Question about Remington R-650s Electric Shaver
My Remington is charged but doesn't work.
With it plugged into the charger even, the blades wont spin. If I take the head and the blades off, the trimmer works. What's wrong?
  • Remington Master
  • 1,614 Answers
Most likely, the heads are either damaged or are too clogged up to spin. First, try disassembling the blades and cleaning them out thoroughly. If this is not the problem, you may need to change the heads. Remington suggests changing the heads every 12 months. You will find these for model R-650s at shaveroutlet.com. See link below
http://shaveroutlet.com/remington-sp29-titanium-rotary-replacement-heads-p-383.html
Posted on Jul 08, 2010
  • P.J. Vidacovich Dec 29, 2010
    Cleaning or replacing heads will probably not help. I believe this model had a design problem not allowing the blades to spin the required speed. I have seen numerous reviews indicating this.
I have remington rotary shaver R4150 but charger is not working i want to buy a charger
remington r4150 charging power cord
remington PR00009
3.8VDC adapter charging cord for men electric shaver remington r4150 power cord replacement parts.
Feb 04, 2015 | Remington R-4150 Flex 360 Rechargeable...
I have a skyforce gravity r/c helicopeter trying to fix for my son.When it is plugged in the charger, it just blinks green light. Have it over night, and it is still just blinking green. Have lost remote....
It means that the charged battery is full. Some chargers have a steady glow, others have a flashing light to show that the battery is charged. When you run the helicopter, is the battery fully charged, does the helicopter blades spin flat out? If so, the battery is charged and the flashing light indicates the battery is charged. If the battery isn't charged or the blades don't spin enough to lift the helicopter, or fly for some time, then the battery isn't charged and the charger may be faulty. Take it to a hobby shop to see where the problem lies, the charger and its blinking light, or the battery.
Dec 28, 2014 | Toys
Motor spins but blade doesn't
If there is a shaft sleeve available from Kitchen Aid you will need to replace that and most likely the chopping blade if there is any damage up inside it.
May 01, 2013 | KitchenAid 3.5-Cup Food Chopper KFC3511
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
My remington epilator -model EP6025- will not charge. The light doesn't show it's charging and it won't turn on at all. How can it be fixed?
I'm having the same problem right now, but I tried using my grandmom's phone charger adapter and it works even though the charging indicator light didnt turn on still, so I'm guessing you should just find a new charger see if it works. let me know if its a new charger that we need.. thanks
Dec 14, 2010 | Remington Health & Beauty
Remington 5130 battery is fully charged and when you put it on it goes click. I noticed that one of the heads moves when you try ot turn it on. Removed that head on the unit works great. Put it back it...
It sounds like either the heads are packed full of hair particles and the blades can not turn OR one of the blades has been damaged and is causing it to lock up.
Try removing all of the blades and cleaning them thoroughly and also insoect the blades, particularly the one that moves when you turn it on
If replacements are required, you will find them at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-spr-titanium-360-pivot-and-flex-replacement-heads-with-frame.html
Dec 08, 2010 | Remington R5130
After two weeks use of my new Remington R5130, now one of the three heads keeps popping off during almost during every shave. Any suggestions?
My R5130 kept falling apart when I shaved. I really like Remington Shavers (Spectrum Brands) and have had good luck with them until the R5130 model.
Two points.
1.) -THEY SHIPPED ME A NEW HEAD ASSEMBLY (BUT)- The original one I got had poorly formed plastics tabs on the blade retainer (head) I Googled Remington Shavers and used their Consumer Service tab to request a fix. They sent me a new head assembly free of charge and yes it worked much better. However, it eventually the heads started falling off again.
2.) RUBBER BAND FIXED IT - I looked it over again and thought that the range of movement and forces on the assembly pieces was just more than the design could handle so I looked for a way to contain some of the movement. I slipped a single thin (1/16"x1/8") - 2" diameter rubber band around the three head assembly and the problem has been completely eliminated. I can shave normally now. The rubber band nearly disappears under the black head flanges so it doesn't even look bad. The shave is a little firmer now but it still has most of the flexibility of the original design.
This simple fix will be a hard one for Remington (Spectrum Brands) to adopt but you might help spread the word. I am sure they will avoid this problem in the next models.
Jul 08, 2009 | Remington R510 Electric Shaver
Remington R-650s Electric Shaver Logo
324 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
