PAPER WONT FEED IT KEEPS PULLING TO ONE SIDEANS WONT FEED
  • 9 more comments
  • hot35 Apr 18, 2008
    the paper pulls to one side and wont feed into the printer it
    seems like there is something blocking the paper but i cant see anything.it goes partly into theprinter then stops.
  • hot35 Apr 19, 2008
    canon mp 160
  • mayv Jun 06, 2008
    the paper start rolling and stop half way, it keep rolling but without paper
  • sweat236 Aug 21, 2008
    Looking at the 5470 the right side wants to feed but the left side wont feed at all. There for it won't print...
  • s_doak Nov 02, 2008
    I hve a Dell 924 AIO printer and the paper will feed some way into the printer then it will stop during the printing operation. I think a secondary feed system has gone unserviceable. The initial feed operation seems to work fine but during the print operation the secondary paper feeder has seized to operate. Can you provide a solution. Thank you Steve!
  • villalad12 Nov 30, 2008
    i have a paper jam error when there is not a paper jam please help urgent paper work to complete
  • hermie420 Dec 21, 2008
    I have the Dell AIO940 and the paper will not feed through. There is nothing physically blocking the paper. It will feed and pull the paper to the right. I've tried holding the paper upright, but then it will not feed through the printer. Any ideas??
  • mswd Jan 13, 2009
    Paper won't feed into my HP office jet 6310. Pulls to one side, wrinkles paper and won't feed. it goes partially into printer and stops.
  • Ms_S_Renee Mar 06, 2009
    I have the same exact prob! it pulls one side but then it stops and says paper jam, I have a cannon ip1800
  • Antonio Cirio May 11, 2010
    If you tell us what printer do you have, will be easyer to help.
    tell me what printer do you are using.
I have a HP Photosmart A626. The paper won't feed. It seems like something is blocking it and sometimes takes me 5 minutes to get it in where at that point the paper is ruined.
Chris
Posted on Jun 07, 2008
Mp495 Pulling one side before the other causing it to jam
The roller maybe sticky and cause the paper not to feed evenly. Clean the rollers with methylated spirits.
Mar 04, 2012 | Canon PIXMA MP495 InkJet Printer
Same problem. Printer runs but wont feed in any
observe if pick up mechanism function as when you send printing job. if yes, may pick up roller already worn out and need replacement.
Jun 02, 2010 | HP Officejet 5510 All-In-One Thermal...
When feeding my paper it keeps pulling the paper
You need to replace the feed rollers. One side is probably worn. You should be able to buy a rebuild kit for it. Try ebay.
Nov 02, 2009 | Lexmark X2600 InkJet Printer
Problems with paper feeder-wont feed through-chews up paper
I HAD THE SAME PROBLEM A MONTH AGO. I LOOKED WHERE THE PAPER LOADS AND THERE WAS A PAPER CLIP JAMMED IN THERE. I HAD A HECK OF A TIME GETTING TO IT, BUT I DID. AND IT WORKS FINE. MAYBE SOMETHING IS THERE.
Jan 31, 2009 | Canon PIXMA MP130 All-In-One InkJet...
The paper feed wont stop
the paper picking rollers i think r weak try cleaning the rollers n try it again.
thank u
May 26, 2008 | Canon SmartBase MP730 All-In-One InkJet...
Paper wont feed , keeps going in crooked
why do we the consumer have to submit the solution??? Where is Cannon after we purchased their product? This is total incompetency on their part!
May 01, 2008 | Office Equipment & Supplies
Brother hl 1440 paper jam
clean the paper feed tires with some alcahol. they are located in the upper part of the machine when you pull out the paper tray. they are gray in color. if that does not work the feed tires may need replaced.
Oct 12, 2007 | Brother HL 1440 Laser Printer
Pixma ip5000
I had identical prob with a PIXMA IP4000. Eventually solved by turning upside down removing bottom feeder tray and gaining access to the four rubber rollers which pick up the paper. I rubbed each one with light sandpaper to roughen up the rubber, turning each one by hand trying to try to abrade all the surface. It did the trick.
Oct 03, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
383 people viewed this question
jasbo
jasbo
