Question about Canon I900D InkJet Photo Printer
Paper jam error
My printer had a paper jam and i removed the paper intact. however, it still gives me the paper jam error and i don't see anything stuck. what can i do to get rid of the error?
  • 88 Answers
There are sensors located in the paper cart area. try to check if there foreign objects obstructing your sensors.
Posted on Apr 18, 2008
I keep getting an error message about a paper jam for my printer but there is absolutely no paper jammed anywhere in the machine.
Have you tried a new toner cartridge, The toner cartridge has moving parts, and of the cartridge gets stuck, the printer may indicate a paper jam.
Also paper often tears when clearing jams, and the little shreds of paper can stay in the rollers of the printer and keep it jammed. Make sure to inspect all the rollers to make sure they move freely, and do not have anything stuck in them.
Aug 21, 2014 | D-Link D LINK DELL B1260DN MONO LASER...
Paper jam removed but machine still shows paper jam
Maybe there are paper stuck inside the printer or maybe out of ink
Apr 03, 2013 | Panasonic KX-FL511 Plain Paper Laser Fax
How do I clear paper jam
The flashing error code that indicates a jammed printer is the digital-age equivalent of a flat tire. Sooner or later it happens to everyone, so you'd better know how to get things moving again if you want to finish your print job.
1.Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2.Turn off the printer.
3.Remove any paper trays. Inspect them for wrinkled or damaged paper.
4.Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5.If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6.If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
7.If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
8.Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9.If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Sep 21, 2011 | HP Photosmart C5180 All-In-One InkJet...
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
How do I remove stuck paper
Please follow these steps:
•1 Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
•2
•3
•4
•5
•6
•7
•8
•9
Aug 18, 2010 | HP Officejet Pro L7680 All-In-One Printer
My cannon IP1900 printer cannot print, it says paper jam, orange light blinks. I need assistance
Dear Sir,
i am giving u step to solve your problem,
Step 1 Turn your printer off and on to see if it can take out some or all of the jam automatically. If not, turn off the printer and go to the next step.
Step 2 Inspect where the printed paper stops. If the stuck paper is visible and on its way out of the device, try to manually remove it. If you can not pull the rest out easily, then refer to the next steps.
Step 3 Remove any paper trays. Check if any wrinkled or damaged paper is still stuck in the printer. If so, remove any other appliances you can (toner or ink cartridge if necessary) and look for the paper shreds. Make sure nothing has been left in this device.
Step 4 Tidy your blank papers, turn the printer back on and try it again. If the paper jam massage still appears, repeat the above steps. If no paper stuck in your device but the error still persists, well then it’s likely your printer is experiencing another hardware issue: maybe the rollers or some other part need to be adjusted or replaced. Check the printer manual and the manufacturer’s website for directions, or contact your support line for additional assistance.
Things you should take care when manually removing paper
l You should be careful, especially for a laser printer – laser printers can get hot.
l Do not remove your jammed paper from where the blank paper enters the printer, or your device might be damaged easily.
l If you find a piece of jammed paper, pull it out with both your hands carefully so as to keep the paper from tearing. If several sheets of paper jammed together, try to loose the jam by pulling out the middle one first.
l If the paper does tear, you may need to manually rotate the gears that feed the paper through the printer to free the shreds. Don’t force anything.
Thanks For Your Time,
Apr 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
My Lexmark C510 printer will print one sheet fine and then give me an error, "201 Paper Jam, Open Rear Door". If I turn the printer off it will reset and I can print one sheet again and will get the same...
there is small Plastic sensor on the paper path, is stucked or broken, is giving this error, need to look closer and check if anything is stucked (paper or dust)
Dec 28, 2009 | Lexmark C510n Laser Printer
Turned it on and it says paper jam. There is no
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 22, 2009 | HP PhotoSmart C4280 Laser Printer
The readout says Paper Jam, open front cover to clear, press i. There was no jam. A page exiting the printer stuck at the bottom end. I pulled it out easily and intact. Immediately, the red light went...
open the printer again.you didnot specify which kodak printer you have. take all papers out of paper tray .fan them properly to make sure that no two papers are sticking to each other. load papers again in to the printer,contact kodak @1800 421 6699 if u face problem again.
Jul 25, 2009 | Office Equipment & Supplies
Printer cartridge stalled
# Turn off the printer.
# Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
# Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
# Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
# Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue
Feb 06, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Canon I900D InkJet Photo Printer Logo
122 people viewed this question
old marine
old marine
