Question about Refrigerators
Ice maker.....one of the stationary fingers on the ice maker is broken. Can I just replace this Comb? or do I need to replace entire ice maker?
  • 145 Answers
On some icemakers you can just get the stripper. It would depend on the brand and model of the unit.
Posted on Apr 18, 2008
Whirlpool how to install
With the freezer door open, depress the flap on the left. Does the flashing stop? If so, the Ice maker is the problem, not he optics. With the flap depressed is the only way you can test this. Solid light mean good, one flash and a pause means cycling, 2 flashes and a pause means faulted optics. Now for the ice maker, what position are the harvest fingers sitting at? At 2 O'clock the Ice maker is parked, At 12 it should fill with water so if the fingers are in any other position than 2 O'clock than the ice maker will not cycle at it can't. Its possible that the ice maker have a broken gear and will not function as designed. Get back to me if you need more information and a model number would be great. Good Luck
Jun 18, 2014 | Whirlpool Refrigerators
Icemaker will not work. water will not fill the icemaker
Hello there:
If there There's no ice Please read this entirly to assist you in troubleshooting this problem. If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try
If your ice maker has a small red plastic lever, lower it to lower the wire.
If there's no plastic lever, simply lower the wire.
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Aug 07, 2010 | LG Refrigerators
Ice maker jammed. Ejector fingers in incorrect position.
Is the position off - or the icetray heater failed?
Just before ejection - there is a heater element that warms the ice for easy discharge.
Check that the heater is working.
Reply with the model # of the fridge for more exact help.
Thanks!!
Apr 05, 2010 | KitchenAid Superba KSRG25FK Side by Side...
I have side by side and we just put in new filter . we get water but now ice maker is clicking and no ice.
Either something is obstructing the rotation of the ejector comb in the ice maker, causing that click, or the ice maker head gear is missing a tooth or its diconnected entirely, in which case you would have to replace the ice maker. If you attempt to replace that head gear, and its not attached in the exact correct position, your ice maker will not cycle correctly, and you may instead get a flood of water in your freezer.
If you want to be sure of what the problem is, I would highly recommend you have an expert refrigerator repair service inspect your fridge.
Apr 02, 2010 | Frigidaire FRS-26DR7D Side by Side...
Jen Aire Fridge ice maker fingers are below the
This one you have to take out the ice maker and run hot water from the kitchen sink into the tray to get the ice out. need model number if you want detail explaination how to. or just use a hair dryer that will work to!!! if fingers dont rotate after defrost ice then the gears are stripped, replace ice maker
Mar 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
GE side by side CAN17 ice maker...white ''finger assembly'' that pivots has broken two fingers, and the ice cubes are stuck in the cube dispenser. Any ideas why this happens, and how to fix it without...
You will need to replace the icemaker. The sensor that activates the heat coil in the icemaker is bad. The heat sensor allows the cubes to be released from being frozen to the ice tray. Check ebay for a new icemaker. About one third the price of manufacturer for new factory unit.
Oct 27, 2009 | GE Refrigerators
Kenmore ice maker not releasing ice - it stays in the bottom and ice maker makes sounds like it's trying to kick it out but doesn't. It's frozen in a big block.
Sounds as if your water valve is letting too much water in and too big of ice cubes won't let the rake strip out the ice. Look and see if the ice in the tray is up to the round arm with the fingers. If it is then the water valve needs to be replaced but you will need to get that ice outta there. Take the ice maker down by removing the 2 screws holding it above the tray. Sometimes there is one under the tray as well. Unplug the ice maker and run hot water over the tray keeping the water away from the electronic part. This will release the ice and then reinstall the ice maker.
Another possible problem is the motor module may be broken. Pull the white cover off the front of the ice maker. This will take a little elbow grease. When you access the module (You will see a white dial about as big as a half dollar) see if right in the center of that dial one of the two prongs holding that dial is broken. If you pull on it a bit and it comes off then you are sure that your module is bad. To replace it...remove the three Phillips head screws holding it on. The shut off arm will also be attached...just pull it out with a good tug. Pull the module straight out and replace the module. When replacing the module, you may need to rotate the arm in the ice maker with the fingers on it to fit in the slot in the center of the module. You should have ice within two hours.
Apr 11, 2009 | Refrigerators
Ice cube maker
IF NO WATER IN ICE MAKER, CHECK FOR RESTRICTION IN FILL TUBE SUCH AS FROZEN OFF WITH ICE. REMOVE FILL TUBE AND RUN HOT WATER OVER IT TO MELT ICE IN TUBE.
WATCH FOR WATER COMING SLOWLY OUT PLASTIC FILL LINE ATTACHED TO TUBE ON BACK OF REFRIGERATOR.
IF WATER SLOWLY DRIPS OUT OF FILL LINE, REPLACE FILL VALVE( LOCATED WHERE HOUSE WATER LINE ATTACHES TO REFRIGERATOR.
IF ICE MAKER HAS WATER/ICE IN IT, PULL FRONT COVER OFF ICE MAKER TO ACCESS CONTROL HEAD. INSPECT LARGE WHITE GEAR ON FRONT OF CONTROL. IF THE RETAINING TAB IN THE CENTER IS BROKEN, REPLACE MODULE OR ENTIRE ICE MAKER. THERE SHOULD BE TWO
RETAINING TABS HOLDING THE GEAR IN PLACE.
THE FREEZER TEMP NEEDS TO BE A MINIMUM OF 10 DEGREES FOR THE ICE MAKER TO CYCLE. IF THE FREEZER TEMP IS NOT COLD ENOUGH WE WILL NEED TO FIND OUT WHY.
Mar 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker- I am about to replace my 2nd Ice Maker
First Look at icemaker and see if fingers are sticking down in to mold with no water. Fingers should be slighlty above stripper plate (plastic piece mounted on ice maker that is closest to you)Also the fingers should rotate at all by hand. If its sticking down in the mold and the fingers move....it bad.
Then make sure the black rubber spout doesnt have ice inside (just squeeze it ......its rubber so you can feel if its iced up)
Yes, Whirlpool did have some issues with the Gears on the Motor module breaking also they have ice maker thermostat issues. I recommend a entire new updated In door Ice maker and you shouldnt have to worry about it again.
Jan 22, 2008 | Whirlpool GS5SHAXN Side by Side...
Ice maker
By manually moving the ejector blades you have now broken the ice maker module. (The brain and the motor of the icemaker). Kitchenaid had a batch of thermostats that arent working properly in these Indoor ice makers. I reccommend getting an entire new IDIM icemaker. You will have the improved module whith stronger gears (however you still cannot manually move them) and the improved thermostat.
Nov 24, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
