Question about HP DesignJet 450c InkJet Printer
HP DesignJet 450C - Color Large Scale Plotter The printer will not print in color - everything comes out printed in grayscale. I do not print color often. It used to print color, but will not now. Any suggestions or troubleshooting advice. Thanks.
    Scholar:
  • HP Expert
  • 123 Answers
The problem is probably in the printer driver. Open the printer driver options and be sure "gray scale only" is not selected.
Posted on Jul 08, 2010
Printing to HP Designjet T1200 from Linux, RHEL 5.3 Server. Error 61:01 wrong file format. The printer cannot process the job, how may I resolve this?
This can happen due to the firmware on the plotter, even if it happens only with some postscript files.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=3980523&prodTypeId=18972&objectID=c02189041
Apr 20, 2011 | HP Designjet T1200 Large Format Color...
I have a hp 450c plotter and it will not print.
Has this USB to Centronics cable worked in the past, but has now stopped?
The reason I ask is that there are two kinds of parallel ports, and so two kinds of USB-to-Centronics adapators. One is unidirectional, and one is bidirectional. If your plotter requires bidirectional, then it won't work properly with unidirectional.
Jun 10, 2010 | HP DesignJet 450c InkJet Printer
Is there any way to get my printer to print only black copies without having to buy the new color print cartridge
Go to the printer settings - Preferences- color tab - and select Grayscale in the color selection.
Once this is done, try print a color text and see if it comes in a gray scale. This will work.
To give you a tip on this.... understand that this printer has a black ink cartridge and a tri-color cartridge. When we select grayscale, only black cartridge would be used.
Good Luck.
Mar 15, 2010 | HP PhotoSmart C4180 All-in-One Color...
My HP Designjet 450C prints part of the document.
Steven, it's either lack of memory or the trailing cable is faulty and flexing open circuit at a point as it crosses the carriage rails
Sep 07, 2009 | HP DesignJet 450c InkJet Printer
No colors, just black letters
#1, is your color catridge(s) installed correctly (sometimes they still have the little "strip" on them when installed, removed plastic)
and maybe #2, when you print, is the box marked "Print in Grayscale" checked? Find the "color" tab in the Print dialogue box when it pops up, locate the check box, and uncheck it... that may be your solution :)
Hope that helps!
-- RT
Sep 02, 2009 | HP DesignJet 450c InkJet Printer
HP DesignJet 450c printer issues.
You can purchase a External JetDirect card from any reputable HP (or computer) agent. This will allow you to plug the 450 directly into the network. The problem with the large format printers not being supported is strange to me. I have never had a problem, simply load the drivers and away you go. If the 450 drivers dont work for you, you can select any of the older drivers (750c recomended) and they will work on the 450c
Feb 26, 2009 | HP DesignJet 450c InkJet Printer
450c color problem
The 430 ID is B/W, you need to load the 450C driver to get color, renaming the driver isn't enough.
Oct 13, 2008 | HP DesignJet 450c InkJet Printer
Request for designjet plotter info
my hp 450c plotter works properly in vista. First I' ve tried unsuccesfully to add new printer through windows menu. Then through Autocad menu (plotter manager) I added the specific plotter.
Jul 09, 2008 | HP DesignJet 450c InkJet Printer
Plotter only printing in Cyan
Check your black cartridge. Do the pump the cartridge thing with the plunger on the left of the plotter. Check all the electrical connectors on the cariage and the cartridge - clean with water -or wd40 if you are very careful and check that all the contacts, about 40 of them are clean and undamaged on each cartridge. Replace with known working cartridges. run a color test as specified in the manual -- hp has relased the manual for this printer as they no longer service this unit.
Jun 23, 2008 | HP DesignJet 450c InkJet Printer
HP DesignJet 450c InkJet Printer Logo
283 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
