Question about Frigidaire DGBD2432K Dishwasher
New dishwasher leaking from plug in drain tub
I just installed this dishwasher and after all connections were made I ran it and started to see water. I looked underneath and found what looks like a plug had come out of the drain tub but it won;t stay in. This plug has wiring going to it and is encased in plastic so it won't get wet. It also has a gasket and nothing seems broken. I thought I had it back in but 20 minutes into the cycle it popped out again. I don;t see the part liste din the manual or know what it is for or how to secure it.
  • 159 Answers
SOURCE: Garbage Disposal backing up in dishwasher
Most dishwasher have a check valve at the pump to prevent water from backing into the dishwasher. If the pump is electric there is a rubber flat that may be gone or not working properly. If that is the case you need to replace the pump. If the pump is part of the motor assembly then the pump and motor will need to be replaced. One other thing to make sure of is that you have the drain hose looped to the top od the dishwasher and then to the disposal conection. Its called a drain loop and all dishwashers should have it. Good Luck
Posted on Jul 12, 2007
huuum
  • 750 Answers
SOURCE: FRIGIDAIRE DISHWASHER FDB1050REC0 LEAKS UNDERNEATH
There are a couple reasons water may be leaking out the door of a dishwasher.
1. The water is most likely coming out the bottom of the door where there is no rubber seal.
2. The rubber seal is around the door jam on top and both sides and not on the bottom. This means if the dishwasher has to much detergent in it the soap suds push only the water higher than the front edge of the wash basin and out the bottom of the door where there is no seal!
3. Fill only the soap cup that can close for the secondary wash. The open cup is a pre-wash and mostly not needed unless the food is baked on.This just wastes money to fill both of them every time.
4. And if you are using liquid detergent you only need half the amount from the powdered soap!
try less soap. Remember to much soap too can cause the water overflow.
5. And the last would be that the drain is clogged and caused a back up large or small and then the overflow!
is there water in the bottom when the wash is done?
Soap is usually the culprit, not that there can't be a leak in an old drain or water supply hose!
Go with the soap idea first!
Let me know how you are!
How old is the washer ?
Please remember to leave a rating before you go!
Thank You ,Huuum
Posted on Oct 03, 2008
SolutionGuy
  • 331 Answers
SOURCE: KitchenAid Dishwasher fill up with water after use
Hi BB,
There are only 2 places the DW can get water from. One is the drain line and the other is the supply line. We need to eliminate one to diagnose the problem, OK?
The first picture is a drain hose gone wrong...
Inspect your drain hose. If it looks like the pic above, you gotta fix that. Even IF that's not the problem right now... it will be in the future (and MAY be contributing to the problem now). You'll need to loosen the clamp, remove the drain hose from its' fitting, pull as much slack as you can get from the DW and then make a "loop" in it before reconnecting it. Like this...
The DW drain loop should be as high as the highest part of the sink...
I know that you have done a lot of experimenting in an attempt to figure this out. Just make sure that the drain hose is installed properly to eliminate it as the cause of the flood issue.
After you've made sure about the drain hose, leave the DW alone overnight. If you see water in the tub the next morning, you definitely have a failed valve on your DW. Since it's new (less than a year?) the valve is under warranty and will be replaced at no charge.
Hope this helps. If it's out of warranty let me know and I'll do the part look up for you and provide detailed replacement instructions, OK?
SG
Posted on Apr 14, 2009
SOURCE: Frigidare Ultra Quiet III Dishwasher won't drain
To properly drain and clear out any clogs in a dishwasher: 1.Take a wet/dry vacuum, remove the paper air filter (usually just a screw) from the inside of the vacuum body 2. Empty out the vacuum body prior to using it.  3. Then **** out all of the water from the inside basin/tub.  4. Before you turn off the vac, lift the hose high into the air and make sure all of the water is sucked into the vacuum to prevent any water still in the tube from making a mess.  5. Dump that water. This will provide you an opportunity to remove excess water before you get to work.
Next, under the sink there you will see your drain, just above your drain you will see a black or transparent tube about 1" in diameter.  6. Unscrew the tube screw.  7. Get your vacuum hose and hold it near the tube. When you take off the tube, there may be, though likely not, some excess water in the tube. **** this up if needed.  8. Put the vac hose onto the tube and make an air tight seal with your hand over the hose and tube.  9. Turn on the vacuum and such out any clogs.  10. Turn on your dish washer and let it run for a minute or two to get water back into the tub.  11. Open the door, there should be about 1-2" of water in the tub.  12. Hit the cancel button and let the water pump out of your tub, be sure to hold the vacuum hose over the tube and **** out all the water with the asistance of your dishwashers pump.  13. Repeat steps 8-12 2-3 times. You should notice water will no longer remain in the tube when you fill it up, & press the cancel button because the machine will pump everything out for you. Once you have done this and the water pumps out without a problem you have fixed your clog.
