Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Eletric PTO is not working
John Deere La150 54 inch deck when the Eletric PTO switch is activated it works for a moment then gets hot and melts 2 terminals mower only has 40 hrs on it.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
The PTO draws a pretty good current, so a weak or loose contact in the switch, or in the connections on the back of the switch, could cause this overheating. But it could also happen if the PTO clutch itself or the wiring to it has a short. If the mower's still under warranty, get the dealer to diagnose and fix it. If not, then I'd measure the resistance of the PTO clutch - should be about 2 ohms - and make sure the wiring to it isn't shorted. If all that is OK, then just replace the PTO switch and any melted connectors and wiring. Good luck!
Posted on Jul 08, 2010
Tractor won't start new battery John Deere 4400 does not even turn over
The tractor has a neutral safety switch ,be sure you are in neutral or park , be sure pto is disengaged has a safety switch on pto . Has a operator present switch under seat cushion that is activated when setting in the seat. All these work together to complete circuit to engage starter. Check it out
Jan 10, 2017 | John Deere Garden
I have a John Deere 870, and the PTO quit working, first of all, the pto quit letting the mower deck go down then it quit working?
check your fluid level for the hydraulics and look and check that the pto rods are connected and adjusted correctly
Jul 31, 2016 | John Deere Garden
John Deere 285 lawn tractor pto works but the wire keeps melting?
U need to inspect wiring for wear thuroly. Some is internal from age causing resistenc. Obtain a shopbook or somethin similar in library or online
Oct 08, 2015 | John Deere Tractor Starter 285 345 2243...
F525. Updated mower switch by John Deere is not engaging mower
The John Deere F525, a front cutting machine, has 3 fuses.
20 Amp
15 Amp
10 Amp
Check the 15 amp fuse. I believe this supports the PTO clutch. If you replace the fuse and it blows again, check the electric clutch. You will likely find burnt or melted wires. The bearings do go out on these clutches causing them to run hot and eventually burn up.
PTO Clutch will not engage: There is a very fine one page discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
Resistance 3.7 ohms
Current Draw 3.25 amps
It does not give the air gap.
It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
Cap Screw torque 55 lb-ft (75 N.m).
If the fuse blows, I recommend you check the resistance of the clutch. If the clutch is shorting to ground it will show zero resistance when you ohms the connector wire to a ground position. In which case, you will have to replace the clutch.
Fixing Electric Clutches
Other possibilities.
On the F525 there is a cut-off switch in the hydraulic system. It is a low pressure cut off. If you were running the mower and deck and then it suddenly stopped, it may be low pressure in the hydraulics. It will not automatically reset as you are using the same volume for the drive pumps. Once the oil gets low enough it cuts out the deck drive 1st, then the drive pumps.
Apr 16, 2015 | John Deere Garden
John Deere LX173 pto will not engage. Wet recently
Probably the pto switch. Find the 2 wire 'T' plug from the PTO clutch and disconnect. With a voltmeter across the the 2 spades on the tractor side of the plug you should get 12 volts DC with the PTO switch on ( you may need to sit in the seat ). If you get 12 volts at the plug its probably the PTO clutch. If no power then its a fuse or the PTO switch
Oct 24, 2012 | John Deere Garden
L130 John Deere PTO problems
you have a bad seat switch
Sep 21, 2012 | John Deere Garden
John Deere 314 garden tractor PTO mower deck kills engine
bypass the safety switch on the seat to test that one
Aug 13, 2012 | Garden
Pto not engaging in john deere lx 167
Check the voltage on the wire(s) connector to the PTO switch. Sometime portion of the switch can go bad. If you have voltage coming in to the switch check the output voltage going to the clutch..
Apr 03, 2012 | Garden
John Deere 160 Mower Deck Switch - mower deck does not engage when switch is turned on. The "dead man" engine shutoff still functions when the switch is engaged - if the switch is on and there is...
Hi, check that you have 12 volts to the pto when the switch is on. It sounds like your pto is fried as the switch is functioning correctly. Regards Phil.
Sep 20, 2011 | John Deere Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
744 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
