Question about Vacuums
I have a yellowMiele Vacuum,model=Electronic Air Clean Plus S3121. On the main body the part that the pipe/nozzle clicks into has a piece that has snapped off. I can see this by lifting the lid and the black plastic piece that is screwed to the inside of the lid has a piece chipped of it which means that when the nozzle is clicked into place it is completely loose. There is a black piece that clicks into the inside of the hoover into this broken part which is still ok so at the moment by lining up the nozzle with this loose piece I can click it into place. How can I get this piece that I need?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Generic problem for all Vacuums
posted by maura497 on Apr 18, 2008
Report abuse
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can order the order or the schematics from the factory website listed below and I will provide you with another contact as well for the Miele S3121 in order for you to order or replace the part that is broken or you can refer to your local vacuum cleaner dealer in the yellow pages.
http://miele.com 1-800-999-1360 Customer Care
Toll-Free Contact Information
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
www.AVACcorp.com 1-800-328-9430 they can also mail or fax you the info needed to repair or replace the part and they will ship out the product as well
Posted on Apr 18, 2008
Meile vacuum s3121
push a broom handle through it or a peace of hose pipe
Nov 23, 2013 | Vacuums
Power nozzle will not turn on
Depending on the power nozzle model, does a red light come on the top of the power nozzle? If it does, then the problem could be the circuit breaker. If it does not, then the problem could be either in the hose or the connection from the hose to the main unit. Make sure you hear to clicks and the hose is connected solid to the main unit. Otherwise, the receptacles can't make contact to allow the power nozzle to turn on.
RainVac
www.rainvac.com
800-523-0510
Sep 15, 2012 | Rainbow E series Canister Wet/Dry Vacuum
How do I open my shark plus 1200w vacuum
place the vacuum cleaner in the vacuuming position with the wheels in normal rolling position. Slip your 4 fingers excluding your thumb into the hole located next to the nozzle(where this hose connects to the main body). Yank straight up and the bag compartment will open.
Mar 30, 2011 | Euro-Pro Vacuums
The motor on my carpet tool (beater brush) stopped running yesterday. The main vacuum still works, but the switch for the carpet tool just clicks and doesn't turn it on.
Knowing the model would help.
Possible problems:
Broken or disconnected wire in hose, connections, power nozzle.
Hose needs replaced. Check all connections for discoloration and cracked supports. Have power nozzle checked at a vacuum shop. Depending on the model, take it to an authorized Aerus Electrolux store for this.
Bad power nozzle motor Needs replaced.
Bad switch. Take the whole machine in for thorough check and repair..
Jan 25, 2011 | Electrolux Vacuums
I just got the steam mop but it came without instructions, I don´t know how to assemble it. I´m not sure if I´m missing pieces
There should only be 3 basic pieces to this machine. The body housing, the top handle and the floor nozzle. The handle attaches to the body with a bolt and a nut and then the floor nozzle is just pushed into the body housing. That should be it.
Nov 30, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Missing parts
Contact BISSELL they should be able to get you going
Aug 28, 2009 | Bissell 1631 PowerSteamer ProHeat Canister...
I NEED TO CLEAN UPRIGHT HANDLE TUBE IT IS CLOGGED
Its a simple operation but it will take some time.  On the back of the Oreck just up from the motor you'll come to the first rubber ring which hides the push/pin locks of the main spine. There are two or three on the Oreck depending on the XL model - slide them down to reveal the pin locks and push them in wards to unlock the main spindle pipe. At the same time ensure that the bag clip at the bottom has been unclipped and the cord is also free, taken off the hooks at the back. The main pipe/spine at the back is the main dust channel so this is the first place to check for a clog and then upwards towards the handle/dust channel feeder - there is usually a small screw on the square part at the bottom which loosens the main handle from the body of the spine.
Dec 27, 2008 | Oreck XL2200 Bagged Upright Vacuum
Electrolux Renaissance power nozzle turning on and off, brass pins hot
The deal with the Renny is that it runs off of circuit boards. Usually the problem of the main motor shutting on and off is caused by one of the Triac boards located inside the canister. Another problem could be the thermostat wire located on the inside of your motor itself. It's almost never the thermostat, so the triac board is most likely the issue.
As far as your power nozzle goes, the head eminating from the swivel body is in most cases due to an older design of the power nozzle. I would suggest investing in a new elbow assembly that includes a new swivel body as well as newer style of wiring that is proved to reduce arcing and heat production within the power nozzle.
In some cases, fixing the power nozzle will fix the problems you are experienceing with the main motor as the arcing happening in the power nozzle can in fact turn off your machine. So investing in a new elbow assembly for your power nozzle could in fact solve the problem in its entirety.
Oct 26, 2008 | Electrolux Guardian Bagged Canister Vacuum
How do i put a new belt in kirby vacuum ultimate G
You'll want to rotate the front plastic piece 270 degrees until the red triangle on the plastic piece lines up with the red triangle on the top of the nozzle. Then, rotate the nozzle release (located under the headlight assembly) until the nozzle can pull free of the main vacuum body.
Rotate the front plastic piece back to its original position and flip the nozzle upside down. There will be two clips which will rotate to release the baseplate. After removing the baseplate you should be able to remove the brushroll and take the belt off.
Put the new belt onto the brushroll, and replace the brushroll in the nozzle, making sure that the colored dot on each bearing end is the same on both sides to ensure that the brushroll sits level. then rotate the plastic front cover again, watching to make sure that the hook inside grabs the belt and pulls it upward.
Replace the baseplate, then turn the nozzle back upright and replace it on the front of the vacuum by setting it onto the axle on the front of the machine and then tilting the top of the nozzle back into place and turning the nozzle release back to lock the nozzle into place.
Rotate the plastic front piece back to its original position, and your belt should be fully installed.
-R
Aug 04, 2008 | Kirby Vacuums
Vacuums Logo
252 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
