Question about Denon AVR-887
The power turns off seconds when it is turned on
  • 2,272 Answers
Try the reset procedure first. The procedure is as follows:-- With the system turned off hold the power on button and the speaker A and B at the same time for a few seconds.Then turn the power to the system On.Keep all the 3 button pressed for one minute then release.Then check out. 1) unplug unit from  power . 2)Hold the power on button speaker button on unit. 3) Then replug the power to the unit.Keep the buttons pressed. 4) Keep all the buttons pressed for a minute. 5) Then check. If the reset is not helping then its the electrical problem in the internal board. In the unit there is a power supply circuit board.On that circuit board there are lots of electrical components.Also there is a thermistor on the power board.If this components gets short or thermistor gets faulty then the power board will get overheated and shut off after few seconds. In this case the components on the board needs to be checked and faulty should be replaced by re-soldering. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 07, 2010
Ink system failure, error 0xc18a0001. happened suddenly, adviseme to turn it off, have turned it off, and same problem persist, it will not function a all.
Resetting the printer fixes most of 0x errors. Try next reset if the 1st one did not work.
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech
May 20, 2011 | HP Photosmart C6180 All-In-One InkJet...
Tip
HP Office Jet All in One : Resetting Steps
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Rizwan
on Jan 19, 2010 | Office Equipment & Supplies
Scanner Failure Cycle Power and try scanning again. Warming Up
Please try below resets one after the other if issue is not solved by 1st method.
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards
Riztech
Jan 11, 2011 | HP 7210 OfficeJet All-In-One Printer
When I turn my hp g85 on,I get the following message:initializing,then a sound then press enter to allign cartridges then the printer flashes off &on and turned off by its self.
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
  • Press and hold "Enter" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech
Oct 30, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
MY HP OFFICEJET 6 310 ALL IN ONE INKJET PRINTER IS FLASHING RESET POWER
Please follow below resets.
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Riztech
Oct 24, 2010 | HP Officejet 6310 All-In-One InkJet...
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
I hooked the printer up and all the lights are blinking it says reset power...what do i do...
Try the below resetting steps
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Rizwan
Aug 19, 2010 | HP Officejet 6310 All-In-One InkJet...
Officejet 5610 All-In-One InkJet Printer: error 0xd0620130 reset power...
Please try the below resetting steps
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Rizwan
May 07, 2010 | HP Officejet 5610 All-In-One InkJet...
Worked yesterday, now will not turn on!
  • Try connecting the printer directly to wall outlet without surge protector.
  • If the problem exists reset the print, see below steps to reset it.
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Riztech
May 02, 2010 | HP Photosmart 3210 Printer
Power
When i try to turn it on the power button flashes a code. The power button lights up once for a second, then turns off, then flashes quickly nine times and lights up once again for a second before turning off. The screen doesnt turn on at all, nor do the speakers. Any help would be highly appreciated.
Feb 11, 2008 | RCA D61W130 61" Rear Projection Television
Denon AVR-887 Logo
88 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
