Question about HTC Touch Diamond Smartphone
I get an error message when trying to connect to
HCT Pro
HTC TouchFLO3d ??? not sure if that's operating system.
I get an error message when trying to connect to my emial that says :
Cannot connect
The answeing modem has disconnected. To check your connection settings and change them if needed tap settings.
    President:
  • 567 Answers
Hi there your setting may be incorrect you should go the phone settings and carefully go through it and make sure the settings are right.If you have the manual for the phone you can follow the steps in the manual,you can also go to the manufacturer website by using a computer for more information about the problem.
Posted on Jul 07, 2010
Unlock hct
This is HTC not hct..Specify the model,network,country it locked now?Get the Unlock code from the site Theunlockspot.com/htc/rs10wp8/ and Unlock it easily...
Aug 11, 2012 | HTC Computers & Internet
Change language from italian to english.. htc tyn II pro, thank you
Hi there!
You'll need to follow this steps to change the language of your HTC TyTN II
<p>1. Make sure you install Microsoft ActiveSync in your computer. Do a first time sync between your phone and the computer.</p><p> 2. Disable any screensaver and/or hibernation in your computer.</p><p> 3. Sync and again and flash with the HardSPL rom from OliNex. You can find this HardSPL software from here >> http://wiki.xda-developers.com/uploads/Unsigned_HardSPL_for_Blackstone_OliNex.zip The flashing completes in under 2 minutes.</p><p> 4. Reboot device. TouchFlo3D will launch into the native language the device originally came in. The new rom now enables you to flash other language roms, even official ones from HTC, bypassing licensing and verification checks (of course you should have the relevant ROM).</p><p> 5. Finally, flash again with the newset WWE (World Wide English ROM. You can download the official English ROM here: http://www.htc.com/hk-en/supportdownload.aspx?p_id=13&cat=2&dl_id=287</p><p> 6. Device reboots in english, or the language of the ROM you flashed.</p>
Take note that by doing this, the warranty of your phone will be voided.
Hope this helps
Apr 28, 2011 | HTC TyTN II Smartphone
HTC driver.exe used for hooking phone to MacBook Pro won't execute.
You mention that the driver is named "HTC driver.exe". Are you sure it's a version for MacOS?
Usually files named ".exe" are for the Windows operating system. It's possible that you're trying to use the wrong file for your operating system.
Try looking on HTC's website for a MacOS X version of the driver instead.
Mar 13, 2011 | Computers & Internet
Cnnot get mms to work on htc touch pro
Make sure your WIFI is turned off when trying to download a MMS message. Most carriers do not allow MMS data to be transfered over WIFI. Your phone will us it's cellular data connection.
Feb 17, 2011 | HTC Touch Pro Smartphone
Ive recieved a multimedia message from somebody. how do i forward this message on from my hct wildfire phone?
To forward the message from history you have to press and hold the message to bring up the forward option.
Dec 07, 2010 | HTC Wildfire Cell Phone
Iam sooraj using HTC P400i PHONE MY MOBILE NUMBER +919946324460(PREPAID VODAFONE) I CANNOT USE GPRS IN MY MOBLIE PLS HELP TO BROWSE BY GIVING MANUUAL SETTINGS
This will wipe all the storage (not the sd card) and your device will be reset to default settings.
Hard reset (option 1)
  1. Pull out the stylus.
  2. With the device turned on, press and hold the VOLUME DOWN and CENTER buttons, then press the RESET button with the stylus tip.
  3. Continue pressing the RESET, VOLUME DOWN and CENTER buttons until you see this message on the screen:
This operation will delete all your personal data, and reset all settings to manufacturer default. Press ?VolUp to restore manufacturer default, or press other keys to cancel.
Hard reset (option 2)
You can also use Clear Storage to reset your device back to factory default settings.
  1. On the ?TouchFlo3D Home screen, slide to the Settings tab and then tap All Settings or goto Start and press Settings.
  2. On the System tab, tap Clear Storage.
  3. Enter “1234” and then tap Yes.
Hard reset (option 3)
  2. Turn device OFF.
  3. While pressing the CENTER button, turn the phone on with the POWER button.
  4. Continue pressing the CENTER button until you see this message on the screen:
This works on at least some Verizon CDMA phones on which option 1 will not work.
Hard reset (option 4)
  2. With the device turned off, press and hold the VOLUME DOWN and CENTER buttons, then press and hold the POWER button.
  3. Continue pressing the POWER, VOLUME DOWN, and CENTER buttons until you see this message on the screen:
This operation will delete all your personal data, and reset all settings to manufacturer default. Press ?VolUp to restore manufacturer default, or press other keys to cancel. (works with Alltel touch pro)
Sep 29, 2009 | HTC Touch P3450 Smartphone
How do i hard reset the htc p4600?
  2. Turn device OFF.
Sep 29, 2009 | HTC Touch Diamond Smartphone
HTC HD won't connect to my email server
Hi.
Not sure if this helps or ot, as the original question was a little lacking on detail:-)
If you are using t-mobile (might apply to other operators as well, but I could only test on t-mobile) try the following:
Start
Settings
Connections Tab
Connections
Set up my proxy server
Clear the tick box title "This network uses a proxy server to connect to the internet"
Worked for me.
Mar 17, 2009 | HTC Touch HD Smartphone
Easy Sync Pro not able to connect to my HTC touch
I had exactly the same problem. I changed location from Easysync on my HTC P3300 from memorycard to internal memory. It worked!!
Using easysync 4.26
Lotus Notes 8.0.2
Active Sync 4.5
Jul 10, 2008 | HTC Touch P3450 Smartphone
HTC Touch Diamond Smartphone Logo
150 people viewed this question
Top HTC Computers & Internet Experts
Justin
Justin
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
