Question about Kenmore Dishwashers
Kenmore dishwasher #665.16952000 Appliance will not respond to keys on electronic console. "Quick Rinse" button is flashing and no other buttons respond. I am assuming there is a reset sequence to push. Would like to know the sequence prior to paying for a repairperson to come out and charge me to do the same thing. Any info?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 07, 2010
  • 4 more comments
  • kmmpsyd Jul 07, 2010
    Rylee:
    Have seen this post from you before. Unfortunately, the Kenmore model 665.16952000 is a model that has the console buttons arrayed on the top edge of the door, and when the door is closed, the console buttons are covered by the countertop above. This is how the dishwasher is designed, not a problem with how it was installed. So, back to the question: the "quick rinse" light is flashing, and all other buttons are unresponsive. This model must have a reset code for when the door is open. Can you find this out for me?
    Rylee:
    You might also like to know that this model does not have a "heated dry" console button at all.
  • Rylee Smith
    Rylee Smith Jul 07, 2010
    Thanks for your reply. To start with you can reset it by pressing the High temp. wash then Air Dry, High Temp wash then Air Dry buttons. If still the issue is not resolved then remove the control panel and blow air on it, if this works then it might have been caused due to moisture in the board. If it wont work then the control panel should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Thanks for the next step. I'll let you know how it goes.
  • Rylee Smith
    Sure, Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • kmmpsyd Jul 08, 2010
    Rylee:
    Thanks for your help on this. I tried the reset sequence you provided for the control panel. Still no change. I removed the control panel and dried it with a hairdryer on cool setting for 15 minutes, making sure to get into all the contacts before hooking it back up. Sadly, the flashing light and general unresponsiveness remains. So, I think your final solution is in order; that is, to replace the control panel altogether. Lucky it just snaps in an out. I'll order it today.
    Thanks again, and let you know if things don't go as planned.
    Medford
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Reset for dishwasher
What model Kenmore dishwasher?
Jul 10, 2013 | Kenmore Dishwashers
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore dishwasher 16764 Quick Rinse Light won't go off
you can try reseating the ribbon cable on the board however i strongly believe you have a stuck key and the key panel will need to be replaced.
Feb 02, 2009 | Kenmore 16764 Dishwasher
Dishwasher won't run
It is the touchpad that is faulty.. coz if the control board is faulty the unit may not respond to any button at all.. So just get a new touch pad.. If you want to buy it online.. then let me knnow i will get you the link..
Mar 13, 2008 | Kenmore 16372 / 16374 / 16379 Built-in...
Kenmore Dishwasher 665.15895793
The blinking buttons indicate the buttons are bad. The console will have to be replaced.
Jan 12, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Buttons don't respond
I have same model, same problem. The appliance repair person came today and said it was caused by a bad touch panel, which is one of the most expensive parts on the dishwasher - around $200 (plus the service call and labor = $340) and must be special ordered and will take about 2 weeks. Sorry. He said that this is a frequent problem on Kenmore dishwashers.
Dec 06, 2006 | Kenmore 16639 Built-in Dishwasher
Dishwashers Logo
26 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
