Question about Pass & Seymour Pass and Seymour Decorator Fan Speed Control with Dimmer, White #LSDC16PWV
Is there a wiring guide for the Pass and Seymour LSDC163PWV? Which colors are for the Fan control and which for the Light?
  • 83 Answers
Go to the website below for diagram. Under specifications.
https://www.legrand.us/passandseymour/fan-controls/de-hummer/ls-series/lsdc163pwv.aspx
Posted on Oct 07, 2017
3 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: how to install a dimmer switch
This is a 3-way switch, made to control a light fixture that is also controlled by another switch in a different location. A typical example is a ceiling light fixture installed in an upstairs hallway, which could be controlled by switches at both top and bottom of the staircase.
The green wire in your switch is the ground connection, and joins to the green insulated or bare copper ground wire in the switch box. The red wire is the common connection. It connects either to the incoming AC hot wire from the electric panel, or to the hot terminal of the light fixture, depending on the switch location. The two black wires are traveller connections. They connect to the traveller terminals of the other 3-way switch.
If you purchased this switch as a replacement for a regular single-pole toggle switch or dimmer switch - one that controls a light from a single location only - then this isn't what you need and you can't use it. You'll know if you have a single-pole switch because it will have only three wires or screw connections. Return it and get a single-pole.
To install this as a replacement for a 3-way toggle switch or dimmer, connect the red wire to the wire going to the common terminal of the original switch. This will be a black- or brass-colored screw on a toggle switch, or the different-colored (not green, that's ground) wire on a dimmer. The black wires connect to the wires that go to the traveller screws (copper-colored) on a toggle switch, or the same-colored wires on a dimmer. It doesn't matter which traveller wire connects to which.
Note that if you're using a 3-way dimmer, only one of the switches can be a dimmer. The other switch has to be a plain old 3-way toggle.
Posted on Apr 09, 2010
SOURCE: Trying to install pass & seymour / legrand
I installed two D703p single pole. I was replacing two other brand that were stilling working at the time. The first one went to a light in the dinning room, and it worked, it had two black wires. The second one went to a wall plug in with two red wires, I can not get it to work. thanks for your help Don
Posted on Aug 05, 2010
What does common mean on a dimmer switch
The common wire is usually the white wire. Some switchs are only wired with a hot (black) wire. So not all switchs need a common wire (leg).
Aug 20, 2014 | Pass & Seymour Pass and Seymour Decorator...
Installing two pole switch
Copy following link to help identify switch and wiring:
http://waterheatertimer.org/How-to-wire-switches.html#PandS
Add a comment and describe timer and wiring in detail.
Gene
Jul 31, 2013 | Pass & Seymour Pass and Seymour Decorator...
I am using a Pass & Seymour illuminated three way light switch. I wired my white and ground wire on one side and the hot wire black to the black painted screw and the red wire below to the brass...
I answer questions for free
I work with timers and electrical devices.
If I understand correctly you replaced a 3-way switch.
The new switch has 3 screws (plus green ground screw)
You put the Hot wire on the dark screw correctly.
You attached the two travelers to the brass-colored screws.
The two travelers are red and white.
You connected the ground wire to the green screw.
The ground wire is not supposed to be connected to with the white wire, and I doubt it is because that would trip the breaker.
The lights are working correctly.
If you followed the formula above to the letter, then the lighted switch should light up.
My best guess at this point is that the lighted switch is defective.
The Pass and Seymour webpage does not have manuals to look at like Leviton and Lutron products.
As a result I can't pour over a manual and put a magnifying glass on the wiring and wording to see if there is something we've missed.
But it's just not that complicated ... the light switch should light up.
At this point, I suggest you re-read the instructions (just in case?) and then swap the switch for another one ... or get different brand.
Nov 04, 2010 | Pass & Seymour Trademaster 3-Way 15 Amp...
Pass and seymour ws 3000 Hooking up to basement I have a white, black and copper wire. On the switch I have a green read and black wire. Black to black. green to ground Red to ?
You're right, green goes to ground.
Black wire connects to Hot wire from breaker box
Red goes to Load (fan, light, motor)
Ok which wire on the switch goes to the Load?
And which goes to Hot from breaker box?
You can test or you can simply hook up the device. If it doesn't work, swap the two wires.
