Question about Goodman Heating & Cooling
What does the asterickon the wall control mean
    President:
  • 1,796 Answers
Hi!!
It is used as a symbol for cold, frost, refrigeration and air conditioning.
Don't forget to rate this post!!
Posted on Jul 07, 2010
  • Goodman Master
  • 5,568 Answers
There are at least a dozen brands of controllers that will work with that many different ACs.
You need to state the make and model number of the programmer/controller.
The remote control and the control panel on the wall fan are functioning well, except that when the fan is switched on either with the remote control/the panel, the fan does not start. What's wrong?
If by "the panel" you mean on/off wall switch, then you have to have the the wall switch on for the fan to work. Only use the remote for all funtions. This is all I can tell you with the info. you posted.
Jan 24, 2016 | Dryers
Five conductors are needed to wire 8663rp does that mean five wires is needed to wire fan?
It's a NuTone household fan.
Five conductors usually means five wires, though for example two of the same may be for the same purpose, 0V eg.
The fan also contains two lights. The control of fan and lighs delends on how you choose to wire it up. -
"?For?separate?control?of?fan,?light,?and night?light?three?wall?switches?are?required.?See?NuTone?Catalog?for?accessory?switches.?For?separate?control?of?fan,?light,?and?night?light,?five?conductors?are?needed?between?the?wall?switch?box?and?the?fan's?junction?box" (p1 of manual, below)
For instructions on wiring see manual for example here NuTone 8663RP Installation Instructions Manual p2
12.February.2015
Feb 12, 2015 | Dryers
Double wall oven F0 error code
The F0 error code means that the control board has detected a defect within the control board itself, the F0 code can be cleared by pushing the CANCEL/OFF button and if it goes away and returns all is well,however if a short time later the F0 returns the control board would need to be replaced.
GENE
Oct 04, 2011 | GE Profile 30" Built-In Double Electric...
Wall mounted door control flashing
The light flashing on the wall control means the vacation lock is on - pree the lock button to turn it off.
Apr 01, 2011 | Chamberlain 1/2-HP Whisper Drive Belt...
How to reset a Seth thomas weather station wall clock
what do the boxes in the clock desplay mean and also i do not have an outside temp reading on the clock just inside temp and i do not know what all the buttons on the back of the clock mean and hou to use them the clock is a seth thomas sade weather station
Oct 12, 2010 | Seth Thomas Radio-Controlled Howard Wall...
What does the F 5 error message displayed on Frigidaire - 24" Built-in Single Electric Wall Oven FEB 5 56cbs mean?
Hello there:
Here is what the code means and what needs to be dne to resolve this problem
F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control)0dd70e1.jpgShould be something like this
Jun 05, 2010 | Frigidaire 24" Built-in Single Electric...
GE profile wall, single, Get a
Hello,The "FO " reading you get is as a result of "Shorted Clear/Off key due to the membrane switch,control or connector".And these mean you have to check the Shorted key panel membrane switch; Check Electronic Range Control(ERC)
Thanks
Jun 02, 2010 | GE Profile JTP18 Electric Single Oven
The wall mounted control has stopped working for the liftmaster garage door. I need to know how to open it up to repair the problem.
If you mean the wall control you just remove it from the wall and look at the back. You will see the small printed circuit board. If you mean the keypad, it is usually glued together. Check the battery.
May 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Ritetemp 6022 and can not get it to switch from Celsius to Fahrenheit. What do the instructions mean by separate the control unit from the wall mounted terminals?
It means to remove the little blue (mine are blue) squares on the two prong things( they have numbers next to them). With the blue things on the two prong numbered things on top of the unit it turns on the function of Celsius, 24 hr clock and other things. I had this same problem but I took the blue things off and reset my unit and it went to 12 hr clock and Fahrenheit. For me the Fahrenheit was the two prong thing labeled with the number 3 next to it. That's what the instructions mean by separating the control unit (blue thing is the control unit) from the wall mounted terminal (2 prong gold things with numbers.)
Jan 04, 2010 | Heating & Cooling
Error code EO -F2_
It means that your control panel went out and you need to replace it. Here is how if you want to try your self.
The control panel is not available as a complete part.
To replace the control or touchpad, pull the range away from the wall and disconnect the power to it. Remove the cover on the rear of the control panel. Remove the screws that hold the clock or control to the front wall of the control panel. These screws also hold the touchpad to the front of the control panel. The touchpad connects to the control with a ribbon connector and there is a locking tab holding the ribbon connector to the control. Lift the locking tab and unplug the ribbon.
Dec 18, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Heating & Cooling Logo
37 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
