors to work properly and these are expensive. Kansas City Converters (available online) sells replacement converters for a fraction of the price that will work with post catalytic sensors and not cause the check engine light to come on.
Dec 14, 2010 | Nissan Altima Cars & Trucks
Code po430 not sure what maybe converter
One of three (3) possibitlies:
1. Catalytic Converter is malfunctioning.
2. O2 Sensor is malfunctioning. This will be the O2 Sensor located on the Catalytic Converter. However you should check and/or replace both sensors if needed.
3. You have an Exhaust Leak.
In Order of checking:
A. Check and Repair any Exhaust Leak.
B. Replace the O2 Sensor on the Catalytic Converter 1st. Also Known as the Downstream O2 Sensor or HO2 Sensor.
C. Replace the O2 on the Exhaust Manifold prior to the Catalytic Converter. Also Known as the Upstream O2 Sensor.
D. Replace the Catalytic Converter.
Let me know if this helped, or if you have any additional information, problems or questions. Feel free to contact me at FixYa.com!
Feb 01, 2010 | 1998 Ford Explorer
The check engine engine light remains on. I have replace bothe sensors on the catalatic converter. Do I need to replace the converter now? Fred
i would replace sensors and then reset check engine light and drive if light comes back on then replace converter, 80% of the converters are condemed because o2 sensors are bad,garage fiqure if they replace everything there sure to fix the problem,but the cost is on you.GOOD LUCK!!!!
Oct 01, 2009 | 2000 Mazda MX-5 Miata
Replace muffler, not the catalytic converter which started to rattle. Stop running, will crank but will not start. can it be the catalytic converter.
if the converter is rattlin then it needs to be replaced because the element inside is broken. if the jeep still does not run try removing the catalytic converter to see if the restriction is too much. should start if the converter is restricted. if it doesnt maybe its whatever caused the converter to go bad in the first place
May 28, 2009 | 1996 Jeep Cherokee
Catalytic Converter Noise, Code, and Replacement
CAN'T TELL U IF THE NOISE IS FROM THE CONVERTER BUT THEY DO COME APART AND CAN SOUND THAT WAY.AN AFTERMARKET CONVERTER WOULD BE FINE AS LONG AS IT IS FOR SALE IN YOUR STATE(NO CALI)
May 04, 2009 | Honda Accord Cars & Trucks
Norcent Technologies LT-2722 27 in. LCD Television Logo
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