It just won't work until the 2 wires are correct.
Oct 23, 2010 | Pass & Seymour #DDH16PBK White Fan Control...
I to want replace a regular duplex outlet with a TM818-WCC6 and want just the outlet switched. How do I wire it?
The Pass and Seymour plug-switch combo has 3 screws
There is a dark screw on one side .... the black Hot wire from breaker box connects here
There are silver and brass colored screws on other side of device
The white Neutral from breaker box connects to silver screw connects here >>> this will give power to your receptacle
The black wire going to Load (light, fan, motor that you want switch to control) connects to brass colored screw ... the switch controls power to Load
How to test for black Hot
Remove devices and separate wires
Turn on power
Test each wire to bare copper wire
Tester lights up on black Hot wire
How to test for white Neutral
Test black Hot to each white wire
Tester lights up on Neutral
Oct 16, 2010 | Pass & Seymour #TM818WCC6 15A White...
Trying to install lsdc163pwv for ceiling light operated by 2 different switches. Install box is through switch with black common hot wire, red and black travelers and 2 white neutrals and grounds . New...
Found a .pdf file that shows LSDC163pwv ... it does not show wiring for LSDC. It shows wiring for other 3-way dimmers & separate wiring for 3-way fan control. This is a clue.
The Pass and Seymour download page does not load, so I can't see specific manual.
Let me provide what I know:
-Instructions might be confusing because LSDC works for both single-pole and 3-way circuits ... which probably adds a lot of extra wording in manual
-LSDC Device has single-pole/3-way dimmer (this requires 3 wires)
-Device has single-pole/3-way fan control with 3 speeds (which requires 3 wires)
-That's 6 total wires
-If I understand correctly, you just want to control a ceiling light? -And you do not have a fan? And your ceiling light is set up with 3-way switches.
-IF you are also wanting to control a fan in addition to the light, the box will need separate wires that go specifically to the fan >> your description shows that you do not have separate wires for the fan. Is this correct?
-Without separate wires to the fan, you can still control the light ... but if wires to light also turn the fan on-and-off, then the LSDC is not the right control since a dimmer for lights will not work on both fan and light.
To wire the light:
-You have identified black common wire for light (it is connected to dark-colored screw on 3-way switch)
-You have identified travelers that connect the 3-way switches
-The neutral wires seem to be twisted together at back of box.
-I think the dimmer is located on the top, and fan control is bottom?? Not 100% sure >>>
-Question: are there 3 wires that are associated with dimmer?
-If you can see 3 wires for dimmer, one of those wires should be black ... just hook that to common, and hook other 2 wires to travelers ... and see if it works. If not, keep connecting them until correct combination is found.
Tip- I read a lot of electrical part manuals, and when confused, I write out the instructions so it breaks down the information.
Oct 03, 2010 | Pass & Seymour Pass and Seymour Decorator...
Our switch for the ceiling fan burned out today. Instead of getting the same type of switch (rotary knob with push on/off) I bought a Pass & Seymour combination toggle switch (dual on/off toggle...
The wire to the ceiling fan are meant to send voltage to the fixture only and are not usually wired to control both the light and the fan independently. In order to do that, you may have to pull another set of wires to the switch box and then connect them to the light circuit in the box where the fan is. In regards to the other wiring that you mentioned, it makes no sense that the wires go to the stove fan and the bathroom fan unless those wires are source wires that carry the incoming voltage.
Mar 17, 2017 | Pass & Seymour #690IGCC6 15A Ivory DPLX...
I bought a Dual fan and light control SLSDC16WCC6, no instructions in the box. The unit has red, black, yellow, and green wires. The electrical box for the wall switch has three wires, orange black and...
Would suggest you contact the Pass and Seymour Div. of Legrand (France) and ask for the pdf file with the instructions. Your unit has a wireless function and must be work properly.
Sep 02, 2017 | Pass & Seymour CS320LACC 3-WAY COMMERCIAL...
Pass & Seymour Pass and Seymour Decorator Fan Speed Control with Dimmer, White #LSDC16PWV Logo
718 people viewed this question
Top Pass & Seymour Electrical Supplies Experts
ken skalski
Ottoniel
Mike
Are you a Pass & Seymour Electrical Supply Expert? Answer questions, earn points and help others
