Question about Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height
Flush mechansim Have "Tulip" model with the flush button on the top of the lid. Need a new flush mechansim. Where to purchase?
    Top Expert:
  • Pegasus Tech... Master
  • 12,650 Answers
Pegasus products are a home depot brand can get repair/replacement parts there or,there are multi plumbing supply companies online or can check ur local plumbing supply but most flush valves--flapper-parts can be changed or repaired with parts off the shelf at ur local hardware-wal-mart-home improvement stores
Posted on Jul 08, 2010
Install flush valve
Drain the tank (turn off the water supply and hold the flush valve open with your hand).
Remove the old flush valve. Replace it with a new one. Turn the water supply back on.
Jul 29, 2014 | American Standard Lexington Model 2007 /...
How do i lift the top of the toilet off the button is stopping me doing so
It sounds like you have a tamper proof cistern. The ones I know of you will need to press and hold down half flush and then pull up full flush button(do not force).
Under the buttons is a flat screw once removed your lid will be able to be removed
Mar 14, 2012 | Home
Toilet flush valve is hard to flush....too much suction. Sometimes takes two hands to push the handle.
Hi, you need new Mansfield 210/211 flush valves. They can be found on amazon.. here: Amazon com Mansfield 210 211 seal. I hope this helped you. Cheers
Jun 27, 2010 | Mansfield Plumbing Products Mansfield...
Have to hold down toil handle for 4 secs to flush
Assuming we are talking about a standard flush toilet, it sounds like the internal flush actuator lever is hitting the top of the toilet on the inside. Remove the lid, hold the exterior handle. and carefully bend the lever down a little. Also make sure the lever hasn't slipped or is loose. Put the lid back on try again. Repeat until the toilet flushes with the lid on.
Jan 25, 2010 | Kitchen Appliances - Others
I am having trouble getting the top of the cistern of an Omnia Pro suite. Does the flush button unscrew or clip off.
The flush button should unscrew from the top of the lid. to replace the flush mec. and to remove the lid.
Good luck
Nov 09, 2009 | Villeroy & Boch Home
I want to open the lid of the Kohler closet, but I
I have the same problem. Yes it is top flush!thanks
Oct 14, 2009 | Kohler Home
My V and B toilet suddenly stopped flushing today, what's the problem?
It won't drain? Is the tank draining? Is the water turned off? Or is it just plugged up?
Jun 19, 2009 | Villeroy & Boch 6610 11 Subway...
Convertible Top Lid Not Closing
top still needs to be adjusted to fully seat properly in the trunk/boot. if the upholsterer who replaced the top is not familiar with the adjusting process for a BMW, then i would take it to a BMW dealer and have them do the final adjustments.
Mar 13, 2009 | 2001 BMW 330
Push Button - Have to Hold Down Button
I had the same problem. The fix cost me 50 cents (literally). I just placed a quarter on top of the Blue and White flush buttons (not sure of the technical terms) inside the tank and now it flushes properly. It seems that the 2 plastic poles the extend from the faux chrome buttons are just a bit too short.
Hope this helps
Feb 18, 2009 | Toto Aquia II Dual Flush Toilet
Maybe I'm an idiot but I don't know how to get the top off of my
The cistern lid is held down by the chrome assembly (which includes the two buttons that you press to make the toilet flush) sticking up in the middle of the lid. You need to unscrew that (anticlockwise) to be able to lift the lid off, to get to the inlet valve, etc.
If the water is running in very slowly, chances are high that the small screen filter under the inlet valve is partially blocked. Working inside the cistern, you need to unscrew the inlet valve assembly (noting the order in which the various parts come out!), then unscrew the cranked fitting just under that, to get the screen/filter.
Dec 27, 2008 | Duravit 0910100005 Happy D Toilet Cistern ...
Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height Logo
447 people viewed this question
Top Pegasus Technologies Home Experts
john h
Jim Goldsmith
Jim Goldsmith
Paul Carew
Are you a Pegasus Technologies Home Expert? Answer questions, earn points and help others
