Question about E-Machines W6409 (7234) PC Desktop
The computer dont turn on - E-Machines W6409 (7234) PC Desktop
  • joecoolvette
    joecoolvette Jul 08, 2010
    eMachines are a budget computer. As such, they use low quality Electrolytic Capacitors on the motherboard, and low quality Power Supply's. Most of the time the issue is the Power Supply. Main reasons for Power Supply failure are, 1) The computer is dirty inside, as well as the Power Supply. There are two cooling components for the Power Supply. A) The Fan. B) Heatsink's that are used inside the Power Supply. When these two cooling components are caked with 'Gunk', the cooling capacity drops tremendously. Heat = Wasted Energy. The Power Supply strains to keep up with the call for power, and eventually components inside the Power Supply fail, causing the Power Supply to fail. 2) Low quality components used inside the Power Supply. Low quality; Electrolytic Capacitors, Rectifier Bridge/s, MOSFET's, and gauge (Size) of wiring used inside, is too small. It's just a plain old ATX power supply, rated at 300 Watts.
  • 10,319 Answers
Emachines are noted if they don't boot up the mother board has gone bad. Also the power unit goes bad on most models taking the motherboard with it as well. I have two setting around as parts units now the parts few years and have inquired into many websites about these PC's. I was told to replace them instead of repairing them for the money. I hope you will investigate my findings as well
Laptops are the way to go now a days for they are easy to move around and the power packs are under $10 to replace. Lap tops are even at the $300 range these days at Wall Mart too
Posted on Jul 07, 2010
Fans dont kick on on turning on computer
Check the 12VDC output from the SMPS. If it is lesser than this, the fault you report here can occur.
Apr 19, 2014 | Televison & Video
When my desktop computer is in standby mode, I move the mouse and I hear everything start up like normal but now the monitor dont turn on and the green light above my " num lock" turn's on. I...
For windows 7 you have to change the power settings and stop it from hibernating.Go to control panel. Go to System And Security. Go to power options / Change when the computer sleeps and change that setting to never. It gets locked in a perpetual loop when it hibernates and locks up..
Feb 18, 2011 | Computers & Internet
I need assistance with the front panel cables for Intel d915gav. My computer wont turn on. I dont know where to connect the connections. & I dont know why my computer wont turn on. Please help, I need...
Follow this link to the spec sheet for the board. Make sure the wires running from the inside of the front cover are plugged into the correct pins.
http://downloadmirror.intel.com/15196/eng/D915GAV_D915GAG_TechProdSpec.pdf
Oct 17, 2010 | Intel D915GAV Motherboard
Im trying to set my computer back to the factory default settings, and i dont know the function keys. i need to do this because i want to start from scratch with out having to delete alot of stuff that i...
computers dont realy have a factory reset the only reset function that exist is with bios to do this when the unit is first turned on press f12 and it will take you into bios but if you dont know what your doing i would not mess with bios but its your computer
best luck
Oct 14, 2010 | Dell Latitude C610 Notebook
Bright colors when computer is off
Turn off the monitor when powering off the pc.
Apr 14, 2009 | Computers & Internet
Asus dont turn on
try this
1st. turn off laptop
2nd. unplug power supply
3rd. remove battery
4th. let stand with out any power for about one min
5th. put battery back on
6th. place the power supply back in
7th. turn computer back on.
Should work!!!!!!!!!!!! Good Luck!
Jan 25, 2009 | ASUS Eee PC 900 16G Notebook
I have a virus on my computer thats called zinaps and i wanna get rid of it without having to download spywares that cost too much money. So i decided to reboot it, since i dont have a lot of important...
Go HERE and run Trend Micro Housecall on your PC. It's FREE.
To turn off your PC click Start in the lower left hand corner of your desktop and click Turn Off Computer. You can re-start it or turn it off completely.
Jun 03, 2008 | Acer Computers & Internet
No signal to monitor
Sounds like a bios issue. Check your manual for resetting your bios to default parameters. Good luck.
Mar 20, 2008 | Gateway GT5408 PC Desktop
Bad Firmware Upgread
Hi
when i connect it to computer ; computer detect it as STMP3500 ; i download STMP3500 Driver from internet and then install it to Computer but already Computer Don't detect my mp3player;
then i run MuVoS200_PCFW_A5_1_02_02.exe but at this time computer detect my mp3player as MuVo S200 Then i upgread my Firm ware.
Now it work very good.
Mar 12, 2008 | Creative Labs MuVo S200 MP3 Player
E-Machines W6409 (7234) PC Desktop Logo
52 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
