Question about Sony Televison & Video
I was trying to use my Wii on our Sony KDL46V5100, and I guess I made a mess of things. Now when I turn on the TV, the screen shows a purplr screen with a TV box on the upper left with a line through it and on the upper right, the number 9. When I go through the choose your channels, it searches and comes up 0. How do I get it back to a TV?
  • 10,594 Answers
Perform Reset function to set tv on factory default settings to clear all/ any wrong settings in tv get it back to normal operation. Reset procedure is as follows:
Turn on the TV. Press and hold down the 'UP ARROW' button on the Remote, press the POWER button on the TV set. Release the 'up arrow' button. Up Arrow button is up button of 4 navigation buttons.
This function will reset tv to factory default settings as it was fresh in box.
Go through initial setup screen to set time, date, scan cable channels etc.
Hope this info will help you.
Thanks.
Posted on Jul 07, 2010
  • 3 more comments
  • alii8538 Jul 07, 2010
    I hope you won't get this message twice, however, I followed your e-mail and it got me through the language and home part. Then it started searching for the Analog and Digital Channels. The result was "0". I turned the TV off and then turned it back on again. It came up with the same screen. What do I do now?
    welcomejllee
    I went through your e-mail and did all the things your suggested. I got to the language and home part. Then it started searching for Analog and Digital channels. Results "0". I then turned the TV off and turned it back on.... The same screen appeared.
    What do I do now?
    alii8538@msn.com
    Order #61409
  • Shahid Electronics
    Shahid Electronics Jul 07, 2010
    Make sure to select digital cable option in channel search process.
  • alii8538 Jul 08, 2010
    The problem is still not solved
    Shahid Electronics Jul 08, 2010
    I got your both comments and replied.
My 12 year old Sony KP-53V80 TV suddenly turned off and will not show a picture just a small rainbow at the top of the screen, then a whistling sound, crack and turns back off. can you help?
sounds like the inverter went bad...There's a high voltage device in there that runs the whole "picture" thing. There are capacitors involved with it that have probably failed leading to this mess.. That would be what that "crack" is...If you try to turn it back on does it just "click " and then stay off?
Jun 09, 2012 | Sony KP-53V80 53" Rear Projection...
When i turn my Wii on it does not show up on my screen all the time. Sometimes it does but not always. It usually shows up as a black screen. Everything else on the Wii works and I can eject disks and its...
try changing to a different input on the tv, or a different tv if you can(if you haven't tried that yet). if it stops then you know it's not the game but maybe the tv or the input. they do wear out from things connecting and disconnecting. you could also try a new cable from the wii to the tv. unplug the cables and check the length of the cable carefully to check for cuts or exposed wires (pets can chew them ect...). if you find anything odd, replace the cable right away. if you have ever had you wii modded in any way, that could also be the problem. even if it was a while ago.
hope this helps
Apr 17, 2011 | Nintendo Wii Console
I can not get the sound to work on my Sony LED 46" TV. Model KDL46V5100
This is probably a audio issue this could be a audio/video issue board
Jul 30, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
It's been ahile since I've used my WII. All the
I'm not certain, but it really sounds like you might have the cable plugged into the "out" instead of the "in."
The best thing to do would be to first try using the Wii on another TV. This will help establish if it is the Wii that is the problem or something else.
If it works fine, then it is not the Wii. If it doesn't work, then it must be the Wii or the connectors.
To complete the troubleshooting process, make sure the VCR and TV both are able to show clear images (play a tape in the VCR, I guess). If they both show clear, and the Wii worked on another TV then your problem is definitely in the connection. Either it is misconfigured or a wire is faulty.
Jan 03, 2010 | Nintendo Wii Console
I plugged the red,white, yellow audio/video cables into the front jacks on my Sony Vega. They are marked input 2. When I turn the TV to all inputs, including input 2, I just get the black screen. When I...
Sounds like you have the Wii hooked up properly. I would suggest trying the other inputs on the TV just to be sure input 2 isn't faulty.
After trying the other inputs if the Wii still won't show any video then try another set of cables and after that if the video can't come up then the Output from the Wii is bad and the main board would have to be replaced.
Dec 02, 2009 | Nintendo Wii Console
Toshiba 32a43 32' picture garbled mess
If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
Aug 03, 2009 | Toshiba 32A43 32" TV
LCD HDTV screen skipping?
try setting your tv or try it on another tv
Apr 21, 2009 | Nintendo Wii Console
GETTING INTO MY MII
you dont have to check the cd slot. its not with the cd. its the mii creator screen. I suggest you wait a while before pressing anything
Jan 15, 2008 | Nintendo Wii Console
Screen problems
Sounds like you have caps going bad in video circuit. This will need repair from export. If tv is in warranty, then send back.
Aug 16, 2007 | Hitachi 28LD5200 28 in. HDTV-Ready LCD...
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
