Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
It recognizes the new hard drive as a DVD drive
A new SEAGATE BARRACUDA 7200.11 ST3500320AS 500GB SATA2
...it reads it while booting...
...it reads it in Device Manager under Hard Drives..
but when i open My Computer...it recognizes it as a DVD drive..!
I have 2 more Seagate Sata drives installed...one 80G and one 180G...working
1 DVD drive working fine as well...
  • VasChops Apr 18, 2008
    ...ooops...!
    how did i miss that one....!....formating was the case...
    nice..!.....thanks for your prompt reply...!
    job done...
  • 71 Answers
Have you partitioned and formated it ? unless you do that to the drive it will not show up with a drive letter in windows. go into control panel, administrive tools, computer management, disk management - there you should see all your drives and you can partiton, format, assign or reassign drive letters to them. hope this solves your problem.
Posted on Apr 18, 2008
MYSEAGATE 500GB SATA HARD DISK IS NOT RECONGNIZED BY COMPUTER
If you are using it as a external drive you will find in my computer. If your using it as a new main drive it may have to be formatted .
Jun 29, 2014 | Seagate Barracuda 7200.7 40 GB Hard Drive
Seagate barracuda desktop 3tb no being recognized
Download testdisk and run it to see if it recognised in the list. If so use the intel option to find a boot sector
Mar 03, 2017 | Seagate Barracuda 7200.10 / 500GB / 7200 /...
I want to replace my 80 gb hard drive with a 500gb st3500320as and I have not found a way for my My XP computer to recognise the new HDD even though after a reboot the bios says it is there. This is...
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets
hope this helps you
Aug 25, 2011 | Seagate Barracuda 7200.11 (ST3500320AS)...
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
New hard drive not recognized on mac pro
OK what you could do is connect up that drive to a PC and format it with NTFS, & then put it on the Apple, it should then "See" the drive.Then you can work on it via the Apple.
Jan 29, 2010 | Seagate 500GB Barracuda ES.2 SATA 3Gb/s...
New sata hard drive i installed keeps saying ntl not found checked bios ok cant start up to format drive or insall opperating system any idea?
Hi mikecoombe,
The easiest way to put in a new drive is to boot to the old drive as a master then put the new drive in as a slave. Make sure that if your using all sata drives, that you specify which drive to boot to in your bios. Then Format from your OS, and load away.
Good Luck
Mark
Sep 17, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
I have the same problem
http://www.seagate.com/staticfiles/support/downloads/firmware http://atulchitnis.net/files/seagate.pdf red carefully and follow instruction
Aug 26, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
I cannot install windows xp sp2 on my seagate barracuda 72000.10 500gb hard drive
I would suggest you go to the seagate website and download and burn out their hard drive test. run the test from boot and see if it detects a bad hard drive after it runs
Jul 11, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
158 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