14. Reattach the tube to the drain using the tube screw. 15. Dump the water from the vacuum down the drain. 17. Clean up and put your vacuum away. 16. Put the $95 into your savings account because you likely just fixed your clog in under 45 min. from start to finish.
I hope this helps!
Posted on Aug 18, 2009
SOURCE: Just had new Frigidaire dishwasher installed. When
pf is means power failure.
Posted on Dec 31, 2009
Water drained out of tube, but dishwasher stops and indicators tell me "drain is plugged."
The drain hose on a dishwasher must be long enough to go up above the water level of the dishwasher and then back down to connect to the sink drain. This is to keep gravity from draining the tank. However, you probably replaced the drain hose the same way it was originally.
Try checking the float and float switch for smooth operation. Maybe the float has debris holding it up from dropping to the true water level.
Jan 10, 2014 | Asko 24 in. D3450 Dishwasher
Installed new tub drain linkage assembly water still leaks by
You need to use clay party to seal around the fitting 3_25_2013_1_25_38_am.png
Mar 24, 2013 | Home
Dishwasher didn't drain completely after final rinse.
Check the drain hose stub connection at the disposal for plugging. Lots of material flying around in there which could block the stub pipe. You might consider inserting a short section of drain pipe that has a built-in stub into the regular sink drain and plug the disposal stub. Also check the screen at the bottom of the lower spray arm assembly for plugging. Clean the screen in a mixture of hot water/detergent/white vinegar for an hour or so. That will remove hard water deposits from the screen as well as any food debris. The draining process is a timed event, so it depends on fairly rapid removal of the water. Hope some of this helps!
Mar 19, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Our KitchenAid dishwasher has been working great until just recently. It has started to leak small amounts of soapy water about half way through the process. I ran an empty load and it didn't leak. Ran...
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Answer 2 (Door seal replacement)
Hi
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repair person. The door seals on this Kitchenaid dishwasher are pressure fit into a metal channel that runs along the inside of the wash tub.
To install, simply remove the old seal paying close attention to which way it was installed, apply a bead of adhesive inside the channel, then install the new seal in the correct direction. A test fit prior to applying the adhesive is a good idea and if you are having trouble with one side being to long, try folding the seal in half, take hold of the looped end, and insert it under the door latch. The reset should go in properly. The new seal will be a tight fit which is the way we want it so it may take some force to get it fully seated. If the door is hard to close, then the door seal needs some more work.
Thanks
Rylee
Nov 09, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Doesn't drain; glasses have film; rinses with used, soapy water
The white film problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Sep 02, 2009 | Dishwashers
Water not draining completely from Dishwasher tub
That usually happens because of a faulty water level sensor, check it out.
May 12, 2009 | GE Nautilus 24" Built-in Dishwasher
SPRAY ARM ASSEMBLEY NOT TURNING ON MY BOSCH DISHWASHER, ALSO WATER JUST DRIPPING THROUGH SPRAY ARM
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
Mar 09, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Brand new dishwasher will not drain at end of cycle.
Check your manual. Some dishwashers actually do leave water in them after the final drain cycle. It has to do with the type of seals they use. Some will leak the very first time they are used but not after that. The seals in these types must remain wet. If this isn''t the issue, wait about 5 minutes fir the timer to finish. Sometimes there is quite a lag at the last cycle. If all else fails, call the customer service number in the manual.
Feb 02, 2009 | Haier ESD300 / ESD301 Built-in Dishwasher
Brand new dishwasher installed and water leaks out bottom of door
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note…If the main motor of your dishwasher is mounted vertically, beneath thecenter bottom of the dishwasher, the following instructions probablyapply to you. But if your motor is mounted horizontally, the pump isn'tserviceable--you need to replace the entire pump and motor assembly.
Themain tub seal is beneath the drain impeller. It prevents the water inthe dishwasher from leaking out near the shaft of the motor. To get tothe seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
Door gasket or seal Overtime, door gaskets and seals harden and lose their ability to sealproperly. You can't repair the seals. You need to replace them ifthey've begun to leak.
Water-inlet valve Thewater-inlet valve, itself, seldom leaks. But, the water-supply linefrom the house and the rubber tube leading from the valve to the insideof the dishwasher may leak. Tighten or repair/replace these asnecessary.
The water-inlet valve could mechanically stick open.When that happens, the water continues to flow into the dishwasher,which then floods your kitchen. Turn off the water supply to thedishwasher, and replace the valve.
Hoses Behindthe lower access panel on your dishwasher are several rubber or plastichoses. If the leak appears at a connection, try a new clamp. If thatdoesn't work, replace the hose.
Dec 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwashing machine not fully draining (2 inches of water remain). I have an open problem concerning this problem. I have a new pump. dishwashing machine not fully draining (2 inches of water remain) For...
Following a cycle, a small pool of clean water inside the tub is typical. Excessive water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up. If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made (see your disposer instructions).
Apr 19, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Frigidaire DGBD2432K Dishwasher Logo
35 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
