Question about Kenmore 12502 Top Load Washer
After an unbakanced load, washer operates on all but spin cycle
  • davelin1 Jul 07, 2010
    with lid down it operates on rest of cycle but won t drain or spin
    found the broken switch
  • 1,284 Answers
Hi, first thing to check if your washer is not pumping or spinning is to see if the motor is running. If the motor is not running then check the pesky lid switch. When the lid gets slammed it hammers that switch and eventually will bend it or break it completely. Some washers will wash but not spin or pump, others will do nothing. This switch is located under the lid on the edge of the frame around the lid. Often there is a hole that a pin from the lid will go through and push on a lever that is the switch. Check that it is not simply bent, so that it does not trip the switch inside anymore. To change or check the switch the top will need to be raised or the front removed. Getting to it, is often harder then the replacement.
If the motor is running then you may have a broken pump belt or a broken or frozen pulley. If the belt is broken replace it. To check the pulley, remove the belt and then check to see if the pulley turns freely. If it does not, replace it.
If you are pumping, but not spinning, then you will need to again check the lid switch. Next on the list is the motor coupling. Many washers made are actually Whirlpool. These washers all use a coupler that is made of plastic and rubber and they will wear out after some time. This couples the motor to the transmission. If it breaks it will need to be replaced.
Other machines use belts. These belts can become stretched and then will not grip the pulleys to spin them at the proper speed. This also will often give that burning rubber smell. Be sure to replace these belts with washing machine belts as they are specially made for this purpose and are often not the same as regular automotive belts.
Drive motors are often a source of trouble. These motors often run in forward and reverse. They spin one way to agitate and the other to spin. Just because it works in one direction, does not mean that the other direction cannot be burnt out. This often happens and just because “it works” people think the motor is okay. The motor still needs to be replaced if either direction goes bad.
GE manufactured washers use a clutch system. This slowly bring the spin cycle up to speed as the water goes out of the washer. When this becomes worn the spin will not be as fast or may not spin at all. If your clutch needs to be replaced, you may want to hire that out as it is quite a project for most DIY’ers.
The final problem would be the bearing or basket drive. This gets worn or even will get tight so that the basket will not spin freely. If this goes bad you will usually have excessive noise when the washer spins. This too is a project that you may want help with.
As you can see there are many things that can go wrong to make problems with the spin cycle of a washer. You will have to do some detective work to figure out exactly what the problem is with your washing machine.
Take care
Posted on Jul 07, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check the lid switch is fine. If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Check the connector voltage which should be 110V. Also check that nothing is jamming the motor to hinder it to rotate. If still the issue persists, then it means that the pressure switch or timer has gone bad. Replace whichever is required. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Jul 07, 2010
    Thats the reason I said to check the lid switch as that might have gone bad.
  • Rylee Smith
    Thanks
    Rylee
Electrolux screaching noise on spin cycle
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a loud screeching noise during the spin cycle on your Electrolux washer. You will hear a certain amount of motor whine during the spin cycle this is a normal operation of your appliance. -Matt
Aug 23, 2014 | Electrolux EWFLS70JRR Energy Star Front...
Washer will not operate properly with full load--decrease load and will spin
Hello sismurphy1 - Does the washer make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. Try setting the cycle to spin only and verify if water pumps out. If it does not, then the unit could possibly be experiencing an issue with a faulty pump, timer, door lock assembly or control board. Contact a professional to move forward accurately.
Feb 07, 2013 | Frigidaire ATF6000ES Front Load Washer
All cycles are working except the spin cycle. I have visually inspected the wiring connections and motor and dont see any obvious issues. There are no error codes and the LED lights seem to be functioning...
Because of the high spin speeds of front load washers, the doors are equipped with a latch and lock mechanism to prevent the door from being opened during the washers operation. These locks will often be actuated by a solenoid or wax motor to ensure they remain latched during the wash cycle. This model uses a two stage lock that latches the door when the load starts, and then when it is time to spin, the second lock engages to ensure the door is properly secured prior to beginning the spin. When this second lock engages, it also closes a set of switch contacts (the auxiliary door switch) telling the control board the door is closed and locked. If for some reason this switch is not closed, the washer will tumble during what would normally be the spin cycle until the entire cycle is complete.
Jul 02, 2011 | Frigidaire Affinity ATF7000E Front Load...
My washer will spin but very slowly. Motor and shaft spins out of washer.
Your problem sounds like the drum/tub drive clutch is worn. Especially if the motor operates fine and attempts to spin the tub. This model is a direct drive unit, no belts, so if the motor operates during the spin and drain cycles but the tub is barely moving, only two problems can cause this, bad clutch (which is engaged only during the spin cycles) or worn drive coupling on the motor. If the coupling were a problem, though, you would also notice sluggish or erratic agitation during the wash cycle.
Hope this helps
kcomp1863
Jan 04, 2011 | Roper RAS6233KQ Top Load Washer
Rough, uneven Cotton Load spin cycle
Make sure the washer sits level on the floor and that the machine can't be rocked around due to uneven foot adjustment. The feet usually have rubber cups that cover the metal bottoms--one of the cups may be damaged or missing entirely. Hope this helps!
Jul 01, 2010 | Kenmore 24032\24036 Top Load Washer
Cloths still very wet after final spin cycle
Use spin ccyle again for proper operation and to help remove water.
Apr 29, 2010 | Maytag Neptune MAH5500B Front Load Washer
Top load washer won't go through cycle
modle problem here its the main board common fault with this model good luck
Mar 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin Cycle Fails on Washer
This solution is 100% correct, change the : wax motor &control board.I'll be happy to guide you through this if you need me to.
Apr 23, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Stopped operating in the spin cycle
With a heavy blanket you probably have an out-of-balance condition which doesn't let the machine spin out and drain. This would keep the door lock from opening. Try hitting the Stop button twice. This should cancel the cycle and let the door lock open after a little while. Then either redistribute the load or add some items and run a Spin and Drain cycle.
Mar 05, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 12502 Top Load Washer Logo
22 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
